Topic: PLX-DAQ version 2 - now with 64 bit support! (and further new features) (Read 125167 times) previous topic - next topic
NetDevil
Nov 24, 2016, 01:51 am Last Edit: May 14, 2017, 10:29 pm by NetDevil Reason: Update due to new version available
Most recent version 2.11 to be found here:
http://forum.arduino.cc/index.php?topic=437398.msg3251256#msg3251256
Download specific versions directly:
v2.0 - v2.2 - v2.3 - v2.4 - v2.5 - v2.6 - v2.7 - v2.8 - v2.9 - v2.10 - v2.11
So well well well - here it is :-)
I have re-written the well know PLX-DAQ to be able to be run on modern Office suites.
What's new in "version 2:
  • Support for both Office versions 64 bit as well as Office 32 bit
  • No more installation needed! All within the workbook
  • I got rid of the selmaDAQ_Ver2.ocx and use API calls now
  • Fully compatible to all previous PLX-DAQ commands in your code!
  • Got rid of some old stuff like "Max row size of 65000" (Office limit is 1048576 rows with 64 bit) or Baud rate only up to 128000 (now supports 230400 and 250000 as well)
  • Added a direct debugging window for better testing as well as a VBA code module for testing and debugging
  • Setting for selecting where to post data (first most left sheet or currently active sheet)
  • Disabled the control boxes as Stamp object is no more in use
Tested the code on Windows 7 64bit with Office 2013 32 bit and Office 2013 64 bit - both are working fine.
I would appreciate if anyone could test it further on other operating systems (maybe Mac as well ;-) ) and Office versions and post feedback.
All source code is available within the Excel, no more closed DLLs ! :-)
Attached is a default sketch as well for you to test the new PLX DAQ if you want to.
Attached is of course the new Worksheet with the new Macro as well.
If you have questions please feel free to ask :-)
Well - it is nearly 2am in Germany right now ... this is going to be a short night ....
cYa !
Image-Link: http://www.freebie-base.de/Pics/PLX_DAQ_v2.png (hosted on my server, no traffic hijack)
(This is just for all google folks that are trying to get PLX DAQ "version 1" to run and have the "Stamp.disconnect" error - this new version will solve the issue!)
==> https://forum.arduino.cc/index.php?topic=437398.msg3013761#msg3013761 <==
This version (v2.00) is already outdated !! Link to always most recent version of PLX DAQ v2 above
NetDevil
ok so this was quick
I have not yet received one single feedback to version 2.0 and am already releasing version 2.2 ....
Sorry for kind of "double posting"
This version is already outdated !! Link to always most recent version of PLX DAQ v2 here:
What's new in "version 2.2" aka Change log:
  • Enhanced 64 bit support (even better stability now)
  • Added a dropdown box to select with sheet to post to (got rid of the radio buttons)
  • Minor adjustment for faster startup of logging
Code attached in zip file
Image-Link: http://www.freebie-base.de/Pics/PLX_DAQ_v2.2.png
P.S.: skipped release 2.1 for no reason I guess. Might have been a private development release  8)
el_supremo
Works just fine on Win 7 Pro x64 with Excel 2010. It does require that you allow the macro to run by changing the security level.
One minor problem I had was that it only seems to allow COM port numbers up to 15 and the Teensy I was using was COM30. But I switched to one on COM4 and all is well.
I don't have an immediate need for it but it's nice to have it here ready to roll.
Pete
Don't send me technical questions via Private Message.
Nick_Pyner
Congratulations and karma. I am not able to test this myself but a lot of users out there are going to appreciate this. I have published PLX notes and I will link to your breakthrough.
Further to COM ports, that is a problem I also have. My main laptop gets Arduino's bluetooth on COM 40 and I can't use PLX with it.
NetDevil
Hi there,
thanks a lot for the feedback.
I will try to enhance the COM port list. Performing some basic tests with virtual ports this morning I was not able to use any port greater then 9. Might be I find the time on Sunday to fix it.
Could you two give me some info how you managed to get that high Port number? So I can copy your setting and test.
el_supremo
The port numbers were assigned by the system but you can change an existing port.
Control Panel | Device Manager | Ports
Select the device you want to change and right click on it.
Select Port Settings and click on Advanced. The small drop down selector at the bottom of the dialog gives the current COM number and allows you to change it.
Pete
Nick_Pyner
NetDevil
Hey Pete,
all right thanks a lot. I found that information elsewhere on the internet as well but didn't think it was this simple to actually change it :-D Quick question: why are running your Arduino on such high ports then anyway? You don't actually have 39 further COM ports in use do you?
What so ever: I fixed the coding and it is now working with up to 256 ports. Actually port number and baud rate are free text fields now. Just for fun I tested with baud rate 1 (Serial.begin(1);) and 400.000 ==> both worked fine  8)
What's new in "version 2.3" aka Change log:
  • Port and baud rate not drop down box anymore but free text fields
  • Port number bug fixed thus ports > 10 can be used (max set to 256 as of modern Windows OS limit)
Image-Link: http://www.freebie-base.de/Pics/PLX_DAQ_v2.3.png
el_supremo
I don't know why it gets to such high COM port numbers. I use Teensys a lot and usually once a Teensy has been assigned a port, it will be that port whenever I plug it in again. But sometimes the system decides to change it and what used to be COM6 is now COM18. Same thing happened when I was using NANO, although not as much because I didn't have as many of them.
Occasionally, I open Device Manager, look at the list of COM ports, including the hidden ones that aren't currently plugged in, delete them all, reboot and then start plugging them in again to get lower COM port numbers.
Pete
el_supremo
It works with COM30 :)
For Teensy, and perhaps other processors, I added while(!Serial); after Serial.begin so that the code waits for the port to be opened before sending data to PLX-DAQ.
Pete
SASv
For the absolute noob, also state that before pressing the Connect button the user should close the arduino serial communications box.
NetDevil,what you did is absolutely great.  I will be using your spreadsheet in my research and in my teaching (I am a prof). Many many thanks.
larryd
Looks Interesting.
This is what I get, seems like the form is chopped (Using Microsoft Office 365), suggestions?
Edit:
Made this change all OK.  Works well on Microsoft Office 365.
frmStampDAQ.Width = 220
Changed to:
frmStampDAQ.Width = 480
No technical PMs.
The last thing you did is where you should start looking.
NetDevil
Hi LarryD,
well yeah - that does not look perfect ;-) What happens when you press the button for "Display direct debug =>" ? Is the window expanding?
larryd
Changed to:
Will be a good tool to add to our collection +1
Quote
Yes
No technical PMs.
NetDevil
But that way the direct debug window is shown on startup already. I wanted to keep it lightweight for starter users.
Is the button generally working with your office version? (should expand / collapse the debug window)
