Topic: PLX-DAQ version 2 - now with 64 bit support! (and further new features) (Read 113256 times) previous topic - next topic
NetDevil
Tried all PLX 2.x versions. After pressing CONNECT button, controller message says "Timer reset"..no any data in debug window.
Hi Dan,
duh tough question. Never heard of such an issue before. Can you post your code and a screenshot please?
"Timer reset" sounds at least like he is connecting to Arduino correctly. Is the baud rate adjusted as in your code?
By the way, The original Paralax PLX-DAQ (uploaded on Paralax website 2014) works fine with same Excel 2010 , on both win7/10.
Yeah as long as you stick with Office 32bit it will - regardless of your Windows installation. As soon as you upgrade to Office 64bit it won't work any further.
morrisx
Hello NetDevil,
I am simply trying to run the example AutoGrapher-RandomValue you have in the zip file with the version 2.11, but it crashes after maybe 70 rows. Is this normal? I followed the advice and have not moved or even clicked anything after clicking connect.
Excel kept crashing on my other program I have been trying for a few days to use, so I decided to go back to the basics and use some code you provided. It's not working either. I've got Windows 10, and Microsoft 365.
Dhanraj_Gupta
I am unable to download the new version. Every time the link is taking me to the same page after clicking.
Wosche
Hey guys.
I have a question to the PLX-DAQ Version 2
is there the possibility to transfer a decimal number to the Arduino program? just like 4.3 or so?
Currently I'm using the commands
Code: [Select]
  Serial.println("CELL,GET,FROMSHEET,Simple Data,G,5");   dac1_voltage = (float) Serial.readStringUntil(10).toFloat();
It seems tha PLX only sends the rounded number 4 instead of 4.3
I already have changed the decimal seperater to "." in Excel, but still.
NetDevil
Hi Dhanraj: this is more an forum issue. Have you tried rightclick and "Save as"?
Hi Wosche: I remember having the same issue. At least in the Beginners Guide I gave a recommendation to send Strings and Integers only. But I think I said that because sending Floats is just a bit tricky. What is your DirectDebugWindow showing? There should be a line for send information as well.
Changing the decimal delimiter to a point should help, otherwise the question is whether or not your dac1_voltage variable is declared as float?
In the end you could just increase the number by 10 (depends on your places after the decimal delimiter), thus send full integers, and divide by that in Arduino.... ugly but should work....
Wosche
Hi NetDevil Yeah my debug window shows that for example "4,3" is sent. And this is the Problem, because than it interprets it as two separated things.
My solution  to this issues on the Arduino side was, that I just save the sent data into a String, make a for-loop iterating over all of the fieldelements and than compare and replace the "," with "." and save  it in a float afterwards. :)
Maybe you have an more elegant solution to this, that doesn't need that much processing time, escpacially when someone has a lot of variables to transfer :)
But another question came to my mind. At the moment I'm just reading out a couple of cells in excel to the Arduino program. Is there a possibilty to read out TextBoxes of an Excel GUI for example?
I would have an ugly solution for this, So that that what I write into the GUI textboxes is written into cells, and the PLX-DAQ takes it from there, but is there a more direct solution for this?
And thanks a lot!
monamomeni
Hello,
Just wanted to ask if PLX-DAQ v2.11 is supported on Mac. I don't have a mac but the code I am working on is probably tested on a macbook.
Thank a lot for good work!
monamomeni
Hey,
I just tried to run DefaultSketch.ino on MKR1000 with Arduino IDE version 1.8.4, but every time I try to Connect and start logging, the UI kind of crashes and the excel shut down. It restarts and recovers the PLX-DAQ xlms file. I am on Windows 10, 64bits.
Will be very thankful if you have any idea.
Edit: I am using Office 365 ProPlus, so may be this is the reason. Can I install an older office and keep my own at the same time if Office 365 is not supported with PLX-DAQ?
Best regards,
Mona
atExcel
Hi net^devil,
thank you so much four your Excel-File. I just startet in electronics and programming my arduino. I was not happy with the serial monitor and plotter - now I should be able to work with my output data in Excel.
My question. Is it okay for you, if I publish some tutorials of your software at YouTube? I've got a German Excel YouTube-Channel www.youtube.com/athehos and would like to demonstrate PLX-DAQ.
Thanks a lot
Andreas
NetDevil
Duh, a lot to reply on :) let's give it a try!
