Topic: In function 'void loop()': error: invalid convers (Read 2531 times) previous topic - next topic
npuckett
Nov 17, 2010, 06:13 pm Last Edit: Nov 17, 2010, 06:15 pm by npuckett Reason: 1
Hey everyone I keep getting this error:
error: invalid conversion from 'int (*)()' to 'long unsigned int' In function 'int calcDelay()':
I'm wanting to use the value returned from a function as the value for delay();  The code in the loop is a series of servoWrite. values and delays that are generated from an animation.
any insights as to what I'm doing wrong would be appreciated
Nick
#include <Servo.h>
Servo myServo1;
int servoPin1 = 50;
int inputPin1 = 0;
int minPulse = 500;
int maxPulse = 2700;
int  convVal;
int inValue;
int inmin = 0 ;
int inmax = 1024;
int outmin = 1000;
int outmax = 10;
void setup(){
  myServo1.attach(servoPin1,minPulse,maxPulse);
myServo1.write(0);delay(calcDelay);
myServo1.write(6);delay(calcDelay);
myServo1.write(12);delay(calcDelay);
myServo1.write(19);delay(calcDelay);
myServo1.write(26);delay(calcDelay);
myServo1.write(34);delay(calcDelay);
myServo1.write(42);delay(calcDelay);
myServo1.write(49);delay(calcDelay);
myServo1.write(57);delay(calcDelay);
myServo1.write(65);delay(calcDelay);
myServo1.write(73);delay(calcDelay);
myServo1.write(81);delay(calcDelay);
myServo1.write(89);delay(calcDelay);
myServo1.write(97);delay(calcDelay);
///... and more values like this
int calcDelay()
inValue = analogRead(inputPin);
convVal = map(inValue,inmin,inmax,outmin,outmax);
return convVal;
Groove
#1
Nov 17, 2010, 06:15 pm Last Edit: Nov 17, 2010, 06:18 pm by GrooveFlotilla Reason: 1
You need to call calcDelay(), not just dereference it.
Learning about arrays and for loops may reduce your code size too.
Per Arduino ad Astra
npuckett
Thanks for the quick reply - I knew it had to be something simple I wasn't seeing.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
