Topic: save data from Arduino in CSV file, Processing (Read 4147 times) previous topic - next topic
vicas
Dear , I am new here and arduino I need save data from Arduino to csv. file. How I make csv file from code below
int sensorPin = A0;    // analog input pin to hook the sensor to
int sensorValue = 0;  // variable to store the value coming from the sensor
float val=0.0;
  Serial.begin(9600); // initialize serial communications
    sensorValue = analogRead(sensorPin) ;
    val=sensorValue*(5/1023);
  Serial.println(val);
  delay(10);
that is simple code for measure voltage from analog input. How I can make csv in Processing? Thanks
PaulS
Quote
You don't. The Arduino has no place to store a file, regardless of what format the data is in, or what extension you want to use.
Quote
Processing comes with lots of examples, just like the Arduino IDE. Processing comes with a forum, too, just like here.
They don't much like Arduino questions there. We don't much like Processing questions here, either, unless they are specifically about how to get data to or from Processing.
vicas
How I can save data from arduino code in csv file on example Excel?
PaulS
Using Processing? Did you not understand that that is a Processing question, for the Processing forum?
Did you not understand that the Processing folks provided you with examples that read from and write to files. Did you even look at any of them?
f41_ardu
float val=0.0;
  delay(10);
look i.e. at this link https://forum.processing.org/two/discussion/879/saving-arduino-data-with-processing
This may help you.
f41_ardu
NetDevil
Hi vicas,
the tool PLX DAQ runs in Excel and captures all information from the serial port and lists it in a worksheet.
This worksheet can afterwards be saves as a CSV or you can create graphs etc there directly.
PLX DAQ can be found for example here: http://forum.arduino.cc/index.php?topic=437398.0
A tutorial for PLX DAQ (which is really really easy to use) can be found here (http://robottini.altervista.org/arduino-and-real-time-charts-in-excel) or many times on Youtube.
Good luck
JSchiltz19
A super simple way to record data is by using these Processing and Arduino Programs.
They send data using markers to tell Processing when the transmission is starting and ending and are quite easy to use.
