Author Topic: how many 7 segment LEDs can a arduino run?  (Read 551 times)
UK
How many 7 segment LEDs can a arduino run before using a LED Driver IC?
Really want to have 4 counting down 60.00 to 00.00 (MM.SS)
You can run a 4-digit LED display from the arduino.  I have a 4 digit display from digikey(67-1450-ND) running right now.  You'll need 12 IO.
edit:12 IO, not 16.
« Last Edit: August 12, 2009, 04:22:09 pm by jotux » Logged
UK
how about 4 separate 7 segments?
That display is 4 separate segments.  There are 8 segments per digit, and 4 common cathodes.
You connect the 8 segments and 4 cathodes to 12 IO and drive each digit sequentially.  Here's some code I threw together to display numbers on that particular display.
note: this code isn't all that great, or even all that complete.
#include <TimerOne.h> // this is non-standard, download it from the arduino site
const int num_digits = 10;
const byte num_pins   = 8;
const byte num_grounds= 4;
byte grounds[] = {3,2,1,0};                        // g1,g2,g3,g4
byte segments[]  = {9,6,13,12,11,8,7,4};      // A,B,C,D,E,F,G,P
byte num_to_display[]={0,0,0,0};
int led_nums[num_digits][num_pins]=
      {1,1,1,1,1,1,0,0},      // 0
      {0,1,1,0,0,0,0,0},      // 1
      {1,1,0,1,1,0,1,0},      // 2
      {1,1,1,1,0,0,1,0},      // 3
      {0,1,1,0,0,1,1,0},      // 4
      {1,0,1,1,0,1,1,0},      // 5
      {1,0,1,1,1,1,1,0},      // 6
      {1,1,1,0,0,0,0,0},      // 7
      {1,1,1,1,1,1,1,0},      // 8
      {1,1,1,1,0,1,1,0},      // 9
      int i;
      for (i = 0;i < num_pins;i++)
            pinMode(segments[i],OUTPUT);
            if (i < num_grounds)
                  pinMode(grounds[i],OUTPUT);
                  digitalWrite(grounds[i],HIGH);
      Timer1.initialize(550);
      Timer1.attachInterrupt(updateDisplay);
void updateDisplay()
      int g,d;
      for (g = 0; g < num_grounds;g++)
            for (d = 0;d < num_pins;d++) if(digitalRead(segments[d]) == 1) digitalWrite(segments[d], LOW);      // clear used
            digitalWrite(grounds[g],digitalRead(grounds[g])^1);      // enable digit
            for (d = 0;d < num_pins;d++) digitalWrite(segments[d], (led_nums[num_to_display[g]][d] == 1) ? HIGH : LOW); //write segments
            digitalWrite(grounds[g],HIGH);      // disable digit
      setDigits(1,2,3,4);
void setDigits(byte n1, byte n2, byte n3, byte n4)
      num_to_display[0] = n1;
      num_to_display[1] = n2;
      num_to_display[2] = n3;
      num_to_display[3] = n4;
« Last Edit: August 12, 2009, 04:12:09 pm by jotux » Logged
Hey guys, it doesn't look like this was ever answered proper.  I have a similar need:
I need to run 3 separate 8-segment LED displays independently.  Meaning, 1) Stopwatch Timer  2)  Temperature  3)  Calculation
Is three of these overkill? Sparkfun 7-Segment Serial Display
sku: COM-09230
Can the Arduino handle all that?
Thanks!
These are what I was asking about.
http://www.sparkfun.com/commerce/product_info.php?products_id=9230
Manchester (England England)
Solder is electric glue
Yes you can control as many as you want with the arduino. Use the SPI interface and then connect the CSN line of each display to an arduino output to enable it. In that way you can talk to as many devices as you have output pins on the arduino, or even more if you use I/O expanding chips.
I don't know if size/brightness does matter:
But if you want to show just much numbers, maybe an LCD 2x16 is more suitable?
For the 3x13$ you get a nice LCD. For an LCD you normally need 6 digipins, no matter of coulumn and row of the LCD.
If you look at this page:-
http://www.andreadrian.de/schach/#Selbstbau_Schachcomputer_SHAH
You will see the schematic has four 7 segment displays multiplexed. The Text is about a chess computer using an arduino and is in German but fortunately the diagram is in schematic an I read that very well.  smiley-wink
