Pages: [1]   Go Down
Author Topic: assign array to a 2D array error  (Read 791 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I use uno and lcd shield, why this code messes up my lcd output? With Serial print it gets stuck. With no print in program it works fine(ir signals received/sent correctly).
Code:
#define rec_memory  10
int rec_ind = 0;
// Storage for the recorded code
int codeType[rec_memory]={-1}; // The type of code
unsigned long codeValue[rec_memory]; // The code value if not raw
//unsigned int rawCodes[rec_memory][RAWBUF]; // The durations if raw
int codeLen[rec_memory]; // The length of the code
int toggle[rec_memory]={0}; // The RC5/6 toggle state
typedef int rawCodesDef[RAWBUF];
struct RawCodes {
    rawCodesDef x;
RawCodes rawCodes[rec_memory];
////// somewhere in code /////
    RawCodes tmpRawCodes;
    for(int i=0; i<RAWBUF;i++){
//        tmp_rawCodes[i] = 1;
        tmpRawCodes.x[i] = i+2;
  //  for(int i=0; i<10;i++){
   //     rawCodes[1][i] = tmp_rawCodes[i];
    rawCodes[1] = tmpRawCodes; // problem code <<<<<<<<<
in my debugging i only lcd.print "hello +time()"
with  "//rawCodes[1] = tmpRawCodes;" commented out i get " hello 1" , "hello 2" etc
with " rawCodes[1] = tmpRawCodes;"
i get "hello 1$%@...", "hello 2%5*" etc
txs!!!
Logged
Guildford, UK
Offline Offline
Full Member
Arduino rocks
View Profile
I'm not sure I follow you code but could it be you want to replace
Code:
with
Code:
memcpy(&rawCodes[1], tmpRawCodes, sizeof(RawCodes));
Iain
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
i made a simpler task and it haz the same affect
Code:
#include <LiquidCrystal.h>
#include <IRremote.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
int rec_ind = 0;
struct RawCodes {
    rawCodesDef x;
// read the buttons
int read_LCD_buttons()
 adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
 if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
 return btnNONE;  // when all others fail, return this...
 lcd.begin(16, 2);              // start the library
 lcd.setCursor(0,0);
 lcd.print("Push the buttons"); // print a simple message
 lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
 lcd.print(millis()/1000);      // display seconds elapsed since power-up
 //Serial.println(millis()/1000);
 lcd.setCursor(0,1);            // move to the begining of the second line
 lcd_key = read_LCD_buttons();  // read the buttons
    if (lcd_key == btnDOWN){
        RawCodes tmp_rawCodes;
        for(int i=0; i<RAWBUF;i++){  // RAWBUF == 76
            tmp_rawCodes.x[i] = i+1;
            //rawCodes[1].x[i] = i;
            rawCodes[1].x[i] = tmp_rawCodes.x[i];  // problem 2.. <<<<<<<<<<<<
        //rawCodes[1] = tmpRawCodes; // problem 1
        lcd.setCursor(0,0);
        for(int i=0; i<10; i++){
             Serial.print(rawCodes[1].x[i]);
             Serial.print(" ");
             //lcd.print(rawCodes[1].x[i]);
             //lcd.print("t");
        Serial.println(" ");
and using your code i get
sketch_jan17b:89: error: cannot convert 'RawCodes' to 'const void*' for argument '2' to 'void* memcpy(void*, const void*, size_t)'
Logged
Guildford, UK
Offline Offline
Full Member
Arduino rocks
View Profile
Sorry for the typo.
Should have been an & in front of the second parameter.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
ohz, thx.
Code:
works fine too.
found the problem by the way, it appears that i was out of ram...
i use 76*10 ints.
when reduced it to 76*9 ints it worked.
Code:
#define rec_memory  9
thats why disabling Serial was working, i guess Serial uses lots of ram? (output buffer?)
need other way to log my ir codes =)
Logged
Pages: [1]   Go Up
Jump to:
