Author Topic: atoi FAIL  (Read 1303 times)
Hey everyone!
I am trying to recieve multiple bytes over serial, store in array, and use atoi to convert to int. However I am getting very different results from atoi smiley-sad
Using atoi like this:
if( Serial.available() >= 3 ) {
  rred[0] = Serial.read();
  rred[1] = Serial.read();
  rred[2] = Serial.read();
  char * thisChar = rred;
  int a = atoi(thisChar);
Attaching a pic of terminal, so you can se what it outputs.
gratisupload.dk/download/45675/
As you can see, it works after sending 000 command some times, but only once.
Please help!! smiley-grin
Best regards, Jonas Hald
Des Moines, WA - USA
char    buffer[4];
if ( Serial.available() >= 3 )
    char*   pbuffer = buffer;
    *pbuffer++ = Serial.read();
    *pbuffer++ = 0;
    int     n;
    n = atoi(buffer);
UK
Gorm deficient
Or, if you're averse to explicit pointer arithmetic and extraneous variables:
char    buffer[4];
    buffer[0] = Serial.read();
    buffer[1] = Serial.read();
    buffer[2] = Serial.read();
    buffer[3] = '\0';
    int     n;
    n = atoi(buffer);
Per Arduino ad Astra
Thank you very much!! smiley-grin Both of you!
Canby, OR
The short answer is you can do:
You'd have to use strcpy or something else to copy the array to the other one.
UK
Gorm deficient
He already is doing that - what's your point?
There's nothing wrong with the code in the OP, except there's no "rred[3] ='\0';" before the "char * thisChar = rred;"  (assuming "rred" is declared as having at least four elements.)
