Topic: Arduino101 'freezes' when moving sensors (Read 664 times) previous topic - next topic
carpo23
Hi, i'm seeing a randomly strange behaviour of the Arduino101. If I don't move the board everything works fine, but when I start shacking and moving constantly the board it randomly gets stucked. This menas that you can not see anymore the BLE Arduino device when scanning, and the only way to work again with it it's to restart the board. When facing this issue, the power on the arduino is still ok. Again I repeat, it seems something related with shacking the board for a while.
I put here my code hoping that you can help me understand the possible reasons for that (maybe some problem about performance or the way I handle interrupts).
Code: [Select]
#include "CurieIMU.h"
#include "CurieBLE.h"
#include <stdio.h>      /* puts, printf */
bool motion;
int aix, aiy, aiz;    // raw accelerometer values
int gix, giy, giz;    // raw gyro values
BLEPeripheral blePeripheral;
BLEService sensorService("19B10010-E8F2-537E-4F6C-D104768A1214");
BLEUnsignedLongCharacteristic stepCharacteristic("19B10011-E8F2-537E-4F6C-D104768A1214", BLERead);  // stepcount
BLEFloatCharacteristic axCharacteristic("19B10012-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // acc.in x in g
BLEFloatCharacteristic ayCharacteristic("19B10013-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // acc.in y in g
BLEFloatCharacteristic azCharacteristic("19B10014-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // acc.in z in g
BLEFloatCharacteristic gxCharacteristic("19B10015-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // rot.in x in deg/s
BLEFloatCharacteristic gyCharacteristic("19B10016-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // rot.in y in deg/s
BLEFloatCharacteristic gzCharacteristic("19B10017-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify); // rot.in z in deg/s
BLEIntCharacteristic shockCharacteristic("19B10018-E8F2-537E-4F6C-D104768A1214", BLERead | BLENotify);  // true if shock sensed
BLEIntCharacteristic modeCharacteristic("19B10019-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);  // sensing mode
BLEIntCharacteristic srangeCharacteristic("19B10020-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);  // shock range
BLEIntCharacteristic arangeCharacteristic("19B10021-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);  // acc. range
BLEIntCharacteristic grangeCharacteristic("19B100122-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite); // gyro range
BLEIntCharacteristic calibCharacteristic("19B100123-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);  // 1 if calibration is on, otherwise 0
void printSerial() {
// print for debug
void initPeriph() {
// initialization of BLE sensor device
blePeripheral.begin();
// Serial.begin(9600);
//while (!Serial);    // wait for the serial port to open
// Serial.println("Initializing IMU device...");
CurieIMU.begin();
// configure Bluetooth
blePeripheral.setLocalName("MOOVBIT");
blePeripheral.setAdvertisedServiceUuid(sensorService.uuid());
blePeripheral.addAttribute(sensorService);
blePeripheral.addAttribute(stepCharacteristic);
blePeripheral.addAttribute(axCharacteristic);
blePeripheral.addAttribute(ayCharacteristic);
blePeripheral.addAttribute(azCharacteristic);
blePeripheral.addAttribute(gxCharacteristic);
blePeripheral.addAttribute(gyCharacteristic);
blePeripheral.addAttribute(gzCharacteristic);
blePeripheral.addAttribute(shockCharacteristic);
blePeripheral.addAttribute(modeCharacteristic);
blePeripheral.addAttribute(arangeCharacteristic);
blePeripheral.addAttribute(srangeCharacteristic);
blePeripheral.addAttribute(grangeCharacteristic);
blePeripheral.addAttribute(calibCharacteristic);
// set initial characteristics values
stepCharacteristic.setValue(0);
shockCharacteristic.setValue(0);
modeCharacteristic.setValue(0);
arangeCharacteristic.setValue(4);
srangeCharacteristic.setValue(4);
grangeCharacteristic.setValue(250);
calibCharacteristic.setValue(1);
initPeriph();
//Serial.println("Bluetooth device active, waiting for connections...");
if (calibCharacteristic.value() == 1) {
//Serial.println("About to calibrate. Make sure your board is stable and upright");
delay(5000);
CurieIMU.autoCalibrateGyroOffset();
CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0);
CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1);
else {
//Serial.println("No calibration");
// Configure sensors
CurieIMU.setAccelerometerRange(arangeCharacteristic.value());
CurieIMU.setGyroRange(grangeCharacteristic.value());
CurieIMU.setStepDetectionMode(CURIE_IMU_STEP_MODE_SENSITIVE);
CurieIMU.setStepCountEnabled(true);
/*CurieIMU.setDetectionThreshold(CURIE_IMU_TAP, 750);       // (750mg)
CurieIMU.setDetectionThreshold(CURIE_IMU_DOUBLE_TAP, 750);    // (750mg)
CurieIMU.interrupts(CURIE_IMU_TAP);
CurieIMU.interrupts(CURIE_IMU_DOUBLE_TAP);*/
CurieIMU.setDetectionThreshold(CURIE_IMU_SHOCK, srangeCharacteristic.value() * 500); // 1g = 1000 mg
CurieIMU.setDetectionDuration(CURIE_IMU_SHOCK, 50); // 50ms or 75ms
CurieIMU.interrupts(CURIE_IMU_SHOCK);
CurieIMU.interrupts(CURIE_IMU_MOTION);
CurieIMU.attachInterrupt(eventCallback);
//Serial.println("Sensor ready");
motion = false;
/* NOT IMPLEMENTED WRITE CHARS SO COMMENTED THIS SECTION
if (arangeCharacteristic.written()) CurieIMU.setAccelerometerRange(arangeCharacteristic.value());
if (grangeCharacteristic.written()) CurieIMU.setGyroRange(grangeCharacteristic.value());
if (srangeCharacteristic.written()) {
CurieIMU.setDetectionThreshold(CURIE_IMU_SHOCK, srangeCharacteristic.value() * 1000);
if (modeCharacteristic.written()) {
// change sensing mode
if (motion) {
if (!axCharacteristic.setValue(convertRawAcceleration(aix)) || !ayCharacteristic.setValue(convertRawAcceleration(aiy)) ||
!azCharacteristic.setValue(convertRawAcceleration(aiz)) || !gxCharacteristic.setValue(convertRawGyro(gix)) ||
!gyCharacteristic.setValue(convertRawGyro(giy)) || !gzCharacteristic.setValue(convertRawGyro(giz))) {
//Serial.println("Erorr BLE");
stepCharacteristic.setValue(CurieIMU.getStepCount());
motion = false;
delay(2000);
void eventCallback() {
if (CurieIMU.getInterruptStatus(CURIE_IMU_SHOCK)) {
if (shockCharacteristic.value() == 0) {
//Serial.println("Shock sensed");
shockCharacteristic.setValue(1);
//CurieIMU.readMotionSensor(aix, aiy, aiz, gix, giy, giz);
//motion = true;
else if (CurieIMU.getInterruptStatus(CURIE_IMU_MOTION)) {
motion = true;
// converted values based on accelerometer range
float convertRawAcceleration(int aRaw) {
float a = (aRaw * float(arangeCharacteristic.value()) / 32768.0); // output values from -16.0 to +16.0
return a;
// converted values based on gyro range
float convertRawGyro(int gRaw) {
float g = (gRaw * float(grangeCharacteristic.value()) / 32768.0); // output values from -2000.0 to +2000.0
return g;
GUSTAVOJALBOR
Im in the same boat, im using tinytile, do you solve the problem?
ThierryG
Hello,
I have not exactly the same script, but i read IMU positions and send them in ext uart and in a same time, i read 2 I/O interrupt with pwm form and send it on USB side braswell.
Also i have freeze ...
