Topic: Share tips you have come across (Read 108231 times) previous topic - next topic
larryd
#510
Apr 06, 2018, 10:45 pm Last Edit: Apr 06, 2018, 10:46 pm by larryd
Further to post #503
You can of course add other SMD components to machine pin headers.
http://www.dipmicro.com/store/TACT3X6-SMT
No technical PMs.
The last thing you did is where you should start looking.
TomGeorge
If I have to solder like this, using a protoboard, I have an el-cheepo board that I use all the time.
The heat from the pins can cause the clips loose their spring properties if you are soldering solder pads, that take a bit longer to solder, on a PCB.
Also a worn board is easier to insert and remove your work.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
larryd
Hi Tom.
I use this old breadboard for soldering.
Not sure where I got the board, just realized it only has one power rail on each side.
I just ordered some new machine pin headers.
Looks like they now have a bit of a bulb on the pin side.
No technical PMs.
TomGeorge
Hi Tom.
Not sure if I like the little bulb, means the pin will only have the solder joint as support, the other type without the bulb will sit right down on the PCB.
If you use them a single test points the non bulb will be better to keep the pin vertical during soldering and support from the PCB.
They would be okay as pins into protoboard.
Needs a "suck and see" to find if they are good.
It will be interesting how they sit when you solder them.
Tom... :)
polymorph
It looks just like the protoboards I bought from Radio Shack in the '80s. They still work.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
larryd
#515
Apr 13, 2018, 07:31 pm Last Edit: Apr 13, 2018, 07:33 pm by larryd
Stacking jars, mentioned earlier, can be used to keep your hook up wires organized.
Several places on the internet to get jars.
https://www.etsystudio.com/ca/listing/520370837/bead-craft-storage-round-stack-jar
No technical PMs.
larryd
#516
Apr 13, 2018, 07:35 pm Last Edit: Apr 13, 2018, 07:36 pm by larryd
No technical PMs.
Boardburner2
@Jiggy-Ninja
That is a great idea.
I purchased 10 of these boards to do something similar.
You Must corrected this error before you plug it onto an Arduino.[/color][/b]
larryd
#518
Apr 14, 2018, 01:57 am Last Edit: Apr 14, 2018, 05:01 am by larryd
'On that board' they connected 0V to +5V, you need to correct this as shown.
Always check for Vcc to GND shorts with ohmmeter.
No technical PMs.
larryd
#519
Apr 20, 2018, 04:39 am Last Edit: Apr 20, 2018, 04:40 am by larryd
No technical PMs.
larryd
#520
Apr 20, 2018, 04:39 am Last Edit: Apr 20, 2018, 04:48 am by larryd
No technical PMs.
Boardburner2
#521
Apr 20, 2018, 07:03 pm Last Edit: Apr 20, 2018, 07:03 pm by Boardburner2
Hi Tom.
I recently had a problem with these falling out of their sockets too easily.
Certainly worse than the square ones.
larryd
#522
Apr 22, 2018, 12:47 am Last Edit: Apr 22, 2018, 01:28 am by larryd
Sometimes, drilling plastic can be difficult.
An: engraving/end mill/spoon/D bit can make this task easy and safe.
Chuck your bit in an electric drill or cordless screw driver.
At slow speed, advance the bit into the plastic.
These bits cut clock wise. (looking from the drill to the hole)
The single fluted bit cuts thin shavings as it advances.
Since the bits are tapered, you can drill smaller holes than the bit diameter, if you drill partly through the plastic.
However, the hole will be tapered.
These bits are made of carbide steel, avoid forcing the bit as this may result in the bit breaking.
And, these bits are SHARP!
Different bit degees available, 10,15,20 and 30°.
1/8" bits are ~$1.00 each.
Lots of suppliers on eBay:
https://www.ebay.ca/itm/10pcs-3-175mm-Carbide-PCB-Engraving-Bits-CNC-Router-Tool-10-Degrees-0-1mm-V-Shap/382413315150?hash=item59099c1c4e:g:ehYAAOSw~l5arTN5
No technical PMs.
larryd
#523
Apr 22, 2018, 12:47 am Last Edit: Apr 22, 2018, 12:49 am by larryd
No technical PMs.
Boardburner2
#524
Apr 22, 2018, 08:02 am Last Edit: Apr 22, 2018, 08:03 am by Boardburner2
I have used caarbide drills but find they break too easily even when used in a drill press.
The dremel drill press does not seem to be rigid enough and there is a fair amount of runout on my dremel as well.
Can you use those by hand ?
