Topic: ArtNet to WS2812 Pixel LED driver : Using Wemos D1 (arduino-esp8266) (Read 25158 times) previous topic - next topic
mcnobby
A standard UNO and an Ethernet Shield could probably get you 2 universes (340 pixels), the main limitation is ram as you need to have 3bytes per RGB Pixel, but it can be done
If you are looking at doing more than this then you might need to be looking at an Arduino Mega as it has alot more ram than an UNO
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
w31x
hello bob,
first of all thanx for the great job. I've been playing with my D1 mini for a while and now I have 4 universes on one pin (680 pixels). Now I want to supply another pin with the next 4 universes ->  some non-round effects such as green flickers arise on some places and the animation is not as smoothly.
So how do I get more than the 680 pixels on one controller?
Can you please give me a hint ...Thank you!
Code: [Select]
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#define WSout1 D1
#define WSout2 D1
#define WSout3 D1
#define WSout4 D1
#define WSout5 D1
#define WSbit1 (1<<WSout1)
#define WSbit2 (1<<WSout2)
#define WSbit3 (1<<WSout3)
#define WSbit4 (1<<WSout4)
#define WSbit5 (1<<WSout5)
// ARTNET CODES
#define ARTNET_DATA 0x50
#define ARTNET_POLL 0x20
#define ARTNET_POLL_REPLY 0x21
#define ARTNET_PORT 6454
#define ARTNET_HEADER 17
WiFiUDP udp;
//universe 0
uint8_t uniData1[510];
uint8_t universe1 = 0;
uint16_t uniSize1;
//universe 1
uint8_t uniData2[510];
uint8_t universe2 = 1;
uint16_t uniSize2;
//universe 3
uint8_t uniData3[510];
uint8_t universe3 = 2;
uint16_t uniSize3;
//universe 4
uint8_t uniData4[510];
uint8_t universe4 = 3;
uint16_t uniSize4;
//universe 5
uint8_t uniData5[510];
uint8_t universe5 = 4;
uint16_t uniSize5;
uint8_t hData[ARTNET_HEADER + 1];
uint8_t net = 0;
uint8_t subnet = 0;
const char* ssid     = "----";
const char* password = "----";
IPAddress local_ip(172, 20, 10, 10);
IPAddress gateway_ip(172, 20, 10, 1);
IPAddress subnet_ip(255, 255, 255, 240);
  delay(10);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  WiFi.config(local_ip, gateway_ip, subnet_ip);
    Serial.print(".");
  udp.begin(ARTNET_PORT); // Open ArtNet port
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  pinMode(WSout1, OUTPUT);
  pinMode(WSout2, OUTPUT);
  pinMode(WSout3, OUTPUT);
  pinMode(WSout4, OUTPUT);
  pinMode(WSout5, OUTPUT);
void sendWS1() {
  uint32_t writeBits;
  uint8_t  bitMask, time;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize1; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      // time=0ns : start by setting bit on
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit1 );  // do ON bits // T=0
      if ( uniData1[t] & bitMask ) {
        writeBits = 0;  // if this is a '1' keep the on time on for longer, so dont write an off bit
      else {
        writeBits = WSbit1;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, writeBits );  // do OFF bits // T='0' time 350ns
      time = 6;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit1 );  // switch all bits off  T='1' time 700ns
      // end of bite write time=1250ns
      bitMask >>= 1;
  os_intr_unlock();
void sendWS2() {
  uint32_t writeBits;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize2; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit2 );  // do ON bits // T=0
      if ( uniData2[t] & bitMask ) {
      else {
        writeBits = WSbit2;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
      time = 6;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit2 );  // switch all bits off  T='1' time 700ns
      bitMask >>= 1;
  os_intr_unlock();
void sendWS3() {
  uint32_t writeBits;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize3; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit3 );  // do ON bits // T=0
      if ( uniData3[t] & bitMask ) {
      else {
        writeBits = WSbit3;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
      time = 6;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit3 );  // switch all bits off  T='1' time 700ns
      bitMask >>= 1;
  os_intr_unlock();
void sendWS4() {
  uint32_t writeBits;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize4; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit4 );  // do ON bits // T=0
      if ( uniData4[t] & bitMask ) {
      else {
        writeBits = WSbit4;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
      time = 6;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit4 );  // switch all bits off  T='1' time 700ns
      bitMask >>= 1;
  os_intr_unlock();
void sendWS5() {
  uint32_t writeBits;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize5; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit5 );  // do ON bits // T=0
      if ( uniData5[t] & bitMask ) {
      else {
        writeBits = WSbit5;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
      time = 6;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit5 );  // switch all bits off  T='1' time 700ns
      bitMask >>= 1;
  os_intr_unlock();
  if (udp.parsePacket()) {
    udp.read(hData, ARTNET_HEADER + 1);
    if ( hData[0] == 'A' && hData[1] == 'r' && hData[2] == 't' && hData[3] == '-' && hData[4] == 'N' && hData[5] == 'e' && hData[6] == 't') {
      if ( hData[8] == 0x00 && hData[9] == ARTNET_DATA && hData[15] == net ) {
        if ( hData[14] == (subnet << 4) + universe1 ) { // UNIVERSE One
          if (!uniSize1) {
            uniSize1 = (hData[16] << 8) + (hData[17]);
          udp.read(uniData1, uniSize1);
        if ( hData[14] == (subnet << 4) + universe2 ) { // UNIVERSE two
          if (!uniSize2) {
            uniSize2 = (hData[16] << 8) + (hData[17]);
          udp.read(uniData2, uniSize2);
        if ( hData[14] == (subnet << 4) + universe3 ) { // UNIVERSE drei
          if (!uniSize3) {
            uniSize3 = (hData[16] << 8) + (hData[17]);
          udp.read(uniData3, uniSize3);
        if ( hData[14] == (subnet << 4) + universe4 ) { // UNIVERSE vier
          if (!uniSize4) {
            uniSize4 = (hData[16] << 8) + (hData[17]);
          udp.read(uniData4, uniSize4);
          if ( hData[14] == (subnet << 4) + universe5 ) { // UNIVERSE fünf
          if (!uniSize5) {
            uniSize5 = (hData[16] << 8) + (hData[17]);
          udp.read(uniData5, uniSize5); */
          sendWS1();
          sendWS2();
          sendWS3();
          sendWS4();
          //sendWS5();
      } // if Artnet Data
Nikolov
hey @w31x
is the code you posted the working one with 4 universes on one pin?
