Topic: IDE 1.8.0 Released -- update: 1.8.9 (Read 115975 times) previous topic - next topic
LuisSousa
Hi, i have this problem;
In file included from C:\Users\Admin\Documents\Arduino\sketch_nov11a\sketch_nov11a.ino:4:0:
C:\Users\Admin\Documents\Arduino\libraries\MCUFRIEND_kbv/MCUFRIEND_kbv.h:16:26: fatal error: Adafruit_GFX.h: No such file or directory
compilation terminated.
exit status 1
Erro ao compilar para a placa Arduino/Genuino Uno.
Any 1 know who to fix?
Thanks.
MAS3
Hi LuisSousa, welcome.
Yes, you fix it yourself.
Seems like you didn't install all required libraries.
I don't know whether Adafruit_GFX.h is included in the MCUFRIEND_kbv library or not, so you should check that.
If it is not, install that library by using the library manager.
I have it installed for some time already, so i can't tell you whether it came as part of something else or not.
Also check to see you need other libraries as well for this sketch of yours.
By the way, this thread wasn't meant for questions like this.
Please be sure you put you questions in the correct location.
That way, chances are a lot better you will be promptly helped with some suiting suggestions.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
Birki
Hi!
I wrote a C++ class on debian stretch on a raspberry that communicates with an Adafruit ItsyBitsy M4 or a Feather Express M4 using libusb. Well - native USB is a little bit more tricky and I would not molest anyone when I would be unsure that there is something really strange going on:
- When compiling my code for the Feather with Arduino IDE 1.8.5, all works fine. The Raspi sends something, and the Feather responds accordingly, and all is fine.
- That works also when I use the terminal of the Arduino IDE. I send something, and the feather reacts. I use "Serial.write()" to send data via USB and "Serial.read()" on the Feather.
When uploading the code from Arduino IDE 1.8.7
- all works fine with the IDE terminal
- when connecting with the Raspberry and my C++ program, I can send data which are recognized by the Feather (at least I think so - i fire up the red LED on pin 13 for certain characters, and turn it off with others) but
- i cannot send anything ... both with the ItsyBitsy M4 and the Feather Express M4!!!
I have not tried it yet with another native USB board such as the Teensy, but this is really strange - does someone have an idea???
yours
wolfi
PS: cross posted this also in the Adafruit forum
oqibidipo
ARDUINO 1.8.8 2018.12.07
[ide]
* Fixed: command line parsing of version parameters when installing cores/libraries
* Platform indexes are now downloaded using https
* Fixed: on some newer linux distrubitions, NPE when loading GTK look-and-feel without libgtk2 installed
* MacOSX: added touch bar support
* MacOSX: do not exit app after closing last window
* Fixed: serial monitor timestamps not always printed. Thanks @nitram509
* Kill active programmer if still alive after closing last IDE window
* Fixed: "Export compiled binary" now works also with unsaved sketches
* Improved automatic port re-selection after upload
* Added scroller to "INCOMPATIBLE" examples menu
[wifi-firmware]
* Added firmware upgrade for NINA-based boards
mjculross
The newly released 1.8.8 IDE does not seem to pay attention to the "export.application.fullscreen=true" setting.  Reverting back to the 1.8.7 IDE (using the same preferences.txt file) restores functionality remembering fullscreen upon startup.
DaveAhrendt
There's something weird going on with 1.8.8 preferences.  As previous poster stated the fullscreen is wonky but so is the opening of the last sketch used.  It now opens with a empty sketch where in 1.8.7 it opened the last used. Reverting back to 1.8.7.
PAULC5
1.8.8 seems to be broken for me.  OS 10.9.5/MacbookPro 13.3" from 2012  (i.e. no touch bar)
Symptoms :  IDE starts up,  loads boards etc,  opens window to default sketch and immediately quit.
Looks like added touch bar support broke IDE for older Macs without touch bar; (reverting to 1.8.7 resolved the problem)
Debug shows :
dyld: Registered code signature for /private/var/folders/x_/n1mc8xx08v51kc006s6fgwqh0000gp/T/libJTouchBar.dylib4651976256396159074
2018-12-11 11:55:18.880 Arduino[1676:507] -[NSApplicationAWT setAutomaticCustomizeTouchBarMenuItemEnabled:]: unrecognized selector sent to instance 0x7fcfa8d04900
2018-12-11 11:55:18.882 Arduino[1676:507] Apple AWT Internal Exception: -[NSApplicationAWT setAutomaticCustomizeTouchBarMenuItemEnabled:]: unrecognized selector sent to instance 0x7fcfa8d04900
2018-12-11 11:55:18.882 Arduino[1676:507] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[NSApplicationAWT setAutomaticCustomizeTouchBarMenuItemEnabled:]: unrecognized selector sent to instance 0x7fcfa8d04900'
pert
I think you diagnosed the problem correctly. The Arduino developers have already been notified of this bug and have made a fix:
https://github.com/arduino/Arduino/issues/8274
If you want to try it out, you can install the Arduino IDE hourly build:
https://www.arduino.cc/en/Main/Software#hourly
The hourly build is primarily intended for beta testing and may not be as stable as the production releases. However, the fix of this bug is only one of two significant changes made to the IDE's code since the 1.8.8 release so I think it should be just as good as 1.8.8, except without the touch bar bug.
PAULC5
Excellent,  thanks !
cfletch630
It seems that the Wifi firmware updater isn't working properly on IDE 1.8.8.  I was attempting to update my new WINC 1500 and the only firmware offered is the Model A (19.4.4) not the current version of Model B (19.5.4). I ran IDE 1.8.7 on my older MacBook and it offered versions from 19.4.4 up to the required version of 19.5.4.
I downloaded the nightly build and it also does not offer the correct firmware versions.
I was able to update the firmware correctly with the 1.8.7 version, just wanted to let everyone know of this issue.
Thanks,
Carroll
fatehinura
IDE
Wifi Firmware
pert
Thanks for reporting this. There is now a proposed fix:
https://github.com/arduino/Arduino/pull/8349
Test builds are available at the link above if you want to try it out.
Vaibhav2710
Hey team arduino I have a problem in uploading code to my arduino uno r3 and I am doing this in Windows 7 and I also checked your help box and done exactly given there to update driver installation. I only found unknown sources and tried to update it but my windows in online search send a message that 'Windows is unable to find driver software for your unknown device
Hi there this is vaibhav new to arduino. If I make any mistake i request you to forgive me
pert
Provide a detailed explanation of the problem.
Plz help me
Don't do that. It will only make us less likely to help you.
Kshehab91
I downloaded the new version but suddenly "  while (Serial.available()==0){ } " stopped working so I uninstalled and kept working on the older version if someone can help it would be so thankful
