Loading...
Pages: [1]   Go Down
Author Topic: When are function prototypes necessary?  (Read 577 times)
Highlands Ranch, CO
Offline Offline
Newbie
Sparkfun Autonomous Vehicle Competitor
View Profile
When are function prototypes required when programming the arduino?
I have never had to declare function prototypes for the arduino.  However, the code below does require the following prototoype:
void gpsdump(TinyGPS &gps);
In the thread at the following link, it states that the compiler will generate function prototypes automatically.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1288542862
Here's example code for compiling.  Comment out "void gpsdump(TinyuGPS &gps)" to see my issue.
Code:
#include <TinyGPS.h>
TinyGPS gps;
bool feedgps();
      Serial1.begin(4800);
      bool newdata = false;
      unsigned long start = millis();
      // Every 5 seconds we print an update
      while (millis() - start < 5000)
            if (feedgps())
            newdata = true;
      if (newdata)
            Serial.println("Acquired Data");
            Serial.println("-------------");
            gpsdump(gps);
      long lat, lon;
      float flat, flon;
      unsigned long age, date, time, chars;
      int year;
      byte month, day, hour, minute, second, hundredths;
      unsigned short sentences, failed;
      gps.get_position(&lat, &lon, &age);
      Serial.print("Lat/Long(10^-5 deg): "); Serial.print(lat); Serial.print(", "); Serial.print(lon);
      Serial.print(" Fix age: "); Serial.print(age); Serial.println("ms.");
      feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
      gps.f_get_position(&flat, &flon, &age);
      Serial.print("Lat/Long(float): "); Serial.print(flat, 5); Serial.print(", ");Serial.print(flon, 5);
bool feedgps()
      while (Serial1.available())
            if (gps.encode(Serial1.read()))
            return true;
      return false;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The only case I'm aware of that you need to generate a function prototype is when the function takes a reference argument (preceded by the &).
Logged
Left Coast, USA
Offline Offline
Sr. Member
Sometimes I just can't help myself.
View Profile
Older versions of Arduino required that functions with reference parameters had to be defined or declared before they are used in a sketch.
With arduino-0022, I can comment out both function prototypes and your sketch compiles without errors.
Regards,
Dave
« Last Edit: January 16, 2011, 04:59:55 pm by davekw7x » Logged
Highlands Ranch, CO
Offline Offline
Newbie
View Profile
OK, now I understand.  I have never used pointers and I am using version 21.  Problem solved.  Thanks for the help.
Logged
Pages: [1]   Go Up
Print
Jump to:
