Topic: Nokia 3310 LCD Library with basic graphics functio (Read 3077 times) previous topic - next topic
GnobarEl
I connect a simple nokia LCD to arduino and I can use it with simple functions.
I used a schematic like this:
http://www.amontec.com/lcd_nokia_3310.shtml
and
http://www.techdesign.be/projects/datasheet/nokia_3310_LCD.jpg
Modifying this:
int LCD_DC_PIN         =        2; //  PB0  4  Data Command
int LCD_CE_PIN         =        3; //  PB2  5  /CS   active low chip select ??
int SPI_MOSI_PIN       =        4; //  PB3  3  Serial   line
int LCD_RST_PIN        =        5; //  PB4  8   /RES RESET
int SPI_CLK_PIN        =        6; //  PB5  2  CLOCK
with my pin-out I was able to run this code:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1200398529/16#16
But i wanted to use this library
http://blog.thiseldo.co.uk/?p=383
That library is very powerful since it has lots of functions to draw,
but i'm not sure how to make it work without the LCD shield.
Any idea?
Thanks for your help!
