Topic: Help needed to convert some code. (Read 7313 times) previous topic - next topic
flapjackboy
OK, a bit of background here. A few years ago, I bought a Velleman K8055 USB interface board and whilst tinkering with it, I developed a rather nice quiz buzzer program for it.
Fast forward to today and I start hearing about Arduino, so I order a Duemilanove to tinker with, hoping to convert my quiz buzzer program over to it, thinking that it shouldn't be too hard...
Well, it turned out to be more difficult than I thought and I could use a little help from the community with it.
Here's the original code:
#include <stdio.h>
#include <iostream>
#include "K8055D_C.h"
#include "resource.h"
#include "conio.h"
#include <cstdlib>
#include "windows.h"
using namespace std;
void CheckInputs(bool screen = true);   // passes a true value to screen
                                       // and sets CheckInputs to perform
bool inputflag = false;                 // the initial input error check
bool exitflag = false;
int x;
int main()
     // open communication with K8055D
     OpenDevice(0);
     // check for sticky inputs
     CheckInputs();
     cout << "Initial Check Complete" << endl;
     cout << "Enter number of questions: ";
     cin >> x;
     cout << "Press any key to continue...";
     _getch();
     system("CLS");
     for (int i = 0; i < x; i++)
       // cout << i; // used for testing purposes
         do
               CheckInputs(false);
               if (ReadDigitalChannel(5))
                     ClearAllDigital();
                     system("CLS");
                     inputflag = false;
                     exitflag = true; // get out of do...while loop
         } while (exitflag == false); // loop while button 5 is not depressed
         while (ReadDigitalChannel(5));
         exitflag = false;
     ClearAllDigital();
     cout << "Press any key to exit...";
     _getch();
     CloseDevice();
     return 0;
void CheckInputs(bool screen)
     for (int i = 1; i <= 5; i++)
           bool inputstatus = false;
           inputstatus = ReadDigitalChannel(i);
           if (inputstatus)
                 if (screen) // If at program start, check for stuck inputs
                       cout << "Input " << i << " depressed" << endl;
                       inputflag = true;   // Lock inputs 1-4
                       if (i != 5)         // If input 5 not pressed and
                             if (!inputflag) // if no inputs locked
                                   SetDigitalChannel(i); // Set corresponding output
                                   cout << "Contestant " << i << " buzzed!" << endl;
                                   PlaySound("buzzerheavy.wav", NULL, SND_ASYNC);
                             else;
                       else;
           else;
     if (!inputflag && screen)  // If program starts
                                              // with no stuck inputs
           cout << "No inputs depressed\n" << endl;
           ClearAllDigital();
     else;
     return;
GrooveFlotilla
That's the PC end of your program - you need to read about how to write sketches for the Arduino.
There are tutorials and examples over at the main Arduino site.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
flapjackboy
Yes, I am aware of this. I know that loop() and setup() take the place of main() and get compiled to main() in the final uploaded code.
My main sticking point seems to be that there's no function equivalent to the K8055's ClearAllDigital() in Arduino, but also general problems with syntax matching.
Essentially, CheckInputs() is a Swiss Army Knife routine that performs different functions depending on where in the program it is called and what data is passed to it.
During the initial program startup, it checks that all the inputs are clear, then shifts to detecting buzzer presses and locking out other players. Finally, it checks to see if the reset button has been pressed by the quizmaster.
GrooveFlotilla
I'm confused - are you aiming to run the Arduino as simply an I/O board, and handle the interface on the PC, or do you want to do it all on the Arduino, via the serial interface?
flapjackboy
#4
Apr 16, 2010, 10:40 am Last Edit: Apr 16, 2010, 10:43 am by flapjackboy Reason: 1
I want to run it all on the Arduino via the serial interface. Eventually, I want to make it self contained, using an LCD display to control everything, but for now I just need to get as close as possible to the original program as I can.
GrooveFlotilla
#5
Apr 16, 2010, 10:50 am Last Edit: Apr 16, 2010, 10:51 am by GrooveFlotilla Reason: 1
I don't know anything about this Velleman board, but you need to initialise a set of input pins and a corresponding set of output pins.
"ReadDigitalChannel" becomes "digitalRead", and "setDigitalChannel" becomes "digitalWrite".
There is no "clearAll" - you just loop through the pins and write them to whatever you want.
Work through some of the examples, and see how you get on.
PlaySound is going to be a problem, unless you have a sound shield.
flapjackboy
At the moment, playing a buzzer sound is not important.
One thing I did notice is that because you have to set up a constant for each input, something like this:
digitalRead (buttonPin(i));
won't work, unless I'm missing something blindingly obvious.
GrooveFlotilla
Assuming "buttonPin" is a function that returns an integer datatype, yes, that will work.
flapjackboy
#8
Apr 16, 2010, 12:29 pm Last Edit: Apr 16, 2010, 12:35 pm by flapjackboy Reason: 1
Except that I need to declare 5 input pins, so I would need to declare:
int buttonPin1 = 2;
int buttonPin2 = 3;
int buttonPin3 = 4;
int buttonPin4 = 5;
int buttonPin5 = 6;
Unless I can assign a variable to a single buttonPin declaration in order to step through the pins iteratively.
Essentially, what the K8055 ReadDigitalChannel() function does is scan the input bus for changes to a specific channel number, but you can scan multiple channels at once by feeding it a variable instead of a channel number and stepping through iteratively.
GrooveFlotilla
Yes, if you want you can have a single array of button pin numbers.
Have a look at the tutorials and examples.
flapjackboy
#10
Apr 16, 2010, 12:42 pm Last Edit: Apr 16, 2010, 12:43 pm by flapjackboy Reason: 1
Ah, so if I use:
int buttonPins[] = {2, 3, 4, 5, 6};
I can use that to step iteratively through the input scanning routine?
GrooveFlotilla
I'd prefer to see
const int buttonPins[] = {2, 3, 4, 5, 6};
but yes, that will work.
flapjackboy
#12
Apr 16, 2010, 01:26 pm Last Edit: Apr 16, 2010, 03:55 pm by flapjackboy Reason: 1
So, CheckInputs would be:
void CheckInputs (boolean screen)
 int i;
 for (i = 2; i <=6; i++)
   boolean inputstatus = false;
   inputstatus = digitalRead(buttonPins[i]);
   if (inputstatus)
     Serial.println("Input " i " depressed");
     inputflag = true;
     if (i != 6)
       if (!inputflag)
         Serial.println("Contestant " i-1 " buzzed!");
         inputflag = true;
       else;
     else;
 else;
   Serial.println("No inputs depressed");
 else;
 return;
PaulS
Not every if statement needs an else. If the else is not doing anything, get rid of it.
The else; look like errors. At least, errors waiting to happen.
GrooveFlotilla
#14
Apr 16, 2010, 01:44 pm Last Edit: Apr 16, 2010, 01:46 pm by GrooveFlotilla Reason: 1
digitalRead(buttonPins[glow][[/glow]i[glow]][/glow]);
It's an array, not a function.
Not much point initiailising the flag, if you're going to overwrite it:
boolean inputstatus = digitalRead(buttonPins[i]);
Also, be careful, C subscripts normally start from zero.
