Topic: error: expected unqualified-id before 'if' (Read 1 time) previous topic - next topic
Johnyz
Hello everybody, I'm trying to make a clock that also measures humidity and temperature using SparkFun DHT22 temp. and humidity sensor, DS3231 clock IC and a 16x2 LCD. I threw these three programs together (still a little new to programming). Now, the clock IC program is working with 1 second delay, the DHT22 is using 3 second delay. I honestly don't know millis() and I don't think it would be much reliable too. "This number will overflow (go back to zero), after approximately 50 days." I set up a little if() that executes the DHT22 part if count is 3 (and sets count to zero), else it adds one to count and does not execute the DHT22 part. I keep on getting this error right at the if(count == 3) part. Here is the code:
Code: [Select]
#include <Wire.h>
#define DS3231_I2C_ADDRESS 104
#define DHT11_PIN 0      // ADC0
byte seconds, minutes, hours, day, date, month, year;
int count;
char weekDay[4];
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 // set up the LCD's number of columns and rows:
 lcd.begin(16, 2);
 lcd.clear();
 Wire.begin();
 // set the cursor to column 0, line 1
 // (note: line 1 is the second row, since counting begins with 0):
 get3231Date();
 watchConsole();
 lcd.setCursor(0, 4);
 lcd.print(hours, DEC);
 lcd.print(":");
 lcd.print(minutes, DEC);
 lcd.print(":");
 lcd.print(seconds, DEC);
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
 return ( (val/10*16) + (val%10) );
void watchConsole()
 if (Serial.available()) {      // Look for char in serial queue and process if found
   if (Serial.read() == 84) {      //If command = "T" Set Date
     set3231Date();
     get3231Date();
     Serial.println(" ");
void set3231Date()
 //T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year)
 //T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99)
 //Example: 02-Feb-09 @ 19:57:11 for the 3rd day of the week -> T1157193020209
 seconds = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48)); // Use of (byte) type casting and ascii math to achieve result.
 minutes = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
 hours   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
 day     = (byte) (Serial.read() - 48);
 date    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
 month   = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
 year    = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
 Wire.beginTransmission(DS3231_I2C_ADDRESS);
 Wire.send(0x00);
 Wire.send(decToBcd(seconds));
 Wire.send(decToBcd(minutes));
 Wire.send(decToBcd(hours));
 Wire.send(decToBcd(day));
 Wire.send(decToBcd(date));
 Wire.send(decToBcd(month));
 Wire.send(decToBcd(year));
 Wire.endTransmission();
void get3231Date()
 // send request to receive data starting at register 0
 Wire.beginTransmission(DS3231_I2C_ADDRESS); // 104 is DS3231 device address
 Wire.send(0x00); // start at register 0
 Wire.requestFrom(DS3231_I2C_ADDRESS, 7); // request seven bytes
 if(Wire.available()) {
   seconds = Wire.receive(); // get seconds
   minutes = Wire.receive(); // get minutes
   hours   = Wire.receive();   // get hours
   day     = Wire.receive();
   date    = Wire.receive();
   month   = Wire.receive(); //temp month
   year    = Wire.receive();
   seconds = (((seconds & B11110000)>>4)*10 + (seconds & B00001111)); // convert BCD to decimal
   minutes = (((minutes & B11110000)>>4)*10 + (minutes & B00001111)); // convert BCD to decimal
   hours   = (((hours & B00110000)>>4)*10 + (hours & B00001111)); // convert BCD to decimal (assume 24 hour mode)
   day     = (day & B00000111); // 1-7
   date    = (((date & B00110000)>>4)*10 + (date & B00001111)); // 1-31
   month   = (((month & B00010000)>>4)*10 + (month & B00001111)); //msb7 is century overflow
   year    = (((year & B11110000)>>4)*10 + (year & B00001111));
 else {
   //oh noes, no data!
