Topic: Qn about understanding capacitance meter code (Read 4064 times) previous topic - next topic
Myrmidon
Jan 20, 2011, 08:15 pm Last Edit: Jan 20, 2011, 08:16 pm by Myrmidon Reason: 1
Hello everyone, I have a question about the code found in the tutorial section of the site regarding a capacitance meter.  The code is:
/*  RCTiming_capacitance_meter
*   Paul Badger 2008
*  Demonstrates use of RC time constants to measure the value of a capacitor
* Theory   A capcitor will charge, through a resistor, in one time constant, defined as T seconds where
*    TC = R * C
*    TC = time constant period in seconds
*    R = resistance in ohms
*    C = capacitance in farads (1 microfarad (ufd) = .0000001 farad = 10^-6 farads )
*    The capacitor's voltage at one time constant is defined as 63.2% of the charging voltage.
*  Hardware setup:
*  Test Capacitor between common point and ground (positive side of an electrolytic capacitor  to common)
*  Test Resistor between chargePin and common point
*  220 ohm resistor between dischargePin and common point
*  Wire between common point and analogPin (A/D input)
#define analogPin      0          // analog pin for measuring capacitor voltage
#define chargePin      13         // pin to charge the capacitor - connected to one end of the charging resistor
#define dischargePin   11         // pin to discharge the capacitor
#define resistorValue  10000.0F   // change this to whatever resistor value you are using
                                 // F formatter tells compliler it's a floating point value
unsigned long startTime;
unsigned long elapsedTime;
float microFarads;                // floating point variable to preserve precision, make calculations
float nanoFarads;
void setup(){
 pinMode(chargePin, OUTPUT);     // set chargePin to output
 digitalWrite(chargePin, LOW);
 Serial.begin(9600);             // initialize serial transmission for debugging
void loop(){
 digitalWrite(chargePin, HIGH);  // set chargePin HIGH and capacitor charging
 startTime = millis();
 while(analogRead(analogPin) < 648){       // 647 is 63.2% of 1023, which corresponds to full-scale voltage
 elapsedTime= millis() - startTime;
// convert milliseconds to seconds ( 10^-3 ) and Farads to microFarads ( 10^6 ),  net 10^3 (1000)
 microFarads = ((float)elapsedTime / resistorValue) * 1000;
 Serial.print(elapsedTime);       // print the value to serial port
 Serial.print(" mS    ");         // print units and carriage return
 if (microFarads > 1){
   Serial.print((long)microFarads);       // print the value to serial port
   Serial.println(" microFarads");         // print units and carriage return
   // if value is smaller than one microFarad, convert to nanoFarads (10^-9 Farad).
   // This is  a workaround because Serial.print will not print floats
   nanoFarads = microFarads * 1000.0;      // multiply by 1000 to convert to nanoFarads (10^-9 Farads)
   Serial.print((long)nanoFarads);         // print the value to serial port
   Serial.println(" nanoFarads");          // print units and carriage return
 /* dicharge the capacitor  */
 digitalWrite(chargePin, LOW);             // set charge pin to  LOW
 pinMode(dischargePin, OUTPUT);            // set discharge pin to output
 digitalWrite(dischargePin, LOW);          // set discharge pin LOW
 while(analogRead(analogPin) > 0){         // wait until capacitor is completely discharged
 pinMode(dischargePin, INPUT);            // set discharge pin back to input
Particularly this bit
void loop(){
Can someone explain why the elapsed time bit is outside the {} for the while loop?  Am I right in thinking that this means that analogRead is constantly reading until it's >= 648?
Could this also be done similar to:
       do something
if (analogRead(analogPin)>=648){
     do something else
I'm not great at programming and i'm trying to understand this as i'm doing something similar but i'm not getting what I expect.  I haven't posted it because it's for a uni project and would rather understand the issue so I can implement it.
westfw
Yes, exactly.  "While analogRead is < 648, do nothing.  Then see how much time elapsed waiting for that to happen."
pocketscience
That while loop in the original code simply spins until the condition to break the loop is met - ie analogRead returning >= 649. They record the start time just before the loop, and then the time again right after the loop breaks - and a simple subtraction shows you how long the loop was spinning waiting for the condition to be met.
You pseudo-code is similar, however you need to consider the case where the while loop breaks and then the thing you're reading immediately goes back to < 648. Your if test will fail. The window for this to happen is small, but it could happen and bugs like that are tricky to find!
pocketscience
No replies in hours - then 2 within 11 seconds!! :-)
Myrmidon
#4
Jan 21, 2011, 11:37 am Last Edit: Jan 21, 2011, 11:38 am by Myrmidon Reason: 1
pocketscience, that could be what is happening in my code for mine.  I'm a hardware guy and fairly new to software so i'm still learning the nuances. :P
I'll mess around a bit more and change my while bit to more like the original code and see what happens.  I might be back. :P
Thanks for the help guys.
