Topic: 2.42" OLED SSD1309 with U8GLIB (Read 10060 times) previous topic - next topic
BoKKeR
#15
Mar 15, 2018, 06:49 pm Last Edit: Mar 15, 2018, 06:55 pm by BoKKeR
If anyone else has a problem to get this display to work with I2C I posted my own wiring on my blog: 2.42" I2C wiring
AndreK
So I bought one of those (2.4" display) :
I already have a project that works well with the U8X8_SSD1306_128X64 library and 0.96" displays.
Removed R4 , jumped R3, R5
So far: I added the usual I2C Pullups and connected to an Arduino configures for the before mentioned 0.96"
also tried to pullup RES (2k2)  , pull up/down the DC (for address selection)
no success.
So I compiled it with RES support, and tried with , and without an 3k3 pullup for RES (to bring it up before arduino boots)
what else can I try ?
AndreK
no success.
So I compiled it with RES support,(connected RES) and then tried with , and without an additional 3k3 pullup for RES (to bring it up before arduino boots)
68gt500
Thread is a little old, but for reference:
The  above 2.42" Oled with the jumpers set for I2C operation work when the reset  PIN is connected to the reset pin of the Arduino.
Used SH1109 driver in U8Gxx Lib and also dedicated SH1109 Libs
I2C:
R3 & R5 jumpered
R4 removed.
Also tested with ESP32. Just make sure to use "stickbreakers" updated wire - to avoid hangups.
Greets
Mike
chukovskij
#19
Nov 03, 2018, 08:29 pm Last Edit: Nov 03, 2018, 09:08 pm by chukovskij
@ 68gt500
Thanks, I've managed get it working, my config is slightly different:
My board is black one: Diymore 2,42" 128x64 OLED Display Module with I2C and SPI support
  • I2C: R4 smd resistor (4.6 kOhm) moved to R3
  • R5 jumpered
  • Reset pin connected to ESP8266 reset pin
  • driver settings:  U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
In my case display didn't respond (I thought it could be already dead) until I've connected reset pin to ESP8266 reset pin. If I disconnect it while it is working the screen turns off.
Also, somewhere was mentioned that instead of connecting reset pin to reset you could connect display reset pin to GND via resistor (10 kOhm or greater) and than to some digital pin of your board, so get reset pin low on startup and manually set pin high before lcd init cal)
Not sure what is better for R5: shortcut or resistor (4.6 kOhm similar to others), but shortcut works ok and it is easier to make.
68gt500
It has been working for some time now.
But I have run into an issue:
When powered by USB  - all is good.
When powered via the VIn connector the display is black until I push the reset button.
Anyone an idea?
Should I try chukovskij´s idea?
Any input appreciated
Mike
68gt500
Solution:
Connect Display RES to a pin of your choice - I am using #5
  pinMode( 5, OUTPUT);  // RES Pin Display
  digitalWrite( 5, LOW);
  delay (500);
  digitalWrite( 5, HIGH);
  u8g2.begin();   // Start OLED
Works ok when powered via USB or VIn Plug
