_digitalWrite would be the current slow function.
If modify the macro as follows you can run the code by calling fastWrite in your sketch.
if the pin and value are both constants, a single op code is used, if pin or port are variables then the exisitng slow digitalWrite is called.
#define fastWrite(P, V) \
if (__builtin_constant_p(P) && __builtin_constant_p(V)) { \
if (digitalPinToTimer(P)) \
bitClear(*digitalPinToTimer(P), digitalPinToTimerBit(P)); \
bitWrite(*digitalPinToPortReg(P), digitalPinToBit(P), (V)); \
} else { \
digitalWrite((P), (V)); \
I think paul's macro assumed that the implimentation of the current digitalWrite would be renamed to _digitalWrite