which software do you use to controll the pixels?
w31x
@nikolov: Yes its the one for 4 universes
I donnt know a lot how to handle more universes than 4 on one controller and if nobody can help me with that ... now i built 4 controllers with each 4 universes and one accesspoint to drive jinx on 2048 pixels.
The next problem i got is, if i connect to the accespoint, only 2 or 3 controllers connect and the datatransfer works ... sometimes i have to do a reset with all 4 controllers and sometimes they connect all and the show works absolutely perfect.. but sometimes only a few connect.
The AP is very close to the controllers and yes they all have no ceramic antennas but sometimes i got a good connection and all works as it should!!! I also tryed an 8266 accesspoint with worser results...so i think the problem cannt be only the Wifi router..
If nobody can help me to run more universes on one controller, it would be great if at least someone can help me out here.
DavidAutomacao
Hello Edison, how can I get your Artnet code 32 universe thanks
w31x
why does it only work with an special WiFi AP?
i made an Access-point with an ESP07 and ESP12 with b,g,n but the result is that it stucks and jerks and there is no smoothness anymore..
i tried an old WiFi AP with 11Mbit (b) 54Mbit(g) and 150Mbit(n) but it works only on (b) ?!
can someone explain this?
Joshi32
Hello,
as ESP8266 do not like to disable interrupts as this lead to unintention resets or other strange behavior, unstable running, flicker, packedloss, connection loss, flicker etc.
The code in this post uses a bitbang method for sending data to pixels.
The ESP8266 has an I2S interface and DMA engine so it is possible to send out data in hardware without disabling interrupts. The hardware control the data flow to the LEDs and the CPU could receive WLAN packets.
So I was confusing nobody has mentioned it or maybe it is just to confuse someone? Or is it just to advertise ;)?
ColF
ey mcnobby
for a long I tried to rund 2 universes on my esp8266 (NodeMCU 1.0) for my 20*10 matrix but no succes. :(
I tried nearly everthing, but it didn´t work. Might you be so friendly and send an example code for 2 universes?
thx. ;)
psander247
Hey
i tried the Code from the first post on my NodeMCU (ESP8266)
Sadly i have a few problems.
1. The strip is flickering randomly when sending data from jinx
2. The controller doesn´t connect to wifi network if it is not connected to a pc. Tried it with different 5V power supplys
Can anybody help me?
Moohr
To start thank you @mcnobby for the hard work this is amazing really would like to see more of your code or beeing able to try It !
@w31x I tried you code and I can't get the first three univers to be read, only get the 4th one. Tried to disable sendWS2();, sendWS3(); and sendWS4(); but can't even show sendWS1();
I am trying to figure out what is wrong but I'm not a code expert so make take time ^^ if you have any idea of what is going on please let me know ;)
hello bob,
@psander247 did you connect the led strip to the GND of the NodeMCU ? Sheck any bad soldering on pins. Got mine working straight away
psander247
Yeah,
now it works.
GND NodeMCU->WS2812 was not connected properly  :smiley-confuse:
Should have checked this before :D
I´m working with the 160mhz. Only the 1 pixel flickering (green) is left now.
greetings
ColF
May anyone send my a working code for atb least 2 universes? I just can not manage changing the code right.The LEDs out of the first universe are white and do not response.
Please :smiley-confuse:
arduiflex
hello w31x, I test your code, but I have the same problem like MOOHR,
what is the mistake ?
makethingsdothings
@mcnobby, or anybody else with a good answer ;-)
I've been playing around with 4 ledstrips of 5 meters each, which is 1200 leds in total. I can manage to out a single universe to each ledstrip and address it as such in varuous light programs. Unfortunatly each ledstrips requires 2 univeres (little under but let's stick to 2) so logically i would like to have 2 universes on each pin. That, i somehow can't seem to realize. I've posted my code below so you can see how far I got. Any further pointer as where i need to change it so it puts out the universes nicely behnd each other.
