Loading...
Pages: 1 [2]   Go Down
Author Topic: [SOLVED] switch case with strings  (Read 4101 times)
0 Members and 2 Guests are viewing this topic.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Please post the code, though. I'm curious why the compiler is complaining about a void type.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
The new/completed code:
Code:
// physical mailbox checker (PMC)
// 1. photoresistor detects "box open" state. blue activity LED is enabled.
// 2. if pressure sensor detects mail, green "mail present" LED is enabled.
// 3. if pressure is REMOVED, red "mail retrieved" LED is enabled.
// 4. LED is disabled 5 minutes after mail has been removed if
// no more mail is placed into box (accounts for outgoing mail).
const int photoPin = 11; // use pin 11 for photoresistor
const int pressurePin = 12; // use pin 12 for pressure sensor
// rgb led requires 1 pin for each color
const int redPin = 7; // use higher resistor on red!
const int greenPin = 8; //use regular resistor on green
const int bluePin = 9; // use regular resistor on blue
int photoState = 0; // variable for photoresistor state
int pressureState = 0; // variable for pressure sensor state
int mailPresent = 0; // variable for mail presence
char color = 'c'; // variable for color code for rgb led
void setup() { // pin setup (hardware)
  pinMode(photoPin, INPUT); // photoresistor is input
  pinMode(pressurePin, INPUT); // pressure sensor is input
  pinMode(redPin, OUTPUT); // led pins are all output
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  Serial.begin(9600); // enable serial output for debugging
char ledColor(char color) {
  switch (color) {
    case 'c':
      digitalWrite(redPin, 0);
      digitalWrite(greenPin, 0);
      digitalWrite(bluePin, 0);
    case 'r':
      digitalWrite(redPin, 255);
    case 'g':
      digitalWrite(greenPin, 255);
    case 'b':
      digitalWrite(bluePin, 255);
  photoState = digitalRead(photoPin); // box open?
  if (photoState > 0) { // box is open
    Serial.println("Mailbox has been opened");
    ledColor('b');
    delay(30000); // wait 30 seconds for mail
    pressureState = digitalRead(pressurePin);
    if (pressureState > 0) { // mail is present
      ledColor('g');
      mailPresent = 1;
      delay(30000); // wait 30 seconds for box to be closed
    else {
      ledColor('r');
      delay(300000); // stay red for 5 minutes
      ledColor('c');
    photoState = 0;
  else if (mailPresent = 0) {
    ledColor('c'); // clear the led
As you can see, the ledColor function does not return anything. Maybe your compiler won't complain?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I pasted the code into 0017, and changed char ledColor() to void ledColor. it compiled just fine.
Then I did the same in 0021. Same successful compile.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
That's very strange... I'm currently running on OS X. Which OS are you using? Maybe it'll work without complaint if I paste the code into a new sketch. I'll try that now and post the results when I get the chance.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I'm on Windows XP.
What is the error message that you get?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Very strange... I pasted into a new sketch (using void instead of char) and it worked perfectly. Must have been a non-printable character that found its way into the code or something. I've seen that happen before with line termination characters when writing shell scripts in Windows and then running them in Linux.
I was getting the error
Code:
error: variable or field 'ledColor' declared void
The confusing thing about it is that I was declaring it as a void function properly, but I guess that it saw it as a variable.
« Last Edit: December 23, 2010, 08:53:25 pm by mrbug » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
