Topic: Matrix clock RTC (Read 2638 times) previous topic - next topic
sasaa
Oct 25, 2010, 12:23 am Last Edit: Oct 25, 2010, 12:38 am by sasaa Reason: 1
Hi there,
I'm trying to make a nice clock for the master bedroom.
I got 4 rainbowdouino's with RGB matrixes on them.
it works great.
although I have no trouble trying to display the time of my "ladyada's log shield" over serial.
I want to display the time on the four matrixes so that every matrix just shows one number (only hours and minutes)
But i never worked with a RTC before so hoped to learn something here :P
If possible i love to have the seconds to but i dont know how.
32x8 pixels is a lot so it should work
sasaa
#1
Oct 25, 2010, 09:16 pm Last Edit: Oct 25, 2010, 09:24 pm by sasaa Reason: 1
I'm able to output it on my LCD's and the serial monitotr but not on the 4 matrices and it really bugs me.
the real problem is that i don't understand how to write it to the display when the numbers are bigger then 9 because it will then take 2 matrices to show the value
the serial monitoris very simple because its as simple as taken from the official example
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
   Serial.begin(57600);
   Wire.begin();
   RTC.begin();
 if (! RTC.isrunning()) {
   Serial.println("RTC is NOT running!");
   // following line sets the RTC to the date & time this sketch was compiled
   RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
   DateTime now = RTC.now();
   Serial.print(now.year(), DEC);
   Serial.print('/');
   Serial.print(now.month(), DEC);
   Serial.print('/');
   Serial.print(now.day(), DEC);
   Serial.print(' ');
   Serial.print(now.hour(), DEC);
   Serial.print(':');
   Serial.print(now.minute(), DEC);
   Serial.print(':');
   Serial.print(now.second(), DEC);
   Serial.println();
   Serial.print(" since midnight 1/1/1970 = ");
   Serial.print(now.unixtime());
   Serial.print("s = ");
   Serial.print(now.unixtime() / 86400L);
   Serial.println("d");
   // calculate a date which is 7 days and 30 seconds into the future
   DateTime future (now.unixtime() + 7 * 86400L + 30);
   Serial.print(" now + 7d + 30s: ");
   Serial.print(future.year(), DEC);
   Serial.print('/');
   Serial.print(future.month(), DEC);
   Serial.print('/');
   Serial.print(future.day(), DEC);
   Serial.print(' ');
   Serial.print(future.hour(), DEC);
   Serial.print(':');
   Serial.print(future.minute(), DEC);
   Serial.print(':');
   Serial.print(future.second(), DEC);
   Serial.println();
   Serial.println();
   delay(3000);
how do i get this "Serial.print(now.day(), DEC);" and split the digits if there are 2 :S so i can put in this
#include <Wire.h>
unsigned char RainbowCMD[5];
unsigned char State = 0;
unsigned long timeout;
 Wire.begin(); // join i2c bus (address optional for master)
 ShowChar(4,DIGIT1,0,0,15,0);ShowChar(3,DIGIT2,0,0,15,0);ShowChar(2,DIGIT3,0,0,15,0);ShowChar(1,DIGIT4,0,0,15,0); // time NOT working
//Name:ShowColor
//function: Send a conmand to Rainbowduino for showing a color
//parameter: Address: rainbowduino IIC address
//                 red,green,blue:  the color RGB
void ShowColor(int Address,unsigned char red , unsigned char green, unsigned char blue)
 RainbowCMD[0]='R';
 RainbowCMD[1]=0x03;
 RainbowCMD[2]=red;
 RainbowCMD[3]=((green<<4)|(blue));
  SentCMD(Address);
//Name:ShowImage
//function: Send a conmand to Rainbowduino for showing a picture which was pre-set in Rainbowduino Flash