@Wosche:
Yeah my debug window shows that for example "4,3" is sent. And this is the Problem, because than it interprets it as two separated things. (...) Maybe you have an more elegant solution to this, that doesn't need that much processing time
That shouldn't be the case. If it sends the string with a comma already you need to work on your delimiter in Excel. Maybe try using '=4.3 (make sure of the apostrophe) or format the cell as text and type 4.3. Since I don't have direct access to my Arduino dev IDE at the moment all I can say is that I once managed to make it send a point-separated float to the Arduino. It is possible :)
And thanks a lot!
No, there is currently no possibility. A maybe lightly less ugly workaround is to label the checkboxes and tick them to switch between values. Of course you can only story 4 values by that and your Arduino needs to know which box is what and interpret the checked/unchecked values (1/0) to the numbers again. Is ugly as well....
In case you are familiar with VBA (isn't that hard) you can adjust the code (insert a textbox, create a new command "GETCONTENTFROMTEXTBOX" and instead of reading the cell value read the text box value).
And: you're welcome :)
@Mona:
Neither do I, sorry :-/ just give it a try but I reckon since there is a lot of API calls it might fail. I guess a similar question has been asked in this thread as well once before  :smiley-confuse:
Office 365 is the web version, isn't it? That will surely have trouble to connect to all the APIs used.
Not sure about having to versions installed at the same time. It might work that they can start and run, but I don't know if they might have problems with updating / overriding system files they both use.
What I did (in the beginning to find out why PLX DAQ v1 wasn't running on specific Windows / Office versions) was to use Virtual PC software and install another version of Office in there. It is quite unhandy but at least it works even with Arduino
@Andreas:
Hi net^devil,
Funny thing, that is exactly where I started from as well :) I just wanted a way better way to visualize my data.
Well, since I am German as well let me put it like this: na siggi ! ("sure do")
As mentioned in the code PLX DAQ v2 is widely inspired by v1 and I do not hold any rights on the code or rather do not want to hold any rights. Use it as you like, mod it as you like, spend me a beer if we meet one time and you like (you sure might have a higher chance meeting me since we are both from Germany ;) ). It will be my pleasure to have a wider audience get in touch with the software and it might increase my motivation to finally get to work on v3 (alternative main code with hopefully much more stability).
Greetings to all of you!
atExcel
Hi net^devil,
Quote
this is how it should be done!
1. the YouTube-Tutorial
2. the beer ;-)
You can find my contact information on my channel.
Glück Auf!
Andreas
joseph_1234
hi,
I am trying to  extract  my data from  arduino (i have both nano and uno) wirelessly and wish to  plot the data on a graph.
I make use of the wifi module  esp 8266 and follow the procedure from this link
https://github.com/Cloudino/Cloudino-Doc/wiki/Make-your-first-Cloudino
to make a wifi cloud connector and i will be using cloudino.io cloud server to program my arduino wirelessly.
Is it possible to  use plx daq to  obtain data from the arduino from my sensor  as i will not be connecting my arudino to any usb port ?
If so ,  can i trouble you to advise me on what kind of modifications which need to be done  to implement this idea.
Thanks for your time in advance.
NetDevil
Is it possible to  use plx daq to  obtain data from the arduino from my sensor [wifi esp 8266] as i will not be connecting my arudino to any usb port ?
Hi joseph,
first of all => sadly PLX DAQ does not work with wifi modules like esp 8266. The communication is build on USB comm port communication only.
PLX DAQ could be modded to receive data not from "that one connection" but rather from a generalized module. This module could then be extended to receive data from USB or Network. For network a separate listener would be needed (thus e.g., a server side component to listen within your wifi). It will be some kind of larger design of an architecture.
Actually this is what I wanted to develop in the first place - but I never got my freaking ESP 8266 modules to work properly !!! The voltage converter to 3V (I guess) always resulted in garbage being send between my Arduino and the ESP 8266 ...
The USB communication is kind of problematic for PLX DAQ and I would like think about switching to ethernet communication. Although I don't have any time at the moment to do that ...
joseph_1234
Hi joseph,
thanks for your reply,
no worries , i will try something else :)
joshjoshjosh123
Hey NetDevil,
Sorry if this has already been asked/answered, I couldn't find it anywhere.
Is it possible to use PLX-DAQ in combination with a APC220? I'm able to print and read the prints using a serial monitor program, but PLX-DAQ doesn't see anything. It recognises that the COM port is in use and able to connect, but nothing in the spreadsheet or raw data logger.
Any ideas?
Thanks in advance!
