Loading...
Pages: [1]   Go Down
Author Topic: Problem with float & trigonometric functions  (Read 562 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have the following code, trying to calculate a distance between two geo-coordinates in meters:
Code:
#include <math.h>
void setup(){
            Serial.begin(4800);
            float lat_old = 49.66873;
            float lon_old = 7.98983;
            float lat= 49.66873;
            float lon = 7.98981;
            float dist = acos(sin(lat)*sin(lat_old)+cos(lat)*cos(lat_old)*cos(lon-lon_old))*6378000.0;
           Serial.print("Lat_old: ");
             serial_printFloat(lat_old);
             Serial.print("Lon_old: ");
             serial_printFloat(lon_old);
             Serial.print("Lat: ");
             serial_printFloat(lat);
             Serial.print("Lon: ");
             serial_printFloat(lon);
             Serial.print("Distance in meters: ");
             serial_printFloat(dist);
void loop(){
void serial_printFloat(float value) {
  //Check if negative value and print - sign
  if(value<0)
  {Serial.print("-");}
  //Print the number before the decimal point
  //We check if the number before the decimal point
  //is negative. If it is then we make it into a positive
  //number. So we don't get something like --10.286
  //As we already printed the negative sign (-)
  int temp0=(int)value;
  if(temp0<0){
    temp0=temp0-(temp0*2);
  Serial.print(temp0);
  //Print decimal point
  Serial.print(".");
  //We insert the numbers after the deciaml (.) into temp
  //Using long as we can store more values
  //Add additional zeros (000) to 1000000 to increase degree of accuracy
  //beyond the decimal point
  long temp=long((value - (long)value) * 1000000);
  //If temp is negative we convert it to a positive number so we
  //don't get something like -0.-286
  if(temp<0){
    temp=temp-(temp*2);
  Serial.println(temp);
  //And that's it. We're done :-)
The distance should yield to 1.48152 meters, however, the output via serial monitor always gives me the following output:
Code:
Lat_old: 49.668731
Lon_old: 7.989830
Lat: 49.668731
Lon: 7.989810
Distance in meters: 0.0
Does anybody see my mistake?
Thanks for any help.
Logged
Offline Offline
God Member
Arduino rocks
View Profile
The trigonometric functions expects radians not degrees. You need to convert your lat/lon to radians before you use them in your calculations (deg*PI/180).
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I don't understand the formula for converting lat/long pairs to distance, so I don't know if that's right or wrong. You could add a Serial.print statement to see if the result is even close to right.
I have a question about the serial_printFloat funcction, though. I two places you have code like this:
Code:
Wouldn't "temp0 = -temp0;" be easier to understand, quicker to type, and faster to execute?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
When I convert the lat & lon values to radians I get the same result: distance = 0.0.
So this cannot be the problem, sorry.
Code:
#include <math.h>
void setup(){
            Serial.begin(4800);
            float Pi = 3.1415926535897932384626433;
            float lat_old_rad = lat_old* Pi/180.0;
            float lon_old_rad = lon_old* Pi/180.0;
            float lat = 49.66873;
            float lat_rad = lat* Pi/180.0;
            float lon_rad = lon* Pi/180.0;
            float dist = acos(sin(lat_rad)*sin(lat_old_rad)+cos(lat_rad)*cos(lat_old_rad)*cos(lon_rad-lon_old_rad))*6378000.0;
void loop(){
  if(value<0)
  if(temp0<0){
  Serial.print(".");
  if(temp<0){
    temp=temp-(temp*2);
Logged
Offline Offline
God Member
Arduino rocks
View Profile
Quote
Well -one error doesn't exclude another.
Here's working Arduino code for calculating distance between two points.
Code:
// calculate distance in rad between two points
float c_dist(float lat1,float lon1,float lat2,float lon2)
  // the standard version of formulae yields unacceptable precision
  // return acos(sin(lat1)*sin(lat2)+cos(lat1)*cos(lat2)*cos(lon2-lon1));
  // alternative formulae (haversine)
  const float two=2.0;
  return two*asin(sqrt(square(sin((lat1-lat2)/two)) +
         cos(lat1)*cos(lat2)*square(sin((lon2-lon1)/two))));
}/*c_dist*/
To get distance in meters you must multiply the returned value with earth's radius (#define EARTH_RADIUS 6371009.0).
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
That did the trick! Thanks a lot!
Logged
Bedum. grunn, The netherlands
Offline Offline
Newbie
Arduino rocks
View Profile
:S i do not understand ..
what is the final code for calculating distance then ?
Logged
Pages: [1]   Go Up
Print
Jump to:
