Topic: The Not-so-amazing Disappearing ESP8266 (Read 8957 times) previous topic - next topic
gelfling6
I've noticed, in the newer IDE, that it seems to require grabbing offline, the .json file for the ESP-8266 library and programming, BUT.. I have a small problem..  Not all of my equipment is portable, and the Wifi where I live, is limited to only certain times of the day.. So... Imagine my surprise, when I go to program an 8266-01, and... there's Nothing there except the Adafruit examples... and the IDE doesn't recognize the 8266..  Was this done intentionally, to constantly update on the library, or is this only allowing the 8266 stuff ONLY while online, for a reason? A little mystifying?
Delta_G
Mine works fine offline.  Did you install it through the boards manager?
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
gelfling6
Yes, I have..  and I've noticed it on different OS installs (Windows & Linux). Both installed through the board manager, and when I connect to the internet, and run the IDE, it appears. Disconnect, reset the computer (either platform), but not logged into the internet (yes, some of us still step away from the net from time to time.), start the IDE, and...... If I go to tools-board, EVERYTHING for the ESP8266 disappears. I've also noticed a weird operation from IDE version 1.8.1, where it'll suddenly crash.. without warning, and it'll take 3-4 attempts to start it, before it'll come up.
ballscrewbob
Hmm no issues with my ESP's and 1.6.5 up to 1.8.1 under Win 7, Win 8, Server 2013, Win 10 on actual or VM bases.
Upgrades carried through the JSON config files too and still see all the ESP variations.
All packages currently up to date too here but ESP's did work under prev packages too.
Maybe something screwy at your end ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
gelfling6
If it is, it's on multiple platforms.. System 1, Intel i3/Ubuntu 16.04 LTS, System 2, AMD Vision, Windows-8.1, System3 AMD 64X2, Ubuntu 16.04.
The following steps:
While online, IF it can obtain the json file, the ESP8266 comes up in the board selection. Once set, If I disconnect from the internet, It will stay active, UNTIL.... I choose an Arduino.. Then, the 8266 selections disappear from the board list. and will not return, until I log out of the IDE, re-connect to the internet, and the json file is obtained/checked again.
ballscrewbob
#5
Feb 24, 2017, 10:45 pm Last Edit: Feb 24, 2017, 10:46 pm by Ballscrewbob
How are you getting the board defs ?
and once it has them are you going to board manager to pull in the packages and do the required updates ?
Not a Linux guy (Win as you prob guessed from my last post) but these are settings in the prefs and the ide itself which is nearly identical in appearance.
As proof I am attaching a pic showing that I am disconnected from the internet along with the board selection available for ESP's
gelfling6
The ESP definitions are only loaded if there is a link to the internet. (Which, is limited to only 2 hours where I live, Community access per day.)  it is only when it checks the json file, to see if any new libraries are available, that it has the 'generic esp8266' in the board manager.  When no-longer connected to the internet, But the generic ESP8266 is still selected, it recognizes all the libraries, and examples.  BUT....  if not connected, and I check any other board (example the Arduino UNO/Genuino UNO), then go back to the board manager, the ESP8266 selections no-longer exist.... (as I mentioned in the first post.) it could care less if the json file is still loaded.. as long as I'm not logged into the internet, it reverts to strictly a base Arduino IDE with Arduino-Only examples and libraries. (and any arduino libraries I've added. but ZERO ESP8266.) which would mean, IF i wanted to retain the ESP8266 settings, I would never touch the Arduino board selections.
ballscrewbob
Once loaded they are always available.
Or at least that's how it works under windows regardless of IDe from 1.6.5 r5 upwards here.
They dont need updates daily.
Only when a new release is sent out.
There is something very odd at your end if they are getting deleted between sessions.
pert
This seems very strange to me. There is an issue where if the Boards Manager URL of a 3rd party hardware package is not accessible when you open Boards Manager the JSON file for that package is deleted by the IDE and the boards disappear but on my system when I don't have access to the internet the download of downloads.arduino.cc/packages/package_index.json fails and that aborts any attempt to download other JSON files so no boards are affected (because that URL is always loaded first and the bug doesn't affect that JSON file).
Do you get the "Error downloading http://downloads.arduino.cc/packages/package_index.json" error message when you open Tools > Boards > Boards Manager with no connection to the internet?
