Loading...
Pages: [1]   Go Down
Author Topic: multiple commands in an integer  (Read 353 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am attempting to create a simple program with integers a-h, each of which simply set a pin to HIGH, then to LOW after 500 ms.
how do I do this? is it even possible?
when I tried it this is what i did:
Code:
int a;
etc...
void loop(){
a = digitalWrite (0, HIGH);
       delay (500);
       digitalWrite (0, LOW);
it then told me "void value not ignored s it ought to be" what does that mean?
Am I just completely wrong?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
integers a-h
I could be mistaken but I believe those are letters of the alphabet.
I suspect you'll get more help if you provide more details.
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Yes, [glow]a = digitalWrite (0, HIGH);[/glow] is a bogus statement. You can't assign a digitalWrite command to an int.
If you post your complete sketch we can at least see what you are trying to do.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
To be pedantic, you can't assign the return value from the digitalWrite function to an int, because the digitalWrite function does not return a value.
That's what the compiler was trying to tell you.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Did you perhaps mean
Code:
digitalWrite (0, a);
(though writing anything to part of the serial interface is inadvisable)
« Last Edit: January 01, 2011, 08:48:56 am by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
For this you can use functions not integers, in the code below I have defined the function Pulse() that gets a pinnumber as parameter, so it can be used for different pins.
(code not tested)
Code:
  Pulse(0);
  Pulse(1);
  for (int i=0; i< 5; i++) Pulse (i);
  for (int i=5; i> 0; i--) Pulse (i);
  // etc;
void Pulse(byte pinNr)
  digitalWrite (pinNr, HIGH);
  delay (500);
  digitalWrite (pinNr, LOW);
PLease take some time to check the examples on - http://arduino.cc/en/Tutorial/HomePage
« Last Edit: January 01, 2011, 01:25:22 pm by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
