Loading...
Pages: 1 [2]   Go Down
Author Topic: Scrolling menu program hangs...  (Read 946 times)
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Code:
#include <NewSoftSerial.h>
NewSoftSerial LCDserial(0, 2);
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void LCDmenudisplay();
void first();
void second();
void third();
void fourth();
void fifth();
  LCDserial.begin(9600);
  menu();
void LCDclear(){
  LCDserial.print(0xFE, BYTE);
  LCDserial.print(0x01, BYTE);
void LCDfirst(){
  LCDserial.print(128, BYTE);
void LCDsecond(){
  LCDserial.print(192, BYTE);
void menu() {
  while(digitalRead(up) == HIGH || digitalRead(down) == HIGH || digitalRead(select) == HIGH){};
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
    prognumber--;
  else{
    prognumber = 1;
  LCDmenudisplay();
  LCDsecond();
  prognumber++;
  LCDmenudisplay();
  if(line == 1){
    LCDserial.print(143, BYTE);
    LCDserial.print("<");
  else {
    LCDserial.print(207, BYTE);
  while(digitalRead(up) == LOW && digitalRead(down) == LOW && digitalRead(select) == LOW){}
  if(digitalRead(down) == HIGH){
    line++;
    if(line > 2){
      line = 2;
      prognumber++;
      if(prognumber > 4){
        prognumber = 5;
  else if(digitalRead(up) == HIGH){
    line--;
    if(line < 1){
      line = 1;
      prognumber--;
  else if(digitalRead(select) == HIGH){
    if(line == 1){
      prognumber--;
    switch (prognumber) {
    case 1:
      first();
    case 2:
      second();
    case 3:
      third();
    case 4:
      fourth();
    case 5:
      fifth();
    default:
      first();
  delay(50);
void LCDmenudisplay() {
  case 1:
    LCDserial.print("First");
  case 2:
    LCDserial.print("Second");
  case 3:
    LCDserial.print("Third");
  case 4:
    LCDserial.print("Fourth");
  case 5:
    LCDserial.print("Fifth");
  default:
void first() {
  digitalWrite(13, HIGH);
void second() {
  digitalWrite(13, LOW);
void third() {
void fourth() {
  delay(100);
  delay(100);
  delay(100);
void fifth() {
As I never posted up the completely correct code before.  smiley-razz
Logged
Offline Offline
Sr. Member
Arduino rocks
View Profile
I never used it, but here is a menu library:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1240415211
May be could be useful to you.
Cheers,
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
I have seen that library but it did not do what I wanted it to  smiley-wink
So I wrote some code that did   smiley-grin
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
