Topic: lcd 16x2 shows only background light (Read 730 times) previous topic - next topic
zubator
I've followed a lot of tutorials but i cant get this work.
i use an arduino mega and it's my first arduino so i dont now if it'a a arduino problom or a display.
if u need to know some more information just ask me.
Thanks for your time.
floresta
Probably neither.  I suspect operator error.
Don
zubator
Don
Thanks for your reply
Now it work....
only fault was that i haven't solder the 16 pins so there wasn't any contact with the V0 so it wasn't showing anything.
Noi i'm wondering how i have to work with the LCD without soldering the pins...
do you have any idea how can i do?
rpt007
#3
Dec 11, 2016, 02:28 pm Last Edit: Dec 11, 2016, 02:30 pm by rpt007
You need to solder the pins at least to the display itself!
After that it MIGHT work that you place the pins into a stackable header row on a board, which is properly connected with your Arduino (although imho the whole construction doesn't make much sense and is a source for failure).
Those LCD displays are very critical and won't work at all, whenever a connection is not solid.
Question: why do you want to avoid soldering them ?
Before you ask:
Did you really read and understand How to use this forum ?
AND:
Do you have already some solution or is a part of the problem sitting in front of the screen?  :)
zubator
i dont have one ;)
But i did it with out, here's a photo:
https://hostr.co/sH4xvWSLHFkL
https://hostr.co/bELo1xlBpPcR
thanks for your time
rpt007
Quote
You are welcome.
But, don't be astonished when your configuration will work as a real digital one:
WORKS - WORKS NOT - WORKS - WORKS NOT
The second you touch your non-soldered configuration and move it a little aside - you will see the "digital" effect.
If you want to continue with Arduino and peripheral devices like a display which doesn't come with pin headers soldered, go and get a solder iron and learn how to produce good connections.
Before you ask:
AND:
