Topic: [SOLVED] How to print the degree symbol ? (extended ASCII) (Read 12871 times) previous topic - next topic
ninja2
ninja2
Just upgraded to IDE 1.8.3
still see same issue, although appearing as a backward quesiton mark now - see attached
Whandall
IDE 1.8.1 / Win7-64 / Mega
Code: [Select]
float TbmpC = 24.1;
  Serial.begin(250000);
  Serial.print("Temperature: ");
  Serial.print(TbmpC, 1);
  Serial.print(char(176));
  Serial.println("C");
void loop() {}
Code: [Select]
Temperature: 24.1°C
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
ninja2
yep I used to see similar printed as per @Whandall
I'm using 1.8.3 on Win10-64 and Mega2560
still not solved :(
PS: @Whandall its curious you set 250000 as baud rate. I would have thought 115200 x 2 = 230400 more appropriate?
Coding Badly
#20
Jul 06, 2017, 10:17 am Last Edit: Jul 06, 2017, 10:18 am by Coding Badly
Serial Monitor now uses UTF-8...
Code: [Select]
float TbmpC = 24.1;
  Serial.write(0xC2);
  Serial.write(0xB0);
  //Serial.print(char(176));
void loop() {}
The correct byte sequence is easy to locate through Google...
https://www.google.com/search?q=utf8+degree+symbol
Whandall
That does not work on my 1.8.1 / Win7-64 / Mega
Btw 0xB0 == 176 (11 * 16)
Code: [Select]
float TbmpC = 24.1;
  Serial.write(176);
  Serial.write(0xC2);
  Serial.write(0xB0);
void loop() {}
Code: [Select]
Temperature: 24.1°C
Temperature: 24.1°C
ninja2
thanks, that solves it.
Did that come in after IDE 1.8.1 ?
FWIW all these work correctly:
Code: [Select]
Serial.print("\xC2");
Serial.print("\xB0");
Code: [Select]
Serial.print("\xC2\xB0");
Code: [Select]
Serial.print(char(194));
Whandall
I would still prefer
Code: [Select]
Serial.write(0xC2);
Serial.write(0xB0);
Serial.write(194);
Serial.write(176);
ninja2
I actually prefer the Streaming library by Arduinana for simplified outputting of Serial string commands. I've used it for years with no big issues:
Code: [Select]
#include <Streaming.h>
void loop {
Serial << "Temperature: " << TbmpC  << "\xC2\xB0" << "C\n"; // 0xC2B0 is degree symbol in UTF-8 charset
septillion
Small function to write extended ASCII
Code: [Select]
void writeAscii2Utf8(Print &out, byte in){
  if(in < 0x80){
    out.write(in);
  else{
    out.write(0xC0 | (in >> 6));
    out.write(in & 0x3F | 0x80);
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Coding Badly
#26
Jul 06, 2017, 07:23 pm Last Edit: Jul 06, 2017, 07:24 pm by Coding Badly
Given @Whandall's experience the answer is clearly "yes".
It looks like charting was added between x.1 and x.3.  But, as far as I can tell, text handling was not changed.
I suspect a bug existed in x.1 that was silently fixed by x.3.  Given the code for Serial Monitor the bug was either in the Java runtime itself or in the way the Java text components were initialized.
JohnnyDoe
for anyone who may run into this:
Code: [Select]
is the ONLY snippet I could get to work on my system:
Linux Mint 18.1, Cinnamon 3.2.7
Arduino IDE 1.8.3
Mega2560 R3
Eheran
Im on 1.8.4. And they are all not working for me now. And I just want to get a nice little "°"...
It used to be "\260" but nope. Giving me mirrored "?" or even more weird symbols:
Code: [Select]
      Serial.println("\xC2\xB0 C");
      Serial.write(0xC2);
      Serial.write(0xB0);
      Serial.write(194);
      Serial.write(176);
      Serial.println("\xC2");
      Serial.println("\xB0");
ninja2
I moved to 1.8.4 recently and \xC2\xB0 is still working as before for me ...