//                 number:  the pre-set picture position
//                 shift: the picture  shift bit for display
void ShowImage(int Address, unsigned char number,unsigned char shift)
   RainbowCMD[0]='R';
   RainbowCMD[1]=0x01;
   RainbowCMD[2]=(shift<<4);
   RainbowCMD[4]=number;
    SentCMD(Address);
//Name:ShowColor
//                 ASCII:the char or Number want to show
void ShowChar(int  Address,unsigned char ASCII,unsigned char red, unsigned char blue ,unsigned char green,unsigned char shift)
   RainbowCMD[0]='R';
   RainbowCMD[1]=0x02;
   RainbowCMD[2]=((shift<<4)|(red));
   RainbowCMD[4]=ASCII;
    SentCMD(Address);
//Name:SentCMD
//function: Send a 5 byet Rainbow conmand out
//parameter: NC
void SentCMD(int  Add)
{   unsigned char OK=0;
    unsigned char i,temp;
   while(!OK)
   switch (State)
   case 0:
     Wire.beginTransmission(Add);
     for (i=0;i<5;i++) Wire.send(RainbowCMD[i]);
     Wire.endTransmission();
     delay(5);
     State=1;
     break;
   case 1:
     Wire.requestFrom(Add,1);
     if (Wire.available()>0)
       temp=Wire.receive();
     else {
       temp =0xFF;
       timeout++;
     if ((temp==1)||(temp==2)) State=2;
     else if (temp==0) State=0;
     if (timeout>5000)
       timeout=0;
       State=0;
     delay(5);
     break;
   case 2:
     OK=1;
     State=0;
     break;
   default:
     State=0;
     break;
i really don't know :S
Korman
#2
Oct 25, 2010, 09:43 pm Last Edit: Oct 25, 2010, 09:44 pm by Korman Reason: 1
I don't know where the magic DIGIT1 to DIGIT4 are coming from, but lets assume they're the puzzle to solve. Add this code to the top of your loop() function (as usual untested, the problem isn't interesting enough to start the IDE):
char DIGIT1 = '0' + now.hour() / 10;
char DIGIT2 = '0' + now.hour() % 10;
char DIGIT3 = '0' + now.minute() / 10;
char DIGIT4 = '0' + now.minute() % 10;
Korman
sasaa
#3
Oct 26, 2010, 07:35 am Last Edit: Oct 26, 2010, 07:37 am by sasaa Reason: 1
I will try it when I get home in about 9 hours :-P
the digit1 to 4 are just part of my explaination*
sasaa
It works GREAT ! I really love Open Source :P
thanks Korman.
I'll post my complete code soon :D
sasaa
finally got the time to post my clock code
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
long previousMillis = 0;
long interval = 5 * 1000; // elke 20 seconden verrandert de kleur.
int r_time = 1;
int g_time = 1;
int b_time = 1;
 Wire.begin();
 RTC.begin();
 // RTC.adjust(DateTime(__DATE__, __TIME__)); // Correct time
 delay(5000);
 ShowColor(4,15,0,0); ShowColor(3,0,15,0); ShowColor(2,0,0,15); ShowColor(1,15,15,15);
 delay(5000);
void loop(){
 char time1 = '0' + now.hour() / 10; if(time1 == '0'){ ShowChar(4,'0',0, 0, 0,0); }
 char time2 = '0' + now.hour() % 10; ShowChar(3,time2, r_time, g_time, b_time,0);
 char time3 = '0' + now.minute() / 10; ShowChar(2,time3, r_time, g_time, b_time,0);
 char time4 = '0' + now.minute() % 10;  ShowChar(1,time4, r_time, g_time, b_time,0);
 SetPixelXY(2, 0, 2, r_time, g_time, b_time);
 SetPixelXY(2, 0, 5, r_time, g_time, b_time);
 unsigned long currentMillis = millis();
 if(currentMillis - previousMillis > interval) {
   previousMillis = currentMillis;
   if(r_time != 0){
     r_time = 0;
     g_time = 1;
     b_time = 0;
   }else if(g_time != 0){
     r_time = 0;
     g_time = 0;
     b_time = 1;
   } if(b_time != 0){
     r_time = 1;
     g_time = 0;
     b_time = 0;
