Topic: Unusual serial data from RFID reader (Read 2561 times) previous topic - next topic
zenwebb
I've hooked up a Parallax RFID to an Arduino and got things working great; capturing tag information and retransmitting it via serial to my PC for output.
However when I do a println of the tag I get 10 characters plus another character, which is always Å. I'm not sure if this denotes carriage return or not (doesn't show up on other lines).
I am using these RFID cards from Trossen Robotics which are noted as having 64 bits of EEPROM capacity. Does this mean I should be looking for 64 bit IDs instead of 10 bit IDs?
Hopefully this makes some sense to you guys :P
Creative technologist + OSHW engineer + lover of learning interested in bio+art+tech, form and digital fabrication
Groove
So, print the values in HEX, rather than ASCII - that'll tell you what the character is.
Per Arduino ad Astra
programmer
The cards output 64 bits in the following order:
9 x 1 bit (to signal start of data)
10 bits - customer id (of which the 5th and 10th bit are parity check)
40 bits - user data (of which every 5th bit is parity check)
4 bits - column parity check
1 stop bit
= 64 bits
When you strip off the parity info and start and end markers, you are left with:
customer id: 8 bits
customer data: 32 bits
In hex you'll get something like:
customer id: 22
customer data: 00 06 8E 4D
Have a look at the EM4102 datasheet at:
http://www.emmicroelectronic.com/webfiles/Product/RFID/DS/EM4102_DS.pdf
zenwebb
@Groove: I just tried to do that, but was given an error. I am storing the tag values into an array of chars (char*[]) and when I try to output the tag in HEX the compiler says that it cannot convert char* to long int.
@programmer: The data sheet should help. Weird that they have 9 header bits, looks like I'll need to do a bit more work to read in the tag.
The RFID reader says that it only outputs 8 bits per packet; is this something I need to account for in my program?
Groove
So, print them one-by-one, in a loop.
You can't print arrays in a single print statement, except for char arrays with a NULL terminator.
doghousedean
This will help me with my LCD screen problems thank you
zenwebb
Looking better now. I am able to get sufficiently unique IDs that look more like this:
32373030333932384633
when printed in HEX that is. My code throws out the header bits, so the fact that there are 9 of them is inconsequential. I really should know the answer to this, but I see there are two actual numbers per bit resulting in 20 characters per ID.
programmer
I`m not sure, as I don't know how the Parallax reader spits out data (i`ve only worked with the raw signal data), but I would imagine that those id's you're getting are hex ascii codes
so
would become:
32 = 2
37 = 7
30 = 0
30 = 0
33 = 3
39 = 9
32 = 2
38 = 8
46 = F
33 = 3
Giving:
Customer ID: 27
Customer Data: 003928F3
That would give the 10 bytes, and looks like it could be a valid tag
code
zenwebb
Yeah, I'm definitely confused, lol. I understand the differences between hex, decimal and binary but I suppose haven't seen a practical application of it before.
Like I mentioned when I pass different tags I seem to get sufficiently unique ID codes from them so I can probably finish up my program with that in mind, but just for the sake of learning I'd like to know a little more about this.
I thought there were 8 binary bits in 1 byte which allows for 256 different characters. Hex bits can be 0-9 or A-F; how many hex chars are in 1 byte? 2?
The Parallax RFID datasheet has the following says the following: "All communication is 8 data bits, no parity, 1 stop bit ..." Not sure if this is handled internally by the Serial (I'm using SoftwareSerial) class, I'm guessing it is.
PaulS
There are 8 bits in a byte. Each bit is a 1 or 0. All 0's is 0. All 1's is 255.
A hex digit ranges from 0 to F (0 to 15 in decimal). That's 0000 to 1111 in binary, which, as you can see takes 4 bits. So, there are 2 hex values in a byte. That is, a byte can range from 0 to FF.
It is.
zenwebb
Hahaha. Nice succinct answer. Definitely makes sense now, thanks.
