Author Topic: NEW on-off cycle question!!!  (Read 268 times)
First off, Thanks very much to AWOL and brtech for the prompt help with my earlier question http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274292639/0#0
ive managed to get my code to a usable point...i just repeated my sequence 18 times and put a big delay at the end, its been running fine and ive only used about 5500 bytes of memory...but now on to my next problem:
Since I am working with two separate arduinos running two different codes, I now need help figuring how to cycle the second adruino... I am using arduinos to control an electronic switch which is cycling lights on and off in morse code....and I want the morse sequence to run for 5 minutes and then turn off for 10 minutes, then run for 5 minutes..etc...I have the morse code sequence figured out...i just need to get it to cycle on and off...
my problem now is how to get the following bit of code to run for 5 minutes, then pause for 10 minutes, then run for 5..etc..
The code is meant to generate random morse code...either dots or dashes... it works great, i just dont have any idea how i can make it cycle on and off like i have described...
Any and all help would be much appreciated!!!!
Thank you, Don
 smiley-grin
int pin = 12;
long randOn = 0;
  pinMode(pin, OUTPUT);
  randOn= random(0,10);
  if (randOn > 5) {
    digitalWrite(pin, HIGH);
  delay(100);
  digitalWrite(pin, LOW);
  delay(100);
{digitalWrite(pin, HIGH);
  delay(400);
  delay(100);
Australia
How about this:
#define _5MIN 300000
int pin = 12;
long randOn = 0;
long remaining;
 remaining = _5MIN;
 while (remaining >= 0)
  if (randOn > 5)
   delay(100);
   delay(100);
   remaining -= 200;
   delay(400);
   delay(100);
   remaining -= 500;
 delay(_5MIN * 2 + remaining); // 10 minutes minus whatever we exceeded the 5 minutes by.
We keep track of the 5 minutes active time with the "remaining" variable, which is decremented each time we spend some time doing something. When the 5 minutes is up, "remaining" will be < 0, in which case we reduce the 10 minute delay by the amount we went over, resulting in a total of 15 minutes spent in the full loop{}.
« Last Edit: May 20, 2010, 06:38:51 am by crimony » Logged
Seattle, WA USA
Seattle, WA USA
@dedler
If you properly indented your code, and lined up the curly braces, you'd see that it doesn't look right:
[glow]}[/glow]
  if (randOn > 5)
    delay(100);
    delay(100);
    delay(400);
    delay(100);
You could also do us a big favor and learn to use the # key on the top row when posting code.
UK
Gorm deficient
How about this:
Code:#define 5MIN 300000
Bzzzt!
Per Arduino ad Astra
Australia
Bzzzt!
I didn't say it was tested  smiley-wink
Bzzzt! ???What does that mean???
im guessing it means some kind of a problem with the code...?
that being said, I tried the code crimony posted and it seems to be working beautifully!!!! THANK YOU VERY MUCH!
UK
Online Online
From groove's post, and the fact that crimony edited the code post after groove's "bzzt", I'm going for crimony originally posted an illegal macro name "5MIN" and then changed it to "_5MIN"
« Last Edit: May 20, 2010, 03:40:32 pm by AWOL » Logged
thanks again AWOL