void ShowColor(int Adr, unsigned char R, unsigned char G, unsigned char B) {
 unsigned char shift;
 RainbowCMD[0]='R';
 RainbowCMD[1]=0x03;
 RainbowCMD[2] = B;
 RainbowCMD[3]=((G<<4)|(R));
 SentCMD(Adr);
void SetPixelXY(int Adr, unsigned char X, unsigned char Y, unsigned char R, unsigned char G, unsigned char B) {
 unsigned char TranslateX[8]={6,7,4,5,2,3,0,1};
 X = TranslateX[X];
 RainbowCMD[0] = 'R';
 RainbowCMD[1] = 0x04;
 RainbowCMD[2] = R;
 RainbowCMD[3] = ((G<<4)|(B));
 RainbowCMD[4] = ((X<<4)|(Y));
 SentCMD(Adr);
void ShowChar(int  Address,unsigned char ASCII,unsigned char red, unsigned char green ,unsigned char blue,unsigned char shift)
   RainbowCMD[0]='R';
   RainbowCMD[1]=0x02;
   SentCMD(Address);
   while(!OK)
   switch (State)
   case 0:
     delay(5);
     State=1;
     break;
   case 1:
     else {
       temp =0xFF;
       timeout++;
     if (timeout>5000)
       timeout=0;
       State=0;
     delay(5);
     break;
   case 2:
     OK=1;
     State=0;
     break;
   default:
     State=0;
     break;
ppccmd
I'm using RTClib files to test ds1307 RTC on data logger shield from Adafruit. Trying to compile ds1307.pde I get error that RTClib.h has many stray '\240'.
Here is the .h file itself
// Released to the public domain! Enjoy!
// Simple general-purpose date/time class (no TZ / DST / leap second handling!)
class DateTime {
public:
    DateTime (uint32_t t =0);
    DateTime (uint16_t year, uint8_t month, uint8_t day,
                uint8_t hour =0, uint8_t min =0, uint8_t sec =0);
    DateTime (const char* date, const char* time);
    uint16_t year() const       { return 2000 + yOff; }
    uint8_t month() const       { return m; }
    uint8_t day() const         { return d; }
    uint8_t hour() const        { return hh; }
    uint8_t minute() const      { return mm; }
    uint8_t second() const      { return ss; }
    uint8_t dayOfWeek() const;
    // 32-bit times as seconds since 1/1/2000
    long secondstime() const;
    // 32-bit times as seconds since 1/1/1970
    uint32_t unixtime(void) const;
protected:
    uint8_t yOff, m, d, hh, mm, ss;
// RTC based on the DS1307 chip connected via I2C and the Wire library
class RTC_DS1307 {
public:
  static uint8_t begin(void);
    static void adjust(const DateTime& dt);
    uint8_t isrunning(void);
    static DateTime now();
// RTC using the internal millis() clock, has to be initialized before use
// NOTE: this clock won't be correct once the millis() timer rolls over (>49d?)
class RTC_Millis {
public:
    static void begin(const DateTime& dt) { adjust(dt); }
protected:
    static long offset;
AND the pde file is ds1307 as follows:
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
   Wire.begin();
   RTC.begin();
void loop () {
   Serial.print('/');
   Serial.print('/');
   Serial.print(' ');
   Serial.print(':');
   Serial.print(':');
   Serial.println();
   Serial.print('/');
   Serial.print('/');
   Serial.print(' ');
   Serial.print(':');
   Serial.print(':');
   Serial.println();
   Serial.println();
   delay(3000);
Any ideas?
robtillaart
#7
Nov 16, 2010, 11:32 am Last Edit: Nov 16, 2010, 11:34 am by robtillaart Reason: 1
Please modify your posting and use the # button for code blocks (so it becomnes readable).
I have used the library with no problems, so it might be the installation. Have you tried to download & install the latest version of the library again?
Rob Tillaart
