Topic: LCD "Bigfont" Numbers over 2 or 4 lines (Read 33144 times) previous topic - next topic
designer2k2
Jun 18, 2009, 09:17 pm Last Edit: Jun 19, 2009, 04:40 pm by designer2k2 Reason: 1
Hello,
ive seen this in the MPGuino, and on some other Projects, they display numbers over 2 or 4 lines.
Samples:
ive read the mpguino code, but im not getting it  :-[
Can somebody give me hints how i can make something like this?   :-?
Custom Characters are clear to me, but how do they print "int´s" like that...
help would be highly appreciated  :)
http://www.designer2k2.at
designer2k2
did some play:
2 Lines:
Needed Custom Characters:
4 Lines:
Thats sorted, now "only" the code is missing  :-/
AlphaBeta
#2
Jun 19, 2009, 05:28 pm Last Edit: Jun 19, 2009, 05:30 pm by AlphaBeta Reason: 1
You could write a function like this:
void writeLargeString(char* str){
 byte index=0;
 writeLargeChar( *str, index++ );
 while (++str){
void writeLargeChar(char character, byte leftAdjust){
 switch (character){
   case 'A':
   case 'a':
     //implement code
     //remember to move cursor to the correct places
     //print correct custom chars
   break;
When implemented you could do this:
With this:
writeLargeString("12345");
Or this:
[code]
writeLargeChar('1',0);
writeLargeChar('2',1);
writeLargeChar('3',2);
writeLargeChar('4',3);
writeLargeChar('5',4);
[/code
Not very helpful, but might be an idea.
designer2k2
uh nice , thats a idea!  :)
will give that a try, hope to get it working
Mike Mc
How many custom chars can the unit store?
glt
designer2k2,
Inspired by your designs, I tweaked my 3-line large font.  Here are some pictures: http://hifiduino.blogspot.com/2009/06/new-fonts.html
designer2k2
8 characters can be stored, and the "Everything on" Block is already there.
glt, nice to see it spreading  ;)  but i think with some more custom characters you can round it even more, will try that tomorrow.
and im going to try your code, to see what works for me  :)
designer2k2
got it  :D
2line:
and showing a value (boost):
and showing it with 4line´s:
the code, for the 2lines:
(http://code.google.com/p/multidisplay/source/browse/trunk/work_designer2k2_03/bigfont.pde)
//Bigfont Code
//BIG parts from http://opengauge.googlecode.com/svn/trunk/mpguino/mpguino.pde
void CGRAM_BigFont2()
 //255 is the "Full Block" Code, and 254 is blank
 int data1[] = {31,31,31,0,0,0,0,0};    //Small Block on top
 int data2[] = {0,0,0,0,0,31,31,31};    //Small Block on bottom
 int data3[] = {31,31,31,0,0,0,31,31};  //Small Block on top and bottom
 int data4[] = {28,30,31,31,31,31,30,28};  //Full Block roundet right
 int data5[] = {7,15,31,31,31,31,15,7};  //Full Block roundet left
 int data6[] = {0,0,0,14,14,14,12,8};  //Dot, for Decimal.
 LcdUploadUdef5x8(1,data1);
 LcdUploadUdef5x8(2,data2);
 LcdUploadUdef5x8(3,data3);
 LcdUploadUdef5x8(4,data4);
 LcdUploadUdef5x8(5,data5);
 LcdUploadUdef5x8(6,data6);
// Array index into parts of big numbers. Numbers consist of 6 custom characters in 2 lines
//              0             1          2        3          4             5         6       7               8       9
char bn12[]={255,1,255,0, 1,255,254,0, 1,3,4,0, 1,3,4,0, 255,2,2,0,     255,3,1,0, 5,3,1,0, 1,1,4,0,       5,3,4,0, 5,3,4,0};
char bn22[]={255,2,255,0, 2,255,2,0,   5,2,2,0, 2,2,4,0, 254,255,254,0, 2,2,4,0,   5,2,4,0, 254,255,254,0, 5,2,4,0, 254,254,255,0};
void printOneNumber2(uint8_t digit, byte leftAdjust, int LineOffset)
 // LineOffset = 0, means 1 Line, LineOffset = 20 means 2 Line.
 // leftAdjust = 0, means 1 Pos, leftAdjust = 1 is second Pos.
 // Line 1 of the one digit number
 lcd.commandWrite(0x80+LineOffset+leftAdjust*3+1*leftAdjust);                  //Line1
 lcd.print(bn12[digit*3]);
 lcd.print(bn12[digit*3+1]);
 lcd.print(bn12[digit*3+2]);
 // Line 2 of the one-digit number
 lcd.commandWrite(0xC0+LineOffset+leftAdjust*3+1*leftAdjust);              // Line 2
 lcd.print(bn22[digit*3]);
 lcd.print(bn22[digit*3+1]);
 lcd.print(bn22[digit*3+2]);
void bigNum (unsigned long t, int LineOffset, byte leftAdjust, int d){
// d = 0, means no dp!
