Topic: gsm sim900a not responding to at commands (Read 2064 times) previous topic - next topic
globalturist
hello.
i am currently using a gsm sim900A module (not shield) with an arduino uno with the following connections:
gsm tx -> arduino rx (D6)
gsm rx -> arduino tx (D5)
gsm gnd -> arduino gnd
the point is that before the code worked and i could send and receive sms and use AT commands but when i disconnected the 12v 1a adaptor and reconnected it the code stopped working, no AT commands work just a blank serial monitor.
connections were untouched.
code untouched.
usb cable to pc untouched.
adaptor swapped with several others with 12v and 1A also and the blue light indicated that every single one worked.
red light blinks every 3 sec, indicating that the module connected to the network.
tried writing "AT+CMGD=1,4\r" to the serial monitor yet no response just a blank serial monitor so i dont know if the memory was cleared.
the code:
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5, 6);
void SendMessage();
void RecieveMessage();
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  if (Serial.available()>0)
   switch(Serial.read())
    case 's':
      SendMessage();
    case 'r':
      RecieveMessage();
 if (mySerial.available()>0)
   Serial.write(mySerial.read());
 void SendMessage()
  mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+91504987076\"\r"); // Replace x with mobile number
  mySerial.println("I am SMS from GSM Module");// The SMS text you want to send
  delay(100);
   mySerial.println((char)26);// ASCII code of CTRL+Z
  mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
any idea how to fix the problem?
thanks in advance.
raviindranath
I am also having the same problem, i can call the mobile no, it is ringing.
but when i tried to send AT commands to modem using ardiuno uno board, it is not responding.
it was working first, now it is not responding.
i dont know how to make it works.
Please suggest
Kamal_arduino
Namaste,
I am in the same case situation it was working fine with AT commands and now its not responding.
any one please suggest.
Mariomiguel1987
I Have the mase issue I add a code that worked fine , then after a some testing of other codes it stoped working .
Vahyneck
Hey guys, I have an issue here, I bought a new A6 GSM module a week ago, but when started testing it using Arduino Mega, I couldn't get the response from the module, even if I send AT commands it does nothing. here is my code:
//Create software serial object to communicate with A6
SoftwareSerial mySerial(3, 2); //A6 Tx & Rx is connected to Arduino #3 & #2
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and A6
Serial.println("Initializing…");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
updateSerial();
mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
updateSerial();
mySerial.println("AT+CREG?"); //Check whether it has registered in the network
updateSerial();
mySerial.println("AT+COPS?"); // check which network you are connected to
updateSerial();
mySerial.println("AT+COPS=?"); // return the list of operators present in the network
updateSerial();
updateSerial();
void updateSerial()
while (Serial.available())
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while(mySerial.available())
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
Please I need your help guys.
