Topic: Fritzing Help (Read 5982 times) previous topic - next topic
jocelinenat
Hi guys I have this code and I want to be able to like use it, but I honestly suck at reading so I was wondering if someone could guide me to how to wire everything thanks!
Code: [Select]
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int button = 2;  // The button will be on Pin 7
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
pinMode(pos, OUTPUT);
pinMode(button, INPUT);
digitalWrite (button, LOW);
   if (digitalRead(button) == LOW)
 for(pos = 0; pos < 90; pos += 90)  // goes from 0 degrees to 90 degrees
 {                                  // in steps of  degree
   myservo.write(pos);              // tell servo to go to position in variable 'pos'
                         // waits 1s for the servo to reach the position
 if (digitalRead(button) == HIGH)
 for(pos = 90; pos>=90; pos-=90)     // goes from 90 degrees to 0 degrees
 delay(50);                             // waits 50ms for the servo to reach the position