//  unsigned long t = 98550ul;//number in thousandths
//  unsigned long t = 9855ul;//number in thousandths
 char  dp = 254;
 char  dp2 = 254;
 char * r = "009.99"; //default to 999
 if(t<=99500){
   r=format(t/10); //0098.6
   dp=6;
 }else if(t<=999500){
   r=format(t/100);
 if(t<=9950)
   dp = 254;
   dp2 = 6;
   r=format(t); //009.86
 if(d==0)
  dp = 254;
  dp2 = 254;
 lcd.commandWrite(0x80+LineOffset+leftAdjust);
 lcd.printIn(bn12+(r[2]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn12+(r[4]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn12+(r[5]-'0')*4);
 lcd.commandWrite(0xC0+LineOffset+leftAdjust);
 lcd.printIn(bn22+(r[2]-'0')*4);
 lcd.print(dp2);
 lcd.printIn(bn22+(r[4]-'0')*4);
 lcd.print(dp);
 lcd.printIn(bn22+(r[5]-'0')*4);
char fBuff[7];//used by format
char* format(unsigned long num){
 byte dp = 3;
 while(num > 999999){
   num /= 10;
   dp++;
   if( dp == 5 ) break; // We'll lose the top numbers like an odometer
 if(dp == 5) dp = 99; // We don't need a decimal point here.
// Round off the non-printed value.
 if((num % 10) > 4)
   num += 10;
 num /= 10;
 byte x = 6;
 while(x > 0){
   x--;
   if(x==dp){ //time to poke in the decimal point?{
     fBuff
       }else{
         fBuff
  • = '0' + (num % 10);//poke the ascii character for the digit.
         num /= 10;
     fBuff[6] = 0;
     return fBuff;
designer2k2
#8
Jun 22, 2009, 03:18 pm Last Edit: Jun 22, 2009, 03:46 pm by designer2k2 Reason: 1
and the other functions for the 4lines:
void CGRAM_BigFont4()
 int data1[] = {0,0,0,0,3,15,15,31};    //Small Block on bottom left
 int data2[] = {0,0,0,0,31,31,31,31};    //Small Block on bottom right
 int data3[] = {0,0,0,0,24,30,30,31};  //Small Block on bottom full
 int data4[] = {31,15,15,3,0,0,0,0};  //Small Block on top left
 int data5[] = {31,30,30,24,0,0,0,0};  //Small Block on top right
 int data6[] = {31,31,31,31,0,0,0,0};  //Small Block on top full
 int data7[] = {14,14,14,14,12,8,0,0};  //Dot, for Decimal.
 LcdUploadUdef5x8(7,data7);
// Array index into parts of big numbers. Numbers consist of 12 custom characters in 4 lines
char bn14[]={1,2,3,0,       2,3,254,0,     1,2,3,0,       1,2,3,0,       2,254,254,0,   2,2,2,0,       1,2,3,0,       2,2,2,0,       1,2,3,0,       1,2,3,0};
char bn24[]={255,254,255,0, 254,255,254,0, 1,2,255,0,     254,2,255,0,   255,2,2,0,     255,2,2,0,     255,2,3,0,     254,2,255,0,   255,2,255,0,   255,254,255,0};
char bn34[]={255,254,255,0, 254,255,254,0, 255,254,254,0, 254,254,255,0, 254,255,254,0, 254,254,255,0, 255,254,255,0, 254,255,254,0, 255,254,255,0, 4,6,255,0};
char bn44[]={4,6,5,0,       6,6,6,0,       4,6,6,0,       4,6,5,0,       254,6,254,0,   6,6,5,0,       4,6,5,0,       254,6,254,0,   4,6,5,0,       254,254,6,0};
void printOneNumber4(uint8_t digit, byte leftAdjust)
 lcd.commandWrite(0x80+leftAdjust*3+1*leftAdjust);                  //Line 1
 lcd.print(bn14[digit*3]);
 lcd.print(bn14[digit*3+1]);
 lcd.print(bn14[digit*3+2]);
 lcd.commandWrite(0xC0+leftAdjust*3+1*leftAdjust);              // Line 2
 lcd.print(bn24[digit*3]);
 lcd.print(bn24[digit*3+1]);
 lcd.print(bn24[digit*3+2]);
 // Line 3 of the one digit number
 lcd.commandWrite(0x94+leftAdjust*3+1*leftAdjust);                  //Line 3
 lcd.print(bn34[digit*3]);
 lcd.print(bn34[digit*3+1]);
 lcd.print(bn34[digit*3+2]);
 // Line 4 of the one-digit number
 lcd.commandWrite(0xD4+leftAdjust*3+1*leftAdjust);              // Line 4
 lcd.print(bn44[digit*3]);
