Author Topic: Twitter again: search.twitter  (Read 1041 times)
... indessen wandelt harmlos droben das Gestirn
I'm stuck. I want to write an application which does a search on twitter. I have an ethernet shield and use the dns library. On the page apiwiki.twitter Twitter-Search-API-Method"it is said that the search API doesnt need the oAuth. And oAuth is a pain if you not know how to do Processing.
My question follows for I am not allowed to post URLs in my first msg  smiley-wink
I'm stuck. I want to write an application which does a search on twitter. I have an ethernet shield and use the dns library. On the page "http://apiwiki.twitter.com/w/page/22554756/Twitter-Search-API-Method:-search" it is said that the search API doesnt need the oAuth.
When I formulate the query:
 if (client.connect()) {
      Serial.println("connected");
      client.println("GET /search.atom?q=help");
      client.println();
I get the result :
<h1>Moved Permanently</h1>
<p>The document has moved <a href="http://search.twitter.com/search.atom?q=help">here</a>.</p>
When I copy this URL  into the browser I get the correct results.
So my question: How could I encode the URL "http://search.twitter.com/search.atom?q=help" in the Arduino programm so that the string provokes the connection to twitter and triggers the search?
Thanks in advance  smiley-wink
Seattle, WA USA
Online Online
Seattle, WA USA
The GET request gets sent to the server that the client connected to. Which server are you connecting to? The correct server is, obviously, search.twitter.com.
Hello,
yes, it is search.twitter.com with dns resolution. It also doesnt work with the correct static address of search.twitter.
Thanks
You will need to use ethernet code that supports DNS resolution of the IP address. Below is some code I've used for simple testing that uses a special ethernet library.
//zoomkat 11-13-10
//Kegger ethernet client with DHCP/DNS test code
//using the Kegger ethernet library
//for use with IDE 0021 and W5100 ethernet shield
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
// http://kegger.googlecode.com/files/Ethernet.zip
#include <Ethernet.h>
#include "Dhcp.h"
#include "Dns.h"
boolean ipAcquired = false;
DnsClass googleDns;
  Serial.println("getting ip...");
  int result = Dhcp.beginWithDHCP(mac);
  if(result == 1)
    ipAcquired = true;
    byte buffer[6];
    Serial.println("ip acquired...");
    Dhcp.getMacAddress(buffer);
    Serial.print("mac address: ");
    printArray(&Serial, ":", buffer, 6, 16);
    Dhcp.getLocalIp(buffer);
    Serial.print("ip address: ");
    printArray(&Serial, ".", buffer, 4, 10);
    Dhcp.getSubnetMask(buffer);
    Serial.print("subnet mask: ");
    Dhcp.getGatewayIp(buffer);
    Serial.print("gateway ip: ");
    Dhcp.getDhcpServerIp(buffer);
    Serial.print("dhcp server ip: ");
    Dhcp.getDnsServerIp(buffer);
    Serial.print("dns server ip: ");
    //// Do DNS Lookup
    googleDns.init("web.comporium.net", buffer);  //Buffer contains the IP address of the DNS server
    googleDns.resolve();
    int results;
    while(!(results=googleDns.finished())) ;  //wait for DNS to resolve the name
    if(results != 1)
      Serial.print("DNS Error code: ");
      Serial.print(results,DEC);
    googleDns.getIP(buffer);  //buffer now contains the IP address for google.com
    Serial.print("Web Server IP address: ");
    Client client(buffer, 80);
    Serial.println("connecting...");
      client.println("GET /~shb/arduino.txt HTTP/1.0");
      client.println();
      while(true){
        if (client.available()) {
          char c = client.read();
          Serial.print(c);
        if (!client.connected()) {
           Serial.println();
           Serial.println("disconnecting.");
           client.stop();
           spinForever();
      }  // while(true)
    } //if(client.connect())
    else {
      Serial.println("connection failed");
    Serial.println("unable to acquire ip address...");
void printArray(Print *output, char* delimeter, byte* data, int len, int base)
  char buf[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
  for(int i = 0; i < len; i++)
    if(i != 0)
      output->print(delimeter);
    output->print(itoa(data[i], buf, base));
  output->println();
    spinForever();
void spinForever()
  for(;;)
put in key search words,
Hello,
this is exactly what I have done:
The DNS lookup resolves the IP address correctly, but when i change the Program to
      client.println("/search.atom?q=help");
      client.println();
or
      client.println("search.atom?q=help");
      client.println();
instead of
I receive
<p>The document has moved <a href="http://search.twitter.com/">here</a>.</p>
So when the arduino makes the connection, there seems to be some sort of acknowledgement. So my string is interupted:
http://search.twitter.com ??? /search.atom?q=help
and I cant trace the code on the ethernetport  smiley-sad
