Topic: There is no types.h in library-0019. (Read 11632 times) previous topic - next topic
baobao
Sep 24, 2010, 10:11 am Last Edit: Sep 24, 2010, 11:23 am by baobao Reason: 1
I want to use library-0019 and DHCP library.
DHCP-->
http://blog.jordanterrell.com/post/Arduino-DHCP-Library-Version-04.aspx
DHCP library doesn't correspond to 0019.
It included "types.h" and "spi.h".
But, Types.h is not in the library-0019.
SPI.h changed, too.
How should I do?
Egoblitz
I had the same problem with the UdpBytewise library. All I did for now was use version 0018 until I figure it out.  :P
jrraines
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1281603077
described a similar error that went away when Dhcp was added to the ethernet library. Could this be the problem?
baobao
Hello! Egoblitz and jrraines.
Thank you for the comment.
DHCP library and EthernetDHCP doesn't correspond to 0019.
I modified EthernetDHCP and arduino-0019(w5100.cpp, w5100.h), it corresponded.
It corresponded to arduino-0020, too.
I will report on the change to the author.
# May I write the change here?
# Should I write the change here?
EthernetDHCP
http://gkaindl.com/software/arduino-ethernet
gck
Hi everyone!
I'm the author of the EthernetDHCP library. I'll promise to eventually push out an update that's compatible with 0019+, it's just that I'm currently extremely short on time and that the significant change of the Ethernet and SPI libs between 0018 and 0019 was entirely unexpected for me.
Kiku, let me thank you again for your work to port EthernetDHCP too 0019+, and yes, please feel free to go ahead and post your changes here, so that others can use them.
Other than that, please use 0018 for now (You can still download it at Arduino.cc), since it might still be a week or two until I have some spare time again.
Thanks!
baobao
I modified EthernetDHCP and arduino-0021(w5100.cpp, w5100.h), it corresponded.
Please transmit the message if necessary.
dsk
kiku, the updated DHCP library for the current versions of Arduino would be incredibly helpful.  Can you please post it (or send me a copy)?
Thanks!
rnewbie
hi kiku, could u send me a copy too (arduino 0021 version)?
thanks ..
baobao
Hi dsk and rnewbie.
I'm sorry. The reply has slowed.
Mail was sent.
Rechena
Hi kiku
Could you also please send me a copy of the EthernetDHCP changed lib?
Rechena
baobao
Andre
Hi, any updates?
kiku, do you mind posting your changes here?
Thanks!
Rechena
Thanks for the mail with the DHCP but I still cant make it work :S
Still missing something.
Do I have to put some of the .h and .cpp inside the Original Ethernet Lib?
Thanks for the help.
Regards
Rechena
KineticaRT
Hi kiku
Could you please send me a copy of the EthernetDHCP library you've modified for compatibility with Arduino-0021.
Thanks
Simon
dlucas
#14
Dec 09, 2010, 09:20 am Last Edit: Dec 09, 2010, 09:21 am by dlucas Reason: 1
Kiku, I'd also appreciate a copy of what you've done.  It'll save me time :)
Thanks in advance.
