Author Topic: Declaring Class Variables / Calling Constructors  (Read 812 times)
(coming from Java, no C/C++ experience)
there seems to be a difference between Processing and Arduino when it comes to calling a constructor to instantiate an object of a class.
E.g. Processing
    C c; // declare variable c
    c = new C(); // create object of class C
    c.M(); // call method M of c
vs. Arduino
    C c(); // declare & create
    c.M(); call method M of c
Now my questions:
1) Is there a way in Arduino to declare a variable of a class and *later* assign an instance to it?
2) Does Arduino really have classes, objects and constructors?
Regards,
tamberg
Seattle, WA USA
Seattle, WA USA
No. What you have to do is move the logic that you would put into a constructor into an initialization method, instead (usually called begin).
Yes. It has objects, but not instances.
Thanks for your quick answer. What do you mean by "objects but not instances"? Isn't an object just an instance of a class? Or are Arduino objects rather like structs in C?
Regards,
tamberg
Canada
You will become one with the Arduino!
I have to disagree with PaulS.  It does have objects and instances - just not dynamic instances.
that is to say you can't create and delete objects on the fly using C++'s new and delete.
Seattle, WA USA
Seattle, WA USA
To me, that's what distinguishes objects from instances. Objects are statically defined, while instances are dynamically defined.
Perhaps not technically accurate (certainly not with using the word static there), but that's the way I think of objects and instances.
Norway@Oslo
loveArduino(true);
An object is an instance of a class.  smiley
Seattle, WA USA
Seattle, WA USA
Yes, I know that. I'm struggling to come up with the right terminology to define the difference between object1 and object2 in this scenario:
MyClass object1;
MyClass *object2 = new MyClass();
Since the Arduino can't do the latter, I think of it as not being able to have instances. I guess that's not the right term, but I don't know what the right term to describe object2 is.
Huntsville, Alabama, USA
You could say that the Arduino has instances, but not instantiation smiley-wink
-Mike
Norway@Oslo
loveArduino(true);
My (well, not only mine) ideas on the matter:
MyClass object1; //this is in fact instantiation of the class MyClass
MyClass *myObjectReference = &object1; //could use myObjectPointer
Generally one speaks of the latter example as 'A pointer to an instance of class MyClass' or simply 'A pointer' or 'A reference'.  smiley
tamberg, can you elaborate on this question?  Are you trying to create an instance of an object1 within another class (say...MyClass2).  Then set variables of object1 via a method of object1?
