Loading...
Pages: [1]   Go Down
Author Topic: Re: Arduino Mega Kit source example (Program Cod)  (Read 301 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
hello,i`ve just buyed Arduino Mega Kit,but i`ve never worked with it and i want to ask if someone could give me an example program to visualize some data on PC through USB interface...it doesn`t matter what data would be power,current or voltage
thank you !!!
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
Hi  Dimitar.
If you start the arduino IDE, open file->examples->communication->Graph and read the text in that sketch. The sketch also gives code for processing (http://processing.org/) and Max/MSP as programs for on your computer.
Jeroen
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thank you for the previous info. I saw the materials witch you point me but because I'm a beginner I couldn't handle myself.If this doesn't bother you could you give me the program ( code) and its algorithm with witch to visualize the value of Power.
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
I (we) will help you with problems as they arise but i will not write your code.
Quote
...witch to visualize the value of Power.
Power of what? Can you explain what it is that you want to accomplish?
Jeroen
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i want to visualize on my pc connected to the  board with usb interface voltage from some analog input
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
Ok. If you try what i explained in reply 1 what is the first problem you have?
Jeroen
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i can`t find the source code(program) to visualize voltage
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
It's between
Quote
/* Processing code for this example
and
Quote
xPos++;
In the arduino sketch i pointed you to.
You should copy/paste that to the processing program on the pc and remove what is highlighted below.
Quote
[glow]/* Processing code for this example[/glow]
 // increment the horizontal position:
 xPos++;
 [glow]*/[/glow]
Probably a better advice would be to experiment with some (all) of the examples (like digital->blink) before you do a 'full project' to learn some programming/syntax.  While it seems that that doesn't help you with your goal it is actually vitally important.
Jeroen
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
is this the program(cod) I need to visiolize the voltage
 // Graphing sketch
 // This program takes ASCII-encoded strings
 // from the serial port at 9600 baud and graphs them. It expects values in the
 // range 0 to 1023, followed by a newline, or newline and carriage return
 // Created 20 Apr 2005
 // Updated 18 Jan 2008
 // by Tom Igoe
 import processing.serial.*;
 Serial myPort;        // The serial port
 int xPos = 1;         // horizontal position of the graph
 void setup () {
 // set the window size:
 size(400, 300);
 // List all the available serial ports
 println(Serial.list());
 // I know that the first port in the serial list on my mac
 // is always my  Arduino, so I open Serial.list()[0].
 // Open whatever port is the one you're using.
 myPort = new Serial(this, Serial.list()[0], 9600);
 // don't generate a serialEvent() unless you get a newline character:
 myPort.bufferUntil('\n');
 // set inital background:
 background(0);
 void draw () {
 // everything happens in the serialEvent()
 void serialEvent (Serial myPort) {
 // get the ASCII string:
 String inString = myPort.readStringUntil('\n');
 if (inString != null) {
 // trim off any whitespace:
 inString = trim(inString);
 // convert to an int and map to the screen height:
 float inByte = float(inString);
 inByte = map(inByte, 0, 1023, 0, height);
 // draw the line:
 stroke(127,34,255);
 line(xPos, height, xPos, height - inByte);
 // at the edge of the screen, go back to the beginning:
 if (xPos >= width) {
 xPos = 0;
 background(0);
 else {
 xPos++;
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
Yep. That's the code to paste in processing on your pc. Remember to remove the lines that are highlighted in reply 7.
Jeroen
edit: If you post code please use the #-button.
« Last Edit: December 18, 2009, 06:37:24 am by Yot » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
is this the program(cod) ?
// Graphing sketch
// by Tom Igoe
void setup () {
size(400, 300);
background(0);
void draw () {
// draw the line:
stroke(127,34,255);
xPos = 0;
background(0);
else {
xPos++;
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
Have you tried? What did it do?
You actually have to do something yourself.
Jeroen
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I haven't got any knowledge of this program but I've been assign a task to visualize the voltage. Can I use a ready code from somewhere, coz I can't write it by myself.
Logged
Global Moderator
The Netherlands
Offline Offline
Sr. Member
don't panic...
View Profile
If you spend a couple of hours reading the examples in the arduino IDE and processing IDE you will have the knowledge to do what you want by copy/pasting.
If you don't want to do that then the simplest way of 'visualize the voltage' will probably a multimeter.
Jeroen
Logged
Pages: [1]   Go Up
Print
Jump to:
