Topic: how to connect my Atmel ICE debugger to the MKRZero ? (Read 4040 times) previous topic - next topic
Dirk67
Hello,
how can I connect my Atmel ICE debugger [via SWD] to the MKRZero ?
I know that I have to solder the missing "J8" connector to the backside of the MKRZero...
(btw. is it 50mil or 100mil connector ?)
but the "J8" is only 6-pin and the Atmel ICE has 10-pin SWD connector,
so what adapter is the right one ?
I think, the Adapter I got with the Atmel ICE is for AVR ISP only (?)
arduino powered car relais / car "micro PLC" / with USB --> http://goo.gl/ofWFW3
Federico_Vanzati
#1
Dec 15, 2016, 06:49 pm Last Edit: Dec 15, 2016, 07:07 pm by Federico Vanzati
in the attachment you can find an illustration of the pinout of the J8 header with the SWD signals you need to connect to the ATMEL ICE.
At this link there is described how to connect a SWD target to the ATMEL ICE.
Refer to the connection to the SAM port and pin numbering.
You can use the "50-mil 10-pin mini-squid cable with 10 x 100-mil sockets" if it's included in the ATMEL-ICE kit you have purchased.
It's the one in the top of this image:
(http://www.atmel.com/webdoc/atmelice/atmelice.getting_started_assembling.html)
You can solder wires directly on the pads, mount a 2x3 100-mils pitch header or use pogopins on a perfboard.
In case you want to build an adaprer I'd like to note you that the pads of the J8 connector are aligned with the GPIOs headers so you can use them for centering the MKRZero SWD connector with the adapter.
F
anurag2508
Hi Guys,
I am using Arduino MKR Zero pcb We need this pcb size like (Length x width). If Any one knows please let me know what is the size of pcb?
Thank you.
