Topic: Declaring Class Variables / Calling Constructors (Read 12430 times) previous topic - next topic
tamberg
(coming from Java, no C/C++ experience)
there seems to be a difference between Processing and Arduino when it comes to calling a constructor to instantiate an object of a class.
E.g. Processing
   C c; // declare variable c
   c = new C(); // create object of class C
   c.M(); // call method M of c
vs. Arduino
   C c(); // declare & create
   c.M(); call method M of c
Now my questions:
1) Is there a way in Arduino to declare a variable of a class and *later* assign an instance to it?
2) Does Arduino really have classes, objects and constructors?
Regards,
tamberg
PaulS
Quote
No. What you have to do is move the logic that you would put into a constructor into an initialization method, instead (usually called begin).
Quote
Yes. It has objects, but not instances.
tamberg
Thanks for your quick answer. What do you mean by "objects but not instances"? Isn't an object just an instance of a class? Or are Arduino objects rather like structs in C?
Regards,
tamberg
Spinlock
I have to disagree with PaulS.  It does have objects and instances - just not dynamic instances.
that is to say you can't create and delete objects on the fly using C++'s new and delete.
PaulS
Quote
To me, that's what distinguishes objects from instances. Objects are statically defined, while instances are dynamically defined.
Perhaps not technically accurate (certainly not with using the word static there), but that's the way I think of objects and instances.
AlphaBeta
PaulS
Yes, I know that. I'm struggling to come up with the right terminology to define the difference between object1 and object2 in this scenario:
MyClass object1;
MyClass *object2 = new MyClass();
Since the Arduino can't do the latter, I think of it as not being able to have instances. I guess that's not the right term, but I don't know what the right term to describe object2 is.
mfm9
You could say that the Arduino has instances, but not instantiation ;)
-Mike
AlphaBeta
My (well, not only mine) ideas on the matter:
MyClass object1; //this is in fact instantiation of the class MyClass
MyClass *myObjectReference = &object1; //could use myObjectPointer
Generally one speaks of the latter example as 'A pointer to an instance of class MyClass' or simply 'A pointer' or 'A reference'.  :)
jgrepps
Quote
tamberg, can you elaborate on this question?  Are you trying to create an instance of an object1 within another class (say...MyClass2).  Then set variables of object1 via a method of object1?
