Topic: Easy code question for an RFID reader..... (Read 1 time) previous topic - next topic
EM82987
Hello,
I have my arduino working fine and outputing a 5 byte code through the serial monitor using the code from...
http://www.arduino.cc/playground/Code/ID12
I would like to write an if statement, that will output for a particular card. Right now upon a card scanned through the com I'm getting "5-byte code: 21 00 72 B7 3F" as I should.
However, I'm looking to add to this code to actually identify cards with a series of if statements. For example, I would like to be able to code something like the following.
if "5-byte code: 21 00 72 B7 3F is read"
Serial.print("Card 1")
if "5-byte code: 21 00 34 J3 3G is read"
Searial.print("Card 2")
This way I'm identify cards in the serial monitor instead of getting a string.  I'm sure you get what I'm trying to get at. If anyone can think of a nice way to do this I appreciate any help.
Thanks in advance...
AWOL
Sounds like you need to look at something like "memcmp"
programmer
#2
Mar 08, 2010, 10:40 pm Last Edit: Mar 08, 2010, 10:41 pm by programmer Reason: 1
The string library at:
http://arduino.cc/en/Tutorial/TextString
may also be of use to you.
EM82987
Thanks for the prompt responses...
After looking around the forum for a while I think using the strcmp command function should work just fine. I have limited programming knowledge.
Could someone enlighten me on the correct way to go about doing this or why I am getting error: invalid conversion from 'byte*' to 'const char*'
I have only added the define tag and string comparison code.
char tag1[] = "210072B73F"; //define tag 1
 Serial.begin(9600);                                 // connect to the serial port
void loop () {
 byte i = 0;
 byte val = 0;
 byte code[6];
 byte checksum = 0;
 byte bytesread = 0;
 byte tempbyte = 0;
 if(Serial.available() > 0) {
   if((val = Serial.read()) == 2) {                  // check for header
     bytesread = 0;
     while (bytesread < 12) {                        // read 10 digit code + 2 digit checksum
       if( Serial.available() > 0) {
         val = Serial.read();
         if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) { // if header or stop bytes before the 10 digit reading
           break;                                    // stop reading
         // Do Ascii/Hex conversion:
         if ((val >= '0') && (val <= '9')) {
           val = val - '0';
         } else if ((val >= 'A') && (val <= 'F')) {
           val = 10 + val - 'A';
         // Every two hex-digits, add byte to code:
         if (bytesread & 1 == 1) {
           // make some space for this hex-digit by
           // shifting the previous hex-digit with 4 bits to the left:
           code[bytesread >> 1] = (val | (tempbyte << 4));
           if (bytesread >> 1 != 5) {                // If we're at the checksum byte,
             checksum ^= code[bytesread >> 1];       // Calculate the checksum... (XOR)
           tempbyte = val;                           // Store the first hex digit first...
         bytesread++;                                // ready to read next digit
     // Output to Serial:
     if(bytesread == 12) {         // if 12 digit read is complete
       if(strcmp(code, tag1) == 0) //compare tag1 to the tag read
         Serial.print("Tag 1");
    // if (bytesread == 12) {                          // if 12 digit read is complete
    //   Serial.print("5-byte code: ");
    //   for (i=0; i<5; i++) {
    //      if (code[i] < 16) Serial.print("0");
    //      Serial.print(code[i], HEX);
    //      Serial.print(" ");
       Serial.println();
       Serial.print("Checksum: ");
       Serial.print(code[5], HEX);
       Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
       Serial.println();
     bytesread = 0;
Coding Badly
Nope.  Won't work.  There are "embedded nulls" in the ID.  strcmp will stop comparing when it reaches them.
AWOL's advice is sound.  memcmp is what you need to use.
