Topic: GSM continuous data sending problem to server (Read 747 times) previous topic - next topic
Fazlul_karim
code given in here
voltage,temp,current,frequency are real time value
String one="a=";
String two=String (one+voltage01);
String three="b=";
String four=String (three+current01);
String five="c=";
String six=String (five+frequency01);
String seven="d=";
String eight=String (seven+stator_temp01);
String nine="e=";
String ten=String (nine+rotor_temp01);
String need="&";
String final01=String (two+need+four+need+six+need+eight+need+ten);
Serial println(final01);
mySerial.println("AT+HTTPPARA=\"URL\",\"www.imkhalid.info/fazlu/data.php?"+final01+"\"");
  ShowSerialData();
   mySerial.println("AT+HTTPACTION=1");//submit the request
 delay(5000);
 ShowSerialData();
output
serial monitor shows
a=0.00&b=37.25&c= INF&d=29.63&e=-127.00
AT+HTTPPARA="URL","www.imkhalid.info/fazlu/data.php?a=0.00&b=37
AT+HTTPACTION=1
OK
+HTTPACTION:1,200,0
server only shows this
a=0.00&b=37  .
where the ohers value.is this for GSM 2G feature.
what is the solution of it.
J-M-L
#1
Oct 20, 2016, 09:42 am Last Edit: Oct 20, 2016, 09:44 am by J-M-L
What do you see if you do
Serial.println("AT+HTTPPARA=\"URL\",\"www.imkhalid.info/fazlu/data.php?"+final01+"\"");?
Also remember software serial buffer is limited... might want some timing built into what you do
PS: I'd say drop the way you use String object in the first place and use char arrays
Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums
Pas de messages privés SVP
PaulS
The sprintf() function will produce the same string without trashing memory. Learn to use it, and forget that the stupid String class even exists.
J-M-L
let's say with a bit of strcat() and dtostrf() because he is using floating point data
but I don't think this is his real problem. if you count the number of character in
you can see this is 64... 64 and Serial ports rings a bell.. or should...
PaulS
Quote
That is being sent out. Sure, it will block when the outgoing buffer gets full. But, that isn't a problem.
OP needs to print to the serial port what is actually being written to the (stupidly named) mySerial instance.
Either the data is correct, or it isn't. Right now, we have no way of knowing.
Fazlul_karim
i also tried in this way but,
Arduino compiling error found.
this line .mySerial.println("AT+HTTPPARA=\"URL\",\"www.imkhalid.info/fazlu/data.php?
a="u"&b="v"&c="w"&d="y"&e="z"\"");
char u[10];
dtostrf(voltage01,8,2,u);
Serial.println(u);
char v[10];
dtostrf(current01,8,2,v);
Serial.println(v);
char w[10];
dtostrf(frequency01,8,2,w);
Serial.println(w);
char y[10];
dtostrf(stator_temp01,8,2,y);
Serial.println(y);
  ShowSerialData();
delay(10000);
 ShowSerialData();
J-M-L
Yes - but since he is stating that on the server side he is only receiving
Quote
server only shows this a=0.00&b=37
that seems to indicate that something is happening with the buffer. as we don't know how this is setup and how often he loops this... wondering how the buffer plays with the dynamic String objects he is playing with...
Yes - but may be not enough.
indeed would be on safer grounds with a char array.
PaulS
Quote
You seem to think that some automagic concatenation is going to happen here. It is NOT. Get over it.
Code: [Select]
char atCommand[120];
sprintf(atCommand, "AT+HTTPPARA=\"URL\",\"www.imkhalid.info/fazlu/data.php?a=%s&b=%s&c=%s&d=%s&e=%s\"", u, v, w, y, z);
modem.println(atCommand);
Notice the meaningful name for the SoftwareSerial instance, instead of the stupid name.
Fazlul_karim
problem still remain unsolved . please help me.
I try this way
char u[6];
dtostrf(voltage01,6,2,u);
Serial.println(u);
char v[6];
dtostrf(current01,6,2,v);
Serial.println(v);
char w[6];
dtostrf(frequency01,6,2,w);
Serial.println(w);
char y[6];
dtostrf(stator_temp01,6,2,y);
Serial.println(y);
char z[6];
dtostrf(rotor_temp01,6,2,z);
Serial.println(z);
gsm.println(atCommand);
ShowSerialData();
gsm.println("AT+HTTPACTION=1");//submit the request
delay(10000);
 ShowSerialData();
Serial monitor result
u= 0.00
v=36.00
w= INF
y= 30.69
z=-127.00
SERVER  SHOWS
a=
b=
c=
d=0
e=-127.00
i can not find out exact problem.
PaulS
Quote
You seem incapable of printing the string that you send to the modem to the Serial Monitor app. I really have to wonder why.
It is nearly impossible to fit a 6 character minimum string in a 6 element array and still have room for the terminating NULL. I suspect that you are writing over memory you don't own.
Personally, I'd be concerned about that INF that is printing. Surely you don't expect to put "INF" in a column that expects a float, do you?
Fazlul_karim
thanks all of you .
finally i come out successfully having completing this critical/easy task,sending five variable data to web server.