 switch (day) {
 case 1:
   strcpy(weekDay, "Sun");
 case 2:
   strcpy(weekDay, "Mon");
 case 3:
   strcpy(weekDay, "Tue");
 case 4:
   strcpy(weekDay, "Wed");
 case 5:
   strcpy(weekDay, "Thu");
 case 6:
   strcpy(weekDay, "Fri");
 case 7:
   strcpy(weekDay, "Sat");
[glow]if (count == 3) {[/glow]
 count = 0;
 byte read_dht11_dat()
   byte i = 0;
   byte result=0;
   for(i=0; i< 8; i++){
     while(!(PINC & _BV(DHT11_PIN)));  // wait 50us finish
     delayMicroseconds(30);
     if(PINC & _BV(DHT11_PIN))
       result |=(1<<(7-i));
     while((PINC & _BV(DHT11_PIN)));  // wait '1' finish
   return result;
 //Serial.println("A");
 byte dht11_dat[5];
 byte dht11_in;
 byte i;
 // start condition
 // 1. pull-down i/o pin from 18ms
 PORTC &= ~_BV(DHT11_PIN);
 //delay(18);  //DHT11 must >=18ms
 delay(5);  //DHT22 must 1~10ms
 PORTC |= _BV(DHT11_PIN);  // pull-up 20-40us
 delayMicroseconds(40);
 DDRC &= ~_BV(DHT11_PIN);
 dht11_in = PINC & _BV(DHT11_PIN);
 //Serial.println("B"); //miss first 2 bits on DHT22
 if(dht11_in){
   Serial.println("dht11 start condition 1 not met");
   return;
 delayMicroseconds(80);
 if(!dht11_in){
   Serial.println("dht11 start condition 2 not met");
   return;
 // now ready for data reception
 for (i=0; i<5; i++)
   dht11_dat[i] = read_dht11_dat();
 DDRC |= _BV(DHT11_PIN);
 byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];
 // check check_sum
 if(dht11_dat[4] != dht11_check_sum)
   Serial.println("DHT11 checksum error");
 //debug
 for (i=0; i<5; i++) {
   Serial.print(dht11_dat[i], HEX);
   Serial.print(' ');
 Serial.print("check_sum=");
 Serial.print(dht11_check_sum, HEX);
 Serial.println(' ');
 //end of debug
 int HighByte, LowByte, TReading, SignBit, Whole, Fract;   //DHT22
 HighByte = dht11_dat[0];   //DHT22
 LowByte = dht11_dat[1];   //DHT22
 TReading = (HighByte << 8) + LowByte;   //DHT22
 Whole = TReading / 10;   //DHT22
 Fract = TReading % 10;   //DHT22
 lcd.setCursor(1,3);
 //      Serial.print(dht11_dat[0], DEC);  //DHT11
 //      Serial.print(".");  //DHT11
 //      Serial.print(dht11_dat[1], DEC);  //DHT11
 lcd.print(Whole);  //DHT22
 lcd.print("%  ");   //DHT22
 HighByte = dht11_dat[2];
 LowByte = dht11_dat[3];
 SignBit = TReading & 0x8000;  // test most sig bit
 if (SignBit) // negative
   TReading = (TReading ^ 0xffff) + 1;
 lcd.setCursor(1,10);
 //      Serial.print(dht11_dat[2], DEC);  //DHT11
 //      Serial.print(dht11_dat[3], DEC);  //DHT11
 if (SignBit) // If its negative
   lcd.print("-");
 Serial.println("C");  //DHT22
 //delay(2000);  //DHT11
 delay(3000);  //DHT22
 delayMicroseconds(810);
else{
 count++;
 delay(1);
delay(999);
Yes I already read all the topics about this and similar errors, I couldn't find anything useful. Either I'm blind or this is caused by something else. Does anyone see anything incorrect in the code? I might edit the code to omit functions like weekday etc. because I'm not going to be using them. Only hours, minutes, seconds and temperature + humidity will be used.
kevinsa5
I've never been able to read code effectively in the forum code boxes, but is that if statement in a method? seems like it's just chilling out there.
Johnyz
#2
Jan 03, 2011, 05:42 pm Last Edit: Jan 03, 2011, 05:42 pm by Johnyz Reason: 1
Bingo. And I nearly broke my keyboard with my head. I also moved other bytes and voids out of the void loop. And it compiled. Thanks. A lot.
Code: [Select]
#include <Wire.h>
int count;
char weekDay[4];
 lcd.begin(16, 2);
 lcd.clear();
 Wire.begin();
 get3231Date();
 watchConsole();
 lcd.print(":");
 lcd.print(":");
 if (count == 3) {
   count = 0;
   byte dht11_dat[5];
   byte dht11_in;
   byte i;
   // start condition
   if(dht11_in){
     return;
   if(!dht11_in){
     return;
   for (i=0; i<5; i++)
   // check check_sum
   //debug
     Serial.print(' ');
   //end of debug
   lcd.setCursor(1,3);
     lcd.print("-");
 else{
   count++;
   delay(1);
 delay(999);
void watchConsole()
     set3231Date();
     get3231Date();
void set3231Date()
 Wire.send(0x00);
void get3231Date()
 else {
   //oh noes, no data!
 switch (day) {
 case 1:
 case 2:
 case 3:
 case 4:
 case 5:
 case 6:
 case 7:
 byte i = 0;
 byte result=0;
 return result;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
