Topic: Push button problem again (Read 1 time) previous topic - next topic
SK_21
Ok guys....I feel like giving up on this problem.I have modified this code a million times and still dont get the required result.Please help me :(
#include <Bounce.h>
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = LOW;         // current state of the button
int lastButtonState = LOW;     // Previous state of the button
unsigned long pressed_time = 0;
Bounce bouncer = Bounce (buttonPin,40);
 pinMode(buttonPin, INPUT);
 pinMode(ledPin, OUTPUT);
 digitalWrite(buttonPin, HIGH);
 bouncer.update();
 int buttonState = bouncer.read();
if (buttonState != lastButtonState) {
   if (buttonState == HIGH) {
     ++buttonPushCounter;
     digitalWrite(ledPin,HIGH);
     pressed_time=millis();
   else{
     digitalWrite(ledPin, LOW);
   lastButtonState = buttonState;
 if (buttonPushCounter % 2==0 ) {
     if (millis() - pressed_time <= 400) {
       digitalWrite(ledPin, HIGH);
       Serial.println("Event Occured");
   else {
     buttonPushCounter=0;
    pressed_time=0;
I am trying to print "Event Occurred" after two successive button presses.(Which  this code does)
But the time elapsed between two button pushes should not be greater than 400milliseconds. ( which i have been unable to achieve even after several troubleshooting sessions :( )
DeepZ
Hi.
Just my 2 cents worth.
You have a line :
Why would you write to this pin, you just defined it as a INPUT?
Also, there are 2 lines :
This will make things very confusing. I am sure the first line should be deleted, as you use the Bounce class.
Also, are you sure you are pressing/releasing/pressing the button inside 400 ms? As your code will only trigger if it sees HIGH - LOW - HIGH, within 400 ms?
For debugging, i would insert a line to print the time difference, probably after the line : if (buttonPushCounter % 2==0 ) {
, something like :
unsigned long delta = millis() - pressed_time;
Serial.println(delta,DEC);
Hope this helps,
Guido
SK_21
Hi Guido,
Thanks so much for your advice.I think I somehow uncommented the lines you are talking about while pasting the code in here.
During troubleshooting I was adding and deleting stuff from this code and these lines are some of the residual test code that are now commented.
Also I did try printing the millis() - pressed_time and was mostly getting a 0 and sometimes a 2 or 3.
My code triggers even if the second button press was after a few seconds of the first one.So I think its recognizing the HIGH-LOW-HIGH transition irrespective of the time....which is basically my problem and am trying to figure out how to solve it.
PaulS
This is really a simple task. The last code you posted has multiple methods of reading the same data (the state of the button). Then, you say that you've commented some of that out.
Why don't you post what you are actually running?
SK_21
#include <Bounce.h>
 bouncer.update();
   else{
   else {
    pressed_time=0;
Here's the code.
digimike
@ DeepZ,
having digitalWrite(buttonpin,HIGH); like that in setup enables the built in pull up resistor on current arduino boards. Thus eliminating the need for a pull down restistor on the hardware side.
PaulS
If you are using the Bounce library, you should not also be directly reading the button state.
Local and global variables with the same name are also not a good idea.
