Topic: Why won't this blink? (Read 786 times) previous topic - next topic
dglstrp
I am trying to get a timer to work using millis, when I run this in the Main Loop, the LED turns on (Gator+ board so LED inverted), runs for 10 seconds then turns off.
So the while statement is working, but why doesn't the LED blink?
if (serviceBypassTrigger == HIGH ) //let system open and close doors while error is live
 unsigned long errorClockStart = millis() + 10000;
 unsigned long errorClockCount = 0;
 while (errorClockCount < errorClockStart)
  errorClockCount = millis();
  digitalWrite (errorLED,LOW);
  digitalWrite (errorLED,HIGH);
I just pasted the code cause it was so short.
robtillaart
#1
Dec 02, 2010, 05:22 pm Last Edit: Dec 02, 2010, 05:23 pm by robtillaart Reason: 1
It is allways better to paste the complete code because that makes it often much simpler to find bugs. This one is fairly easy, it will blink but you don't see it. After the errorled is made HIGH it is almost immediately made LOW again as there is no delay after the HIGH. Try this:
 [glow]delay(250);[/glow] // changed
 [glow]delay(250);[/glow]  // added
Rob Tillaart
dglstrp
Thanks Robtillaart!
That nailed it!
I knew it HAD to be something simple!
robtillaart
Manually tracing the code and saying out loud what it does in plain english solves many bugs in software, give it a try!
Rob
Rob Tillaart
