Topic: Keypad/Password Programming (Multiple (Read 8965 times) previous topic - next topic
adamfier
May 08, 2010, 07:26 pm Last Edit: May 08, 2010, 10:21 pm by adamfier Reason: 1
Hello everyone. This is my first post here, so I'm sorry if this is in the wrong place. I searched, but didn't find any similar posts.
So, here's my problem.
I am using a keypad and passwords to control (right now just an led) my door lock. I have made code to work with one or more passwords of my choosing, that is fine.
However, I've been trying to work on coding for a new feature called "Guest Mode." In this, I can use a "Lock" password on the keypad to control whether or not a Guest password would be accepted.
I'm trying to figure it out, but when I use the Lock password, the Guest password still works.
Any help would be greatly appreciated. Thank you for your help!
AdamFier
Code: [Select]
//keypad with password
#include <Keypad.h>
#include <Servo.h>
Servo myservo; //create servo object to control a servo
const byte myRows = 4;  // number of rows
const byte myCols = 3;  //number of columns
char keys[myRows][myCols] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
}; //character array to map the button layout of the keypad
byte rowPins[myRows] = {7, 2, 3, 5 }; //array to map keypad to MCU pins
byte colPins[myCols] = {6, 8, 4 }; //array to map keypad to MCU pins
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, myRows, myCols ); //keypad library map function
char inputArray[4]; //array to gather user keypad presses
char Main[4] = {'4','6','2','7'}; //array to hold keypad password
char Guest[4] = {'2','4','6','8'}; //array to hold the guest password
char Lock[4] = {'1','1','1','1'}; //array to hold the lock password
#define ledPin 13 //led to register keypad pressses
#define registerPin 12 //led that registers correct password entry
#define ServoPin 10 //servo that registers correct password entry
int i = 0;
int pos = 0; //variable to store the servo position
int open()
 digitalWrite(registerPin, HIGH); //turn on registerPin led
 digitalWrite(registerPin, LOW);
 return 0;
int MasterGuest()
{                                             //MasterGuest
   //match input array to password array
   if ((inputArray[0] == Main[0] &&
   inputArray[1] == Main[1] &&
   inputArray[2] == Main[2] &&
   inputArray[3] == Main[3]) ||
   (inputArray[0] == Guest[0] &&
   inputArray[1] == Guest[1] &&
   inputArray[2] == Guest[2] &&
   inputArray[3] == Guest[3]))
     open();
   if (inputArray[0] == Lock[0] &&
   inputArray[1] == Lock[1] &&
   inputArray[2] == Lock[2] &&
   inputArray[3] == Lock[3])
     Master();
int Master()
 inputArray[3] == Main[3]))
   open();
   MasterGuest();
 Serial.begin(9600); //open serial porrt
 pinMode(ledPin, OUTPUT); //define led pin as output
 pinMode(registerPin, OUTPUT); //define led pin as output
 myservo.attach(10); //attaches the servo on pin 1 to the servo object
 char key = kpd.getKey();
 //if a key is presseds
 if(key)
   //turn on ledPin
   digitalWrite(ledPin, HIGH);
   delay(100);
   digitalWrite(ledPin, LOW);
   delay(100);
   inputArray[i] = key; //store entry into array
   i++;
   Serial.println(key); //print keypad character entry to serial port
   if (key=='*')
     Serial.println("Reset");
     i=0; //reset i
   if (i == 4) //if 4 presses have been made
     MasterGuest();
      i=0;
AWOL
#1
May 08, 2010, 07:49 pm Last Edit: May 08, 2010, 07:50 pm by AWOL Reason: 1
Loops and indentation are your friends.
As is the "#" button on the post editor toolbar.
If you click on "Modify", then higlight all the code in your post, then click on the "#" button on the editor's toolbar, the code in your post will be enclosed in a tidy box.
"Master" and "MasterGuest" are functions, and don't need semicolons at the end of their declarations.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
adamfier
Thank you for your reply and your help so far.
I changed the formatting to make everything clearer and tidied everything up in the post.
What did you mean by loops being my friends? What does that mean?
Also, I removed the semicolons from the declarations of "Master" and "MasterGuest," but I didn't notice any changes? What does removing them do?
Thank you again.
Adam
PaulS
Quote
In MasterGuest, you check to see if the master password or the guest password was entered. If so, you open the door.
Then, you check to see of the lock password was entered.
Seems to me that you want to see if the master password was entered. If so, open the lock. Then, see if the lock password was entered. If it was, skip checking the guest password. Otherwise, check the guest password. If it was entered, open the door.
AWOL
adamfier
Hey guys,
thanks for your help, but I figured it out.
I used a variable (int State = ?) and while states to do what I wanted. It works perfectly for now.
Thanks.
Code: [Select]
#include <Keypad.h>
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
char Unlock[4] = {'2','2','2','2'};
int i = 0;
int state = 1; //Creates the state
while (state = 1)
   if(key)
     //turn on ledPin
     delay(100);
     delay(100);
     i++;
     if (key=='*')
         i=0; //reset i
           if (inputArray[0] == Main[0] &&
           if (inputArray[0] == Guest[0] &&
               Serial.println("State 2");
               state = 2;
         i=0; //reset i
 while (state = 2)
   if(key)
     //turn on ledPin
     delay(100);
     delay(100);
     i++;
     if (key=='*')
         i=0; //reset i
           if (inputArray[0] == Unlock[0] &&
           inputArray[1] == Unlock[1] &&
           inputArray[2] == Unlock[2] &&
           inputArray[3] == Unlock[3])
               Serial.println("State 1");
               state = 1;
         i=0; //reset i
PaulS
Code: [Select]
Can you explain what all the open and close braces are for, and which ones are needed?
Many of these are not.