Or which is another option, i am doing something wrong in assigning them in the lightning software.
I've tried:
- playing with the time = in the WS loops,
- changing the 510 size of each odd universe on the same pin to it's actual size (390)
- switching ledstrips ;-)
I was wondering if am missing a step in the code where it actualy add the odd universe to the same pin but i figured the software would do that. or maybe combine the WSloops for universes 0-1, 2-3,4-5 and 6-7.
Code: [Select]
#define WSout1 D1
#define WSout2 D1
#define WSout7 D4
#define WSout8 D4
#define WSbit7 (1<<WSout7)
#define WSbit8 (1<<WSout8)
// ARTNET CODES
WiFiUDP udp;
//universe 0
uint16_t uniSize1;
//universe 1
uint16_t uniSize2;
//universe 7
uint8_t uniData7[510];
uint8_t universe7 = 6;
uint16_t uniSize7;
//universe 8
uint8_t uniData8[510];
uint8_t universe8 = 7;
uint16_t uniSize8;
uint8_t net = 0;
uint8_t subnet = 0;
const char* ssid     = "";
const char* password = "";
const char station[] = "";
  // Led for connection, led on = no connection to wcorrect wifi network
  pinMode(D0, OUTPUT);
  digitalWrite(D0, HIGH);
  WiFi.mode(WIFI_OFF);        //Prevents reconnection issue (taking too long to connect)
  WiFi.mode(WIFI_STA);        //This line hides the viewing of ESP as wifi hotspot
  WiFi.hostname(station);
  WiFi.begin(ssid, password);     //Connect to your WiFi router
  Serial.print("Connecting");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print(" as ");
  Serial.println(station);
  if (WiFi.SSID() == ssid) {
    digitalWrite(D0, LOW);
    Serial.println("Correct SSID WiFi connected");
  else {
    while(1) {
      Serial.println("Incorrect SSID WiFi connected");
      delay(600);
  pinMode(WSout7, OUTPUT);
  pinMode(WSout8, OUTPUT);
void sendWS1() {
  uint32_t writeBits;
  os_intr_lock();
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
      else {
      time = 4;
      while (time--) {
      time = 4;
      while (time--) {
      bitMask >>= 1;
  os_intr_unlock();
void sendWS2() {
  uint32_t writeBits;
  os_intr_lock();
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
      else {
      time = 4;
      while (time--) {
      time = 4;
      while (time--) {
      bitMask >>= 1;
  os_intr_unlock();
void sendWS3() {
  uint32_t writeBits;
  os_intr_lock();
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
      else {
      time = 4;
      while (time--) {
      time = 4;
      while (time--) {
      bitMask >>= 1;
  os_intr_unlock();
................ removed the others due to caharacter limit
void sendWS8() {
  uint32_t writeBits;
  os_intr_lock();
  for (uint16_t t = 0; t < uniSize8; t++) { // outer loop counting bytes
    bitMask = 0x80;
    while (bitMask) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000304, WSbit8 );  // do ON bits // T=0
      if ( uniData8[t] & bitMask ) {
      else {
        writeBits = WSbit8;  // else it must be a zero, so write the off bit !
      time = 4;
      while (time--) {
      time = 4;
      while (time--) {
        WRITE_PERI_REG( 0x60000308, WSbit8 );  // switch all bits off  T='1' time 700ns
      bitMask >>= 1;
  os_intr_unlock();
    // if ( hData[0] == 'A' && hData[1] == 'r' && hData[2] == 't' && hData[3] == '-' && hData[4] == 'N' && hData[5] == 'e' && hData[6] == 't') {
        Serial.println("Got uni 1");
        if (!uniSize1) {
        sendWS1();
      Serial.println("Got uni 2");
        if (!uniSize2) {
         sendWS2();
        Serial.println("Got uni 3");
        if (!uniSize3) {
        sendWS3();
      if ( hData[14] == (subnet << 4) + universe8 ) { // UNIVERSE vier
       Serial.println("Got uni 8");
        if (!uniSize8) {
          uniSize8 = (hData[16] << 8) + (hData[17]);
        udp.read(uniData8, uniSize8);
          sendWS8();
    } // if Artnet Data
Any hints would be much appreciated,
J
karthikx10
@mcnobby
Thank you for the great efficient code you have developed.
I am trying to run a ~2000 Pixel Setup with 1 strip = 50 pixels.
the matrix is 50(Height) x 40(Length).
Im new to this DMX and Artnet but not new to ESP/Arduino.
So how should I proceed to set up? How many universes, pins i need to use? and how can i ensure all leds are used in the strip without leaving out few when a universe fills up partially a strip and split over multiple pins?
I have tested with one strip and its working fine, need to buy more...
Can I power these leds serially, 5v+5v=10v over a 12v output psu? or during when a other 5v leds are off the voltage will rise to 12v and damage the leds?
