Topic: Re: Can't access ATC1000 ethernet to serial conveter IP (Read 168 times) previous topic - next topic
YGSH
 Hello Fiends,
                  I am trying to access atc1000 ethernet to serial converter using ip 192.168.2.1(As given in act1000 datasheet) but not getting any response. Changes in PC setting has made to assign address in the 192.168.2.2 to 192.168.2.254 range with a subnet mask of 255.255.255.0.
                  I have used this unit, almost 6 month ago and was working fine. But may be i changed his ip, later on and forget it. ::)  ::)  ::)  But now i am unable to access it. :smiley-confuse:
                  So any one knows, How to do it????
YGSH
User Manual is here: https://gridconnect.com/media/documentation/atc/ATC-1000-UM.pdf
Pc Setting Done same like this(Windows 7) : https://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
