Loading...
Pages: [1]   Go Down
Author Topic: Parsing Strings in Arduino  (Read 1419 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am trying to modify a sketch to read a serial string and parse the data disply the values using two integers, zone & warn. An example of the string that will be coming into the arduino would be A001002, where 001 would be the zone and 002 would be the alarm. The sketch runs ok if I send the just 001002, but it does not work correctly if I use the A or F. Any ideas what I'm doing wrong? I want to read the data using the A or F delimiter to distinguish a correct data string. The code I'm using is.
Code:
// this program decodes a zone/alarm string sent via remote located PLC
// control
// the result is two integer variables that hold the current zone &
// priority alarm.
// the zone/alarm string is in the following format:
// A000000 or F000000
// where the first three characters are the zone and the second three
// characters are the priority alarm
// by Rob Faludi modified by bsr
// http://www.faludi.com
int zone;
int alarm;
int warn;
   // start up the serial connection with 9600-8-n-1-true (non-inverted):
  Serial.begin(9600); // start hardware serial process
   // blink the status LED
   //blinkLED(ledPin, 2, 200);
  for (int thisPin = 2; thisPin < 7; thisPin++) {
        pinMode(thisPin, OUTPUT);
  Serial.flush(); // clear the serial buffer before reading new data
  char alarmString[7]; // create a string to hold the alarm value when it's read
  memset(alarmString,'\0',7); // initialize that string to all NULL characters
  boolean alarmStringValid = false; // declare and initialize a variable to track whether the string has all valid characters
  byte inByte = '\0'; // declare and initialize a byte to read in serial data
  while(inByte = 0); {
    inByte = Serial.read(); // read data and wait for an A or F character
  Serial.println("starting..."); // show startup on the debug port
  Serial.println("GET");
  if (inByte == 'A'||'F'  ) { // if we got the correct start character
        while(Serial.available() < 6) ; {
      //wait for enough data to be available (6 characters of alarm
       //string), while doing nothing else
    alarmStringValid = true; // declare and initialize a variable to track whether the string has all valid characters
    if (alarmStringValid = true);
    for (int i=0; i < 6; i++) {
      alarmString[i] = Serial.read(); // read each time string character into a character array
      if(alarmString[i] < '0' || alarmString[i] > '9') {
        alarmStringValid = false;  // if any character is bad then the //whole string is bad
    Serial.println();  // do a linefeed on the debug port
    Serial.print("Alarm: ");
    Serial.println(alarmString);
  if (alarmStringValid == true)
    char zoneString[4];  // create a string to hold the zone part of the string
    memset(zoneString,'\0',4); // initialize that string to all NULL //characters
    strncpy( zoneString, alarmString, 3); // copy the first three //characters of alarmString into the zone string
    zone = atoi(zoneString); // convert ASCII zone string to integer and //store in the zone integer variable
    Serial.print("Zone: ");
    Serial.println(zone, DEC);
    char warnString[4]; // create a string to hold the warning part of the //string
    memset(warnString,'\0',4); // initialize that string to all NULL //characters
    strncpy( warnString, alarmString+3, 3); // skip three characters, then //copy the next two of alarmString into the warn string
    warn = atoi(warnString);  // convert ASCII warn string to integer and store in the warn integer variable
    Serial.print("Warn: ");
    Serial.println(warn, DEC);
  Serial.println(""); // print a blank line
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
This should be
Code:
 if (inByte == 'A'||inByte == 'F'  ) {
There are no shortcuts like you are trying to take.
Code:
while(Serial.available() < 6) [glow];[/glow] {
The block of code in the braces is execute only when  there is enough serial data. If should not start on the same line as the while statement, and does not need to be in curly braces. Either that or the semicolon does not need to be there. It seems more likely that the block belongs on a new line, and need not be a block.
Code:
   if (alarmStringValid = true)[glow];[/glow]
If alarmStringValid, do nothing. Why bother? The = should be ==, too.
« Last Edit: January 16, 2011, 02:51:09 pm by PaulS » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I made the following changes to the sketch, but it still doesn't recognize the A or F.
Code:
if (inByte == 'A'||inByte =='F');
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
Unless you REALLY now what you are doing, DO NOT DO THIS.
Code:
 while(inByte [glow]=[/glow] 0)[glow];[/glow] {
Logged
Pages: [1]   Go Up
Print
Jump to:
