Loading...
Pages: 1 [2]   Go Down
Author Topic: Wait Command  (Read 1140 times)
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
while loops can be used in different situations other than while x do squat, but if it works for you then go with it
Logged
Alsager, Stoke on Trent
Offline Offline
Newbie
Arduino rocks
View Profile
Not at all I asked for a simpler command akin to a wait command and you guy's came thro.
I like the idea of less code.
I am working on changing to WHILE it as we speak.
Regards  john
 smiley-grin smiley-grin
Logged
Offline Offline
Newbie
Arduino rocks
View Profile
OK Guy's,
I knew I would get into trouble.
I am enclosing some code I wrote to read a thermister then map it to a temp range, test it and if it doesn't reach a certain temp them my simple program looped it using goto.
I now want to do the same thing but using WHILE but I can not work out how to make it do a wider loop.
Anyone help me???
Code:
Not50c:
                  // read the analog input into a variable:
  int svotempvalue = analogRead(svotemp);     //Read the SVO Thermister
  svotempvalue = map(svotempvalue, 150, 390, 50, 90);
  Serial.print("Oil Temperature ");
  Serial.print(svotempvalue);
  Serial.println("c");
  delay(2000);
  if (svotempvalue < svotempthreshold)
    goto Not50c;         //if SVO temp lower than 50c then loop until hot
as you see I used a goto loop but now I am trying to be converted.
The svotempthreshold at this point is 50
I sorted the code out for reading a level sensor switch OK (the subject that started this thread)
John
 8-) 8-)
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
 // Read the temp once
  delay(2000);
  // If (while) it's not warm enough, do it again
  while (svotempvalue < svotempthreshold)
     delay(2000);
  // Now, it's warm enoug
Logged
Offline Offline
Newbie
Arduino rocks
View Profile
So what you are saying is that the first sequence sets the initial svotempvalue and it is the sequence between { & } that will keep looping.
I can probably lose the first set of print commands and also the initial delay to reduce the code.
That looks SIMPLES....
Thanks
John
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
  delay(2000);
     delay(2000);
Really, what you want here is a "do { } while();" loop, not a "while" loop.
A "do..while" will always execute the loop code at least once, whereas a "while" loop may skip it completely.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
Arduino rocks
View Profile
Hi AWOL
Just looked up the do...while command.
Is this what you mean.....  Perhaps I dont need the first read/print sequence at all......
Code:
  // Check the oil temp is 50c
do
     delay(2000);
while (svotempvalue < svotempthreshold);
//Oil is 50c. So go to next sequence
John
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