 lcd.print(bn44[digit*3+1]);
 lcd.print(bn44[digit*3+2]);
void bigNum4 (unsigned long t, byte leftAdjust, int d){
 char  dp = 254;
 char  dp2 = 254;
 if(t<=99500){
   dp=7;
   r=format(t/100);
 if(t<=9950)
   dp = 254;
   dp2 = 7;
 if(d==0)
  dp = 254;
  dp2 = 254;
 lcd.commandWrite(0x80+leftAdjust);
 lcd.printIn(bn14+(r[2]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn14+(r[4]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn14+(r[5]-'0')*4);
 lcd.commandWrite(0xC0+leftAdjust);
 lcd.printIn(bn24+(r[2]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn24+(r[4]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn24+(r[5]-'0')*4);
 lcd.commandWrite(0x94+leftAdjust);
 lcd.printIn(bn34+(r[2]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn34+(r[4]-'0')*4);
 lcd.printIn(" ");
 lcd.printIn(bn34+(r[5]-'0')*4);
 lcd.commandWrite(0xD4+leftAdjust);
 lcd.printIn(bn44+(r[2]-'0')*4);
 lcd.print(dp2);
 lcd.printIn(bn44+(r[4]-'0')*4);
 lcd.print(dp);
 lcd.printIn(bn44+(r[5]-'0')*4);
whosawhatsis
Where is the declaration for LcdUploadUdef5x8()?
designer2k2
here it is:
void LcdUploadUdef5x8(int character, int *data)
 int c = character << 3, i;
 for (i = 0; i < 8; i++)
   lcd.commandWrite(0x40 | c | i);
   lcd.print(data[i]);
whosawhatsis
Ok, I hate LCD4Bit, here's some code to do it with LiquidCrystal:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7, 8);
byte custchar[8][8] = {
   B11111,
   B11111,
   B11111,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B11111,
   B11111,
   B11111
   B11111,
   B11111,
   B11111,
   B00000,
   B00000,
   B11111,
   B11111,
   B11111
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B01110,
   B01110,
   B01110
   B00000,
   B00000,
   B00000,
   B01110,
   B01110,
   B01110,
   B00000,
   B00000
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000
byte bignums[10][2][3] = {
   {255, 0, 255},
   {255, 1, 255}
   {0, 255, 254},
   {1, 255, 1}
   {2, 2, 255},
   {255, 1, 1}
   {0, 2, 255},
   {1, 1, 255}
   {255, 1, 255},
   {254, 254, 255}
   {255, 2, 2},
   {1, 1, 255}
   {255, 2, 2},
   {255, 1, 255}
   {0, 0, 255},
   {254, 255, 254}
   {255, 2, 255},
   {255, 1, 255}
   {255, 2, 255},
   {254, 254, 255}
void loadchars() {
 lcd.command(64);
 for (int i = 0; i < 8; i++)
   for (int j = 0; j < 8; j++)
     lcd.write(custchar[j]);
 lcd.home();
void printbigchar(byte digit, byte col, byte row, byte symbol = 0) {
 if (digit > 9) return;
 for (int i = 0; i < 2; i++) {
   lcd.setCursor(col, row + i);
   for (int j = 0; j < 3; j++) {
     lcd.write(bignums[digit][j]);
   lcd.write(254);
 if (symbol == 1) {
   lcd.setCursor(col + 3, row + 1);
   lcd.write(3);
 } else if (symbol == 2) {
   lcd.setCursor(col + 3, row);
   lcd.write(4);
   lcd.write(4);
 lcd.setCursor(col + 4, row);
 pinMode(13, OUTPUT);
 loadchars();
 digitalWrite(13, 1);
 printbigchar(0, 0, 0);
 printbigchar(1, 4, 0);
 printbigchar(2, 8, 0);
 printbigchar(3, 12, 0);
 printbigchar(4, 16, 0, 1);
 printbigchar(5, 0, 2);
 printbigchar(6, 4, 2);
 printbigchar(7, 8, 2);
 printbigchar(8, 12, 2);
 printbigchar(9, 16, 2, 2);
void loop() {}
fly3rman
#12
Aug 03, 2010, 02:46 am Last Edit: Aug 03, 2010, 04:51 am by fly3rman Reason: 1
@ whosawhatsis
thanks for the code. works wonderfull:
Ill maybe adopt it to be a lil bit more round-edged, but just maybe.
designer2k2
nice!
i testet rounder numbers but they are a lot harder to read, somehow this ones are easier to read  :-?
