Topic: Esplora Morse Code Encoder/Decoder (Read 28115 times) previous topic - next topic
roundhouselabs
Hello,
  I've been looking for a good platform for using an Arduino to both encode/decode between standard text and morse.  After trying out various buzzers/buttons/shields/boards etc...  it dawned on me that an Arduino Esplora with TFT screen would be the perfect standalone morse trainer as it has a number of inputs, a buzzer, LED and TFT screen.  There seems to be no shortage of Arduino/Morse code sketches/libraries out there but its hard to know which is the most widely used, updated and compatible with the Esplora/EsploraTFT class.  Can anyone recommend a good morse code library that works on the Esplora?
  A little background-  I work at a history museum where they have a great old telegraph key for visitors to play with.  I though it would be great  if there was a way to connect the telegraph (or a replica) to something like twitter it could tap out tweets that were sent to a specific hashtag while also translating the tweet back into text displayed on a small tft screen.  Of course, this is just one idea, but the concept is to connect the 19th century medium to the present context.
  Any other ideas, questions and comments would be greatly appreciated.
michaelj6464
Hi, I am in a similar position at a an Indutrial Heritage Museum in Wales UK. I've tried a couple of Morse encode/decode programs/sketches, modified them and tried various things adn in the end decided that to radically simplify my approach. The reasons for this are:
1) The average person visiting the museum, with best will in the world, can't send morse with sufficiently precise spacings and mark/space ratios for a reliable decode. They will send, a dot then look up the next dot or dash on the accompanying table and so on. In the meantime the software has given up waiting.
2) Off air decode seemed a possibility. I got the software to decode machine generated morse OK. i.e. off computer so it was perfectly sent. I could decode reasonably off the air. The snag is that even if you do decode Amateur transmissions off the air, they contain so many abbreviations and "Q" codes that yet another layer of interpretation is needed as they will not make sense to the average visitor.
3) Commercial or military morse is rarely if ever used now, if you do find some it is likely to be abbreviated and probably encrypted. Finally, there willl be copyright issues to contend with.
I decided instead to provide a practice key for people to try their hand and also to program some stock messages in the arduino that could be "sent" and decoded. That way visitors can hear authentic morse and see the decode coming in at the same time. There are some other functions to be included to do with maritime distress calls, but that's another issue. All this will be up and running for the next season starting next Easter (2017).
Hope this helps - Michael.
