Topic: digitalRead same pin, same loop = crash? (Read 2189 times) previous topic - next topic
xerof
I've an arduino yun Shield (Genuino Yun Shield) connected to my MEGA 2560 and having issues with it crashing with certain code.
Sometimes, the connected device on deviceStatePin flickers (It's opto-isolated) so drives the INPUT LOW (on) then within a few MS drives it back HIGH (off) so I need a way of debouncing. I thought the second method should of worked fine but it fails and just starts all over again @ "Ready..." (It fails straight after the final SendMessage)
Runs fine:
Code: [Select]
  pinMode(deviceStatePin, INPUT);
  Serial3.println("Ready...");
int deviceStatePin   = 22;
boolean deviceStatus = false; /* false = OFF | true = ON */
int lastDeviceState  = 1;
int deviceState      = 1;
  deviceState = digitalRead(deviceStatePin);
  checkDeviceState();
  lastDeviceState = deviceState;
void checkDeviceState()
  if (deviceState != lastDeviceState) {
    if (deviceState == HIGH)
      Serial3.println("Device powered Down");
      canLog = false;
      client.stop();
      Serial3.println("Device powered Up");
      deviceStatus = true;
      Serial3.println("Waiting...");
      fileTimestamp = getTimeStamp();
      dataFileName = "/mnt/sda1/xxxxxxx/logs/" + fileTimestamp + ".txt";
      dataFileName.toCharArray(c_dataFileName, 45);
      delay(3000); /* Give device chance to warm up */
      Serial3.println("Ready to send clear data");
      SendMessage((char*)""); /* Clear data */
FAILS (Basically restarts again):
Code: [Select]
  checkDeviceState();
      canLog = false;
      client.stop();
      delay(1000); /* Allow to see if it's flickering */
      deviceState = digitalRead(deviceStatePin); /* Reset deviceState encase it's fallen HIGH again */
        Serial3.println("Flickered");
