Topic: Good Dispay ePaper for Arduino (Read 58750 times) previous topic - next topic
opendocumentary
Hi Jean-Marc,
thanks, yes that fixed the problem! I was checking the code but also missed that bit.
Don't worry about refresh time. For me it is working now good enough!
Thanks for your help!
If you could just make a "quick & dirty" example for MultiDisplay that would also be fine with me :)
Cheers,
Christian
ZinggJM
Hi Christian,
I have added the example GxEPD2_MultiDisplayExample to the library GxEPD2, declared as "preliminary".
I have tested it with the 4 uncommented displays on Wemos LOLIN32, compiled on my development notebook, not yet tested on my other notebook with actual ESP32 package.
The version of the library has not changed, as the fixes are still pending; black boarder issue needs additional investigation.
Jean-Marc
No personal message please; any question may be useful for other users. Use code tags for code. Make links clickable with URL tags. Provide links to the product in question.
ZinggJM
GxEPD2 version 1.0.3 available with fixes for GxEPD2_SD_Example.
This version also adds the GxEPD2_MultiDisplayExample, an example that shows how to use multiple e-paper displays on one processor board with multiple instances of display classes. It also shows how to preserve IO pins by sharing RST and BUSY IO pins, in addition to the shared SPI pins. Each display needs its own CS pin.
Passing references or pointers to the display class instance is complicated by the fact that the template classes used in this version of the GxEPD2 library have no common base class (except Adafruit_GFX).
Jean-Marc
opendocumentary
Hi Jean-Marc,
THANKS ... now I know what I will do this weekend :)
Cheers,
Christian
ZinggJM
GxEPD2 Version 1.0.4 available with GxEPD2_GFX base class support.
Base class GxEPD2_GFX can be used to pass references or pointers to the display instance as parameter.
This avoids the need of using template functions when a display reference parameter is used.
GxEPD2_GFX_MultiDisplayExample uses GxEPD2_GFX reference parameter passing, can replace GxEPD2_MultiDisplayExample.
GxEPD2_MultiDisplayExample is kept as reference for template function use, and modified for ESP8266 template syntax issue. (GxEPD2_MultiDisplayExample kept as "abschreckendes Beispiel" for missing base class issue).
Jean-Marc
noelportugal
Hello,
Using GxEPD2 I always the following Serial print. Although useful to know whats happening, I would like to disable it (the debugging) at some point. Is there a flag for this?
Code: [Select]
_PowerOn : 100127
_Update_Full : 15404462
_PowerOff : 28955
Thanks
ZinggJM
Hi
The actual version has an init() parameter for this. I think it should work.
Code: [Select]
void init(uint32_t serial_diag_bitrate = 0) // = 0 : disabled
noelportugal
Yeah, that did it! thanks again. Soon I'll share here what have I been working on  8)
WegzZ
Hi,Jean-Marc Zingg
I hope a beautiful day for you,
Yesterday I ordered 5.83 inch GoodDisplay with serial of : GDEW058Z21 and used it with the ESP32 but unfortunately the library you made is supporting the B&W version :
//#include <GxGDEW0583T7/GxGDEW0583T7.cpp>    // 5.83" b/w
could you tell me what to do ? I really want to use the red Color.
Thanks in Advance,
WegzZ
Hi Jean Marc,
I have Purchased the GoodDisplay 5.83 inch GDEW058Z21 and found no supporting library for it since It's 3 Colors  and You only support //#include <GxGDEW0583T7/GxGDEW0583T7.cpp>    // 5.83" b/w
which is black and white version
Do you have any Ideas what should I do ?
Thanks for Helping,
ZinggJM
Hi WegzZ,
Try to use it with library GxEPD2, where it is supported, but untested. It has a very long refresh time ~30s.
WegzZ
Hi,Jean-Marc Zingg
Thanks in Advance,
ZinggJM
Hi,Jean-Marc Zingg
Thanks in Advance,
GxEPD2, GxEPD2_583c.h and post #100
djerred
I am wondering if the 1.43 in flexible display made by good display would be a candidate for being added to one of the above libraries. I would like to incorporate this into a project but I am unsure of the difficulty that is required to control it. From my research it looks this product is fundamentally different than the other displays supported in the GxEPD libraries. Has anyone had any experience with using these displays?
ZinggJM
The Good Display SPI e-paper displays came into the reach of Arduino hobby users, when Good Display decided to sell the DESTM32-S2 adapter board of their DESTM32-S1 evaluation board separately (as I had suggested to them). Then came Waveshare with their SPI e-paper display boards, which made these displays easy to use.
For the mentioned 1.43 flexible display an adapter board with controller would be needed, and a demo code example to start with. If this combination could be a candidate for GxEPD or GxEPD2 is unknown; I don't expect. It might be better usable with a dedicated library or driver class.
Jean-Marc
