Topic: Own header file, problem finding the function inside the program (Read 150 times) previous topic - next topic
per_westergaard_skov
I have made my first little header file and Cpp file. Great! but not so great because when I compile a little test program the program returns this error:
sketch_jan11g:10: error: 'Store_Value_To_Eprom' was not declared in this scope
CPP file is like this:
#include "EL_Boat.h"
#include "Arduino.h"
#include "EEPROM.h"
void EL_Boat::Store_Value_To_Eprom(int Eprom_Value_To_Store, int Adress_LSB, int Adress_MSB)
    if(Eprom_Value_To_Store >= 256)
        Eprom_Value_To_Store -= 255;
        EEPROM.write(Adress_LSB , Eprom_Value_To_Store);
        EEPROM.write(Adress_MSB, 255);
           EEPROM.write(Adress_LSB,Eprom_Value_To_Store);
           EEPROM.write(Adress_MSB,0);
#ifndef EL_Boat_h
#define EL_Boat_h
Header file like this
#include "EEPROM.h"
class EL_Boat
  public:
    void Store_Value_To_Eprom(int Eprom_Value_To_Store, int Adress_LSB, int Adress_MSB);
    int Eprom_Value_To_Store;
    int Adress_LSB;
    int Adress_MSB;
  private:
    int _Eprom_Value_To_Store;
    int _Adress_LSB;
    int _Adress_MSB;
#endif
Anyone can help me with the error?
BR
Per
forgot to put in the program:
#include <EL_Boat.h>
Store_Value_To_Eprom(10, 10,10);
CrossRoads
Don't do that - you'll burn out the EEPROM address really quick.
Read the location, and only update it if the value needs to change.  Will be quicker too, as writing requires 3.3ms, while read/do nothing goes real quick.
Yes I know,
This is only to se if the program works.
I will eventially use it in another program.
