Topic: CRC byte assembly and disassembly (Read 1 time) previous topic - next topic
kristina
I have a stream of bytes with a final crc byte I would like to compare with to check for errors.
in visual basic, it is written like this:
Code: [Select]
crc=0
For i=o To (n_rx - 2)
 crc += rxbuf(i)
Next i
crc = crc And HFF
If crc = rxbuf(n_rx -1)Then
How would I translate this to arduinian?
sixeyes
You've no supplied the VB code to declare the variables used so I'm assuming you can do this.
Code: [Select]
crc = 0;
for (i = o; i < n_rx - 2; i++)
 crc += rxbuf[i];
crc = crc & 0xff;
if (crc == rxbuf[n_rx - 1])