If I understand correctly, you should be able to work around the issue by never opening Tools > Board > Boards Manager when you are not connected to the internet. There's no point in doing this anyway as without connection to the internet Boards Manager is useless.
I do think this all could be handled by the IDE much better:
  • Failure to load a URL should not abort attempts to load other URLs
  • Previously downloaded JSON file should not be deleted until the new one has been successfully downloaded
ballscrewbob
#9
Mar 12, 2017, 12:10 pm Last Edit: Mar 12, 2017, 12:11 pm by Ballscrewbob
@ Pert
Not the first time this has been mentioned recently.
That said I seem to be able to open and close board manager just fine even after I shut down all external access and still be able to pick out what I want from the ESP list (under windows 7 x 64, IDE 1.8.1).
Also have a couple of DEV URLS and they don't fail either if the first one or even just the second is misspelled (done it a couple of times typing from memory)
Took a screenshot with the disconnects ON and the board manager open recently so it is something I double checked for another poster.
pert
Are you talking about all the problems people had yesterday with their ESP8266 boards disappearing because arduino.esp8266.com was down? That's a different but probably related issue because in that case http://downloads.arduino.cc/packages/package_index.json was still accessible so it did proceed to attempt to load the ESP8266 URL. If you're not connected to the internet then downloading the Arduino file will fail and this causes Boards Manager to abort trying to load any other URLs.
I was thinking maybe it was related to the Arduino IDE's automatic checking for updatable boards but even after that running with my internet disconnected the ESP8266 boards still didn't disappear for me.
What do you mean by "don't fail"?
ballscrewbob
@ Pert
No talking about the issue of the IDE seeming to forget about ESP's unless it was directly connected to the internet.
Also wonder if they have a different server for regions too as I didnt have any issues at all yesterday here in Canada with ESP downloads. I removed the URL and moved the user folder 3 times. Then added back in the URL and the ESP's came back up once I told board manager to get the ESP items.
DEV URLS
If I have the first URL misspelled the others in the que appeared to work just fine and not fail.
Looks like it reads past the bad one and continues to the next here ?
pert
Yes, same with me. It's only if http://downloads.arduino.cc/packages/package_index.json can't be downloaded that it aborts attempt to download any other URLs. This was pointed out to the developers a while back when that URL wasn't working for a little while but they just fixed the problem with the downloads server instead of changing the behavior of Boards Manager.
gelfling6
No, I don't think it's a problem of the server, but the IDE itself...  I haven't fired-up the IDE at all today (Why not? Breakfast with my parents, and other things in life.) IF I were to shut-down the WiFi modem, and fire-up the IDE, it would come up set for the UNO, and see no active Com port.  If I click on board, it will only show Arduino boards..  But, the instant I turn on the modem, and restart the IDE, it will request any updates to the libraries. If none, or the same, it'll NOW add the ESP-8266 selections to the board list.  If I were to select another board (arduino), it would still retain the 8266 selections at the bottom.  Okay, turn off the modem again, close the IDE, wait a few minutes, start the IDE again, it would check for the JSON file, and fail.. Go to Tools > Boards, and........  Where did it go? the list ends at Arduino UNO WiFi, and a white down-arrow..  the ESP-8266 Modules list is gone!...   Sorry to say, it Does look like a problem with the boards manager maintaining 'other' boards, whether the json is read online or not.
gelfling6
Hardware/OS this is happening on:
 AMD Vision / Windows 8.1 Toshiba Satellite C855D / 8GB memory
 AMD 64-X2 / Ubuntu 16.04 Home-built desktop / 8GB memory
 Intel I3  / UBUNTU 16.04 Toshiba Satellite A505 / 8GB memory
   All, running Arduino x64 Version 1.8.1, All with ESP8266 by ESP8266 Community Version 2.3.0
If no responding internet connection, the only thing that shows-up on the boards manager, is "Arduino AVR boards Built In by Arduino Version 1.6.17 (when another board other than the 8266 is chosen, and the IDE has been restarted.)
 I'd provide screen captures, if I were using the Linux machines, and at present, the desktop is temporarily down (for an almost similar reason, I did a system update on it out of the machine (extracted the master hard drive, put it in a dock connected to the laptop, and booted it from the laptop.), and UBUNTU is balking at the NVIDIA drivers, locking the graphics log-in, in a crash-back to log-in loop. Without internet access for that machine, I cannot remove the drivers, force it to re-install the generic graphics driver, and restore the NVIDIA drivers off the internet.)
